Question about Brother MFC 210C All-In-One InkJet Printer
Computer states printer spooler is not activated
How do is activated the printer spooler on my computer so i can add a printer to my computer?
    Genius:
  • 1,124 Answers
Go to Start, Control Panels, Administrative Tools, Services.
Windows 2000: Go to Start, Settings, Control Panel, Administrative Tools, Services.
Right click on the print spooler and select Properties.
Click on Dependencies to view a list of all the system components that the print spooler depends on.
Under Services, go to each of these dependencies and check the properties. In each case, ensure that the Startup type is set to Automatic, and that the Service status is set to Started.
Posted on Jan 06, 2009
Print spooler service stopped
Solution
Press START - Run - write msconfig - OK - Services - put checks on the print spooler - OK - restart
After computer restarts, to check printer spooler
press Ctrl+Alt+Delete - Processes. If there spoolsv.exe file, it means the printer spooler is active.
Nov 30, 2011 | Canon PIXMA Office Equipment & Supplies
Tip
PRINT SPOOLER PROBLEM ON XP/VISTA
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
on May 21, 2008 | Epson ACULASER CX11NF All-In-One Printer
On command to print with my epson lx-300+, message reads, "No Printer". When searched on fax and printer and double-clicked "Add Printer", a message came out saying, "It can't...
Hi Basti here,
Try this...
Resolution:
May 23, 2011 | Epson LX-300 Matrix Printer
Printer spooler
Resolution:
Mar 13, 2011 | Canon Office Equipment & Supplies
Print spooler not running. Dont know whether its connected but ive just had live help from microsoft for sound problem
Hi!
Resolution:
Feb 16, 2011 | Lexmark X1190 All-In-One InkJet Printer
Operation failed due to print spooler.
Try downloading the drivers from the following location. This should solve the issue:
http://software.canon-europe.com/products/0010383.asp
Apr 09, 2009 | Canon PIXMA iP1300 Printer
Printer spooler problem + lexmark X1150
Goto Start> Run> (type) regedit and hit ok Then open (Click on the plus sign)HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Spooler registry subkey and find an entry with the name DEPENDSonService.
Backup this entry so you can restore it if other problems arise. (To Backup Click on File Export select desktop and give a file name as Backup and save) After backing it up, delete the entry (value DEPENDonService). and then Restart the machine.
Then try installig the printer
Dec 07, 2008 | HP Officejet 4355 All-In-One InkJet...
Spooler servis dont work
Resolution:
Aug 25, 2008 | HP Office Equipment & Supplies
1020 Spooler SubSytem
ok, so for this, always had an issue with this one,
so, what i did is started the spooler, the way to do this is you have to go into control panel>>>admin. tools>>> services>>>printer spooler>>> and then you have a blue icon on your left where you have to click on the button that says start the spooler, now i recommend you minimize this window,
next step is that you add the printer through the add a printer wizard in most cases the printer should already have the basic driver installed into the computer. and way to add it to to start the add a wizard, click on add a port make sure the box where it reads plug in play is unchecked, so the only icon you have checked is the local port, next you choose the port that is usb001 from here you choose hp>>> then laserjet 1020, let the printer driver install and finally your done.
Jul 09, 2008 | HP LaserJet 1020 Printer
SPOOLER SERVICE IS NOT RUNNING
Resolution:
Pls Rate as Fixya if this helps, Thanks!!
Jun 26, 2008 | Dell A940 All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
300 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
