Question about IBM (76H3658) Expansion Module
Aptiva A50 occassional lockups
PC locks up from time to time. Has a slight electrical odor when this happens. Typically after a few reboot attempts the PC works fine. Help! Thanks
I want to use a system usb to boot to the usb drive of a xp professional IBM Aptiva desktop pc
How about this, Boot to safe mode with Networking. Download MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL SCAN, Delete ALL results, reboot. ALSO, run YOUR UP-TO-DATE Anti Virus, a Full Scan.
Jan 16, 2013 | IBM Aptiva E 240 (2158240) PC Desktop
Honeywell HZ680 Oil Filled Electric Radiator Heater has a popping sound and it just started emitting a foul odor - a few yrs oldive.com
This is a typical sound when the oil is starting break down and boiler inside. it typically indicates the unit is wearing out.
Dec 17, 2010 | Heating & Cooling
Wheel is locking up occassionally
ABS light come on when this happens ?
Dec 13, 2017 | 2001 Lincoln Continental
Hi, Seat Toledo 1996 occassionally cranks, fires,
check your air flow mass air flow sensor
Sep 11, 2009 | 1994 Volkswagen Jetta
'93 Chevy Lumina (car not van) 3.1 engine. Transmission occasionally will not disengage when coming to a stop and kills motor.Normally would be torque converter but this only happens every few weeks or so,...
you nee to get your torque converter lockup solenoid replaced. If you are not very mechanically inclined you probably don't want to attempt this yourself
May 03, 2009 | 1993 Chevrolet Lumina
IBM thin desktop unit locks up ramdomly
this sounds like the memory controller on the motherboard has gone out.
replacing the motherboard would solve the problem.
Sep 20, 2008 | IBM NetVista PC Desktop
COBRA NAVONE 300 GPS RECEIVER
The only thing I can suggest is to shut it off and reboot. I have experienced an occassional problem like that and seems to be related to calculations for some areas. There is an area in OK where mine will lockup everytime I go thru there. Try downloading the update from the Cobra site. It is a 2005 update.
Hope this helps.
Jul 22, 2008 | Cobra NavOne 3000 GPS Receiver
Freezing up
A few things to try. Check the event logs on your PC for Hard drive errors. If the lockups are random they could be caused by bad blocks on your drive in a paging or system file. If you see disk errors, replace the drive immediately and make sure to keep proper backups. Next, update all drivers, especially the video driver. Often lockups will be caused by Video driver corruption. Dont be scared to install beta versions of drivers for your laptop in an attempt to resolve the problem. Next, search out a utility boot CD from the internet. There are several, usually running linux but most contain a memory test utility that you want to run for a long period of time (several hours) to see if after a stress period you start getting memory errors. Next, search for speedfan on google and install it to monitor the temperature on your processor, this problem could be caused by dust buildup on the processor heat sync or cooling fan. Generally it would take some time to have this problem lock up the system, however, after the first lock up and reboot subsequent lockups would happen more quickly. Many laptop repair depots will do a service for under $100 where they will dissassemble the machine, clean the heat sink and fan (or replace it) and apply new thermal grease.
Jun 20, 2007 | Acer TravelMate C312XCi Tablet PC
Mirror Lock Up
I haven't heard of any firmware to fix this but you're not alone. A number of people suffer the problem. Rather than me just copying and pasting try googling "Nikon D50 mirror Lockup problem. There's plenty to read up on. You should find a solution, good luck.
Jun 30, 2006 | Nikon D50 Digital Camera
Computers & Internet Logo
32 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
