Question about Canon i9100D (Bundle) Photo Printer
Printing quality When I print images, I see lines across as the ink goes through. I tried to clean the printer head with maintenance tool many times, but it didn't  work.
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Have you spoken with Canon on this? They have a technique for cleaning the ink cartridge by hand that you can be talked through over the phone.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Will print a printed page with picture fine, try to print photo or any picture comes out with lines across
print heads need cleaning. check the tools/options maintenance for the print head cleaning option. It should be able to do a "self clean"
Mar 22, 2015 | Epson WorkForce 630 All-in-One Printer...
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
Not printing cyan on xerox 6360
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 22, 2013 | Xerox Phaser 6360 Laser Printer
Why is there a clear horizontal line within the printed line?
The print-head is like a paint-brush, in that it prints a "band" as it goes across the page.
In your case, some of the ink-jets are CLOGGED, and thus are not shooting ink as the print-head moves HORIZONTALLY across the page.
Run a few "print-head-cleaning-cycles", to try to unclog those ink-jets.
May 14, 2011 | Canon BJ 200EX InkJet Printer
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
Photos printed come out faint and lines andblack streaks across the photos how do i solve this/
lean The Print Head Nozzles (Windows) The following contains instructions to check the nozzles for poor print quality and perform cleanings of the print head nozzles as necessary. If print results are faint or streaks are printed, the print head nozzles may be clogged. Print quality can be improved by performing print head cleanings or print head deep cleanings. aution: Only used the approved methods below to clean the print head. Use of other methods may further clog the nozzles on the print head and may cause permanent damage the print head.
Note: It is important to check the cleaning results by printing Nozzle Check Pattern after each cleaning. Cleaning and Deep Cleaning consumes a certain amount of ink. Only perform a cleanings when necessary.
Print a Nozzle Check Pattern
  1. Confirm that the printer is connected to the computer and the printer is turned on.
  2. Complete or cancel any print jobs in progress.
  3. Open the Printers folder.
  4. Click the Maintenance tab. (The Maintenance window opens.)
    Note: The layout varies depending on the printer and version of Windows you are using.
  5. Insert a piece of letter-sized plain paper in the paper tray.
  6. Verify the desired paper source for the Nozzle Check is selected on the unit by changing the Paper Feed Switch if necessary.
  7. Select 'Nozzle Check'.
Aug 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Document print quality
A solid line sounds like a jet (in the print head) always on. Replace the print head (<$50 on eBay).
A white line (no ink) sounds like a clogged print head or a burned out jet. Replacing the print head will fix either one. If it is clogged, you might be able to clean it but this procedure is complex (soaking or special cleaners). Read about cleaning in other posts.
Jul 30, 2008 | Canon PIXMA MP750 All-In-One InkJet...
Blue lines running through my image
Did u use the original ink cartridges or compatible ones or refilled?
Jan 18, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Printer update
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head. NOTE:
a. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
b. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
  1. Press <COPY> or <PHOTO>.
  2. Press <Menu> repeatedly until <USER DATA> appears.
  3. Press < (left arrow) or > (right arrow) to select [MAINTENANCE].
  4. Press <OK>.
  5. Use < or > to select [CLEANING] or [HEAD REFRESHIN] as necessary.
    [CLEANING]: Performs normal print head cleaning.
    [HEAD REFRESHIN]: Performs deep print head cleaning.
  6. Press <OK>.
  7. Print a Nozzle Check Pattern to see if print quality improved.
    4. Press <OK>.
    5. Press <OK> again.
      The machine prints a nozzle check pattern (A).
  8. If broken or white lines appear in the pattern, perform two Head Refreshings (from steps 1 through 6) then print another Nozzle Check Pattern.
  9. If print quality does not improve after two Head Refreshings, replace the appropriate ink tank.
Confirming The Nozzle Check Pattern
Broken lines
sj402061.jpg White lines
sj402062.jpg Click here to return to step x to perform Head Refreshings
Oct 18, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon i9100D (Bundle) Photo Printer Logo
old marine
old marine
