Question about Samsung RS2630SH Side by Side Refrigerator
Refrigerator housing is getting very hot
The housing of the refrigerator between the side by side doors is very hot. The freezer and refrigerator are cooling but the ice maker is barely making any ice. I think the fan is not running in the rear of the unit and the compressor is hot. Would this cause the housing of the refrig. to get hot. The compressor is on the bottom rear and the housing is hot on the front of the appliance
  • 3 more comments
  • jletexier Jan 27, 2009
    The compressor fan burnt up, replaced fan, everything worked for about a week, now every few hours the refrig side where door closes gets hot, I unplug the refrigerator and plug it back in and it works okay for a few hours, I noticed the refrig side isnt cooling as it should even after four hours. I have been told by a pro that it sounds like the main board, this 2630 is only 2 1/2 yrs old. also the compressor keeps runing after the fan trips out.
    Jeff In NC
  • Mx-racer Feb 16, 2009
    I have the Samsung RS26WUNS ( A )
    Which i could find in your index. But I have the same problem.. The Fan wants to spin but dtops its rotation, like there is something wrong with the staft. mabe the voltage & amprage is to low?
    The space bar in the middle of the unit where the to doors met is very HOT.. The unit is only 3 years old???
  • Anonymous Mar 01, 2009
    I have the HOT door problem also.
  • pgofam Mar 25, 2009
    Frig is hot and fan is not working and compressor is hot
  • jaime_zilvet Apr 01, 2009
    the fan stop working and between the door at front is very hot
    President:
  • Samsung Master
  • 2,651 Answers
This is for sure the reeason for the heat between the doors, in mean time ( whike waitin got replace the fan behind the compressor, you can install a small cheap house fan behind unit to keep it cool , ohterwise it will eventually damage the compressor
Posted on Jan 06, 2009
Whwhat causes side-by-side freezer/refrigerator center partition to be hot to the touch?h
you got a short in the wiring from frig to the door get it checked stuff like that can burn your house down.
Jul 30, 2014 | Maytag Refrigerators
Door hot
Totally normal. The condenser sends hot gas through the frame to stop the freezer door freezing to the frame. Check to see if you have a fan behind the condenser grill and make sure its running and clean
May 04, 2017 | Maytag MSD2756G Side by Side Refrigerator
Hot housing
I am going to assume you refer the housing as the cabinet. If this is hot to the touch the condenser is clogged and cause this heat. Remove the toe grill under the doors, and clean/vaccum out all the dust from under the unit. Once cleaned the cabinet temp should drop, if not the condenser fan could not be running causing this heat. Clean it first before replacing anything to save money.
Good Luck
Dec 29, 2013 | Frigidaire GLRS234ZA Side by Side...
The top & sides of freezer outer housing getting quiet hot,but only near the door,ps-have the red light alert & rest seems ok,so going to try the defrost stuff.
If you remove the rear panel inside the freezer and examine the evaporator while running you will most times see a few rows of the evaporator with clear ice and the rest will be sweating water droplets. That is what a leak in the Freon will cause and look like. When the door frame gets hot it is sometimes caused by a defective condenser fan or blocked air flow and also reduce cooling. Warm is normal around door frame because you have hot gas flowing there to reduce sweating around doors. I will be here to answer any questions you may have, Thanks Sea Breeze
Aug 22, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Frig is very hot on the outside ban that meets the seal
That heat that you feel is part of the design of all refrigerators. Those heaters are there to keep water from condensing on the outside of the cabinet around the freezer door. Just like water condenses on a cup of Ice water. It will do the same on a refrigerator. If those small heaters were not there. The water would cause the paint to rust badly. There are various arrangements of heaters used on Freezers and refrigerators around the doors. Particularly the Freezer door.
As long as the fridge is cooling properly it is fine.
If the fridge fails to get cold, the outside of the cabinet will actually get quite hot.
Hope this helps,
Best, Mark
Dec 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Aug 19, 2009 | Maytag MZD2766GES Side by Side...
Freezer side is hot outside
There is no problem at all. The outside of the freezer is hot because it is rejecting heat from the inside of freezer compartment to the outside surroundings, this is a normal refrigeration cycle. As for the seals being hot, this may be to prevent the door from freezing shut. i know that commercial and industrial freezers have heated seals for this reason.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore fridge exterior is really hot
It is quite normal for fridge freezers to have what is called a door heater circuit around the freezer compartment to prevent any unwanted ice build ups ( a practice used in commercial systems). I would expect a certain amount of heat in the section described as it normally is the first part of the condenser (hot bit) circuit. As for burning the house down I have only heard of two cabinets (both in labs) that have done this and they were due to what was put in the fridges. If you are concerned though I would suggest you get a tech to check it. Hope this helps.
Aug 12, 2007 | Kenmore 57029 Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
421 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
