Question about Sony KV-32FS13 TV
TV shows red
My tv shows alot of red in the screen. anything that is supposed to be blue, is purple. What could cause this?
  • 32 Answers
It sounds as though the color settings have been altered or that the tv is going out. Assuming this is a crt unit, you might try adjusting the color or unplugging it for a few minutes.
Good Luck,
BB
Posted on Jan 06, 2009
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Sep 21, 2013 | Vizio Televison & Video
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
The picture has a purple tint to it, the TV displays one until it warms up. How can I fix this???!
Older TV units have a tube which is where the picture displays. It sounds as if the green firing beam could be failing which leaves the blue and red firing beam working causing you to get a purple haze on the screen. You might be able to get it repaired, however more often than not it is much cheaper to buy a new tv set.
Oct 03, 2012 | Televison & Video
The color seems to be off. No red, and lots of purple. This is a Toshiba 57H81 wide screen big box tv. It was purchased in 2002.
Could be a bad board within the tv but it is sometimes the source input meaning it could be dvd player, cable/satellite box, etc causing the loss of color but it is unlikely. I have one of these tvs and they use red green and blue projectors to reproduce the colors so when the red projector fails then you get purple which is green and blue colors combined without the red. I have found it to be sometimes a bad connection inside the tv and I found insects such as roaches inside others. Using extreme caution when opening the rear cover of any tv due to dangerous and fatal high voltage. You might find that simply cleaning out the inside of tv and reseating all the connectors might resolve your issue otherwise you would have haul this tv to a repair shop where you pay half the price of a new flat screen lcd for just repairing this tv which will probaly have another color go out next month.
Aug 15, 2009 | Toshiba 57H81 57" Rear Projection...
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Sony trinitron 32 " purple area on screen
Check any magnatic device near TV which causes purple color on screen. That device can be Speaker, Electronic toy, Watch like that carring piece of magnet inside. Remove that device and turn OFF your TV for half a hour, then power again. Hope the color will be fine n normal on entire screen.
May 31, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony KV-32FS13 TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
