Need instructions on how to change the belt in my washer
The belt slipped off of the pulleys and I can't figure out how to get it back on! it is a kenmore 417.40042990 front loading belt-driven washing machine
  • matthastings Jan 09, 2009
    I tried to turn the drum and it appears to be jammed by something, or somethings unknown. I cannot make it (the drum) make a complete revolution. what does this mean? is that why the motor threw a perfectly good belt? any help is appreciated!
  • 640 Answers
You have to take back off,,always unplug first..thats it just remove back take screws out all the way around back,,put belt on motor than spin drum pully...
Posted on Jan 06, 2009
  • onthethejob1
    onthethejob1 Jan 09, 2009
    ok im still with you i just want to be sure,,one more time go to the front of washer and push up and down on drum and listen for rattling,,or clanking ,,you should here no noise..okyou can do it better with belt off,,also you see that big pully that the belt goes on,,left it up and down too,,any noise
I have a 93 k2500 5.7 gas Chevy cheyenne that was squealing so we changed the tenssioner and pulley then changed the idler pulley along with the belt so far it has threw three belts and shredding them like...
The tensioner pulley moves back and forth to keep belt tight..the idle pulley just sits there and spins..none should have play at bearing. If u misplaced a washer/spacer it could cause the misaligned issue that is shredding belt..
Sep 27, 2014 | Cars & Trucks
Need Instructions to replace belt on panasonic SL-5N Turntable
To replace a turntable drive belt.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the center spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the center hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Job done.
Apr 11, 2013 | Audio Players & Recorders
How do I change a broken belt on washer
With most machines the back case comes off and its simple to do /Belt slips over the pulley then onto the motor Shaft, with some machines you may have to loosen the motor to adjust belt tension, making sure belt will not slips or be too tight which could result in bearing stress..Good luck
Feb 19, 2011 | Maytag EPIC MFW9700S Front Load Washer
My washer wont spin or agitate and there was a burning smell
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
How do you get the serpentine belt back onto a 1999 lincoln continental? we can't figure out how to put slack in the belt to get it back on the alternator.
there is a belt tensioner pulley you must lever back to produce the slack needed to slip on the belt. There is a socket type cutout behind the pulley. put in the appropriate size ratchet handle or breaker bar and move tensioner arm back against the spring tension on the pulley. slip on belt making sure the grooves of the belt are in the pulleys correctly
Nov 02, 2010 | 1999 Lincoln Continental
I have a Frigidaire GLTF1670A washer. When the washer goes into the spin cycle, I have noticed a progressively louder belt slipping sound. The washer is 7 years old. Do I need to replace the belt, or is...
Disconnect the washer from the electrical supply then remove the screws shown holding the rear access panel to the washer’s rear panel and lift the access panel off.
Cushion the bottom of the cabinet opening as shown to avoid hurting yourself with the sharp edge.
Plug the washer in then start a loaded spin cycle to check for belt slippage and the motor operation itself.
Replace the belt if loose or slipping. Remove the belt by turning the tub drive pulley and rolling the belt off the pulley.
Install the new belt in reverse order by wrapping it around the motor pulley and on one side of the tub drive pulley then turn the pulley to the other side in such a way that the belt wraps completely around the pulley. Secure the rear access panel back into position to complete the procedure.
Note: This advice is intended solely for the asker dolanbox as per live chat discussion.
Aug 30, 2010 | Frigidaire GLTF1670A Front Load Washer
My washer wont spin and it smells like it is burning it is only 3 yrs old
The burning you smell is probably the belt slipping. There is a belt which is attached to pulleys. The belt engages to spin the basin in the washer. When this belt slips the burning smell happens because the pulleys are spinning and the belt isn't. You will probably need to adjust the tension on the pulleys or get a new belt. This can happen from constantly overloading the washer or trying to get the washer to wash and extra large load while the water level is set at a smaller load.
Aug 07, 2010 | Maytag Washing Machines
How di change the belt on a 2000 maytag top load washer?
HI. you may have a defective idler pulley. excessive bearing clearance can cause the belt to slip off at times. A worn belt will slip off as well. i suggest gaining access to the belt to inspect for damage. you can start by pressing in the middle of the longest straight run. It should deflect no more that one inch. also inspect the belt for cracks, frayed edges or other signs of excessive wear. if any damage or excessive looseness is found, replace asap. It could also be stretched.
((You can check the pulley by removing the belt and physically rotating the pulley, if the pulley has excessive wobbling or shifting, replace it))
Sep 03, 2009 | Zanussi ZWF1430W Front Load Washer
Replace Belt Om WMA30 Washer
If you pull out the machine from where ever it is... then feel around the top on the sides of the machine two oblong small screw covers.. remove the covers remove the star shaped screws. and lift the top up from the front side of the machine and push back and it will come off..
remove the little panel at the back 4 screws. you do this so you can adjust the belt to sit on the last grooves on the motor pulley..
Now to get the belt you have to do it from the top if your doing it alone.. So from the top of the machine you lower the belt donw and onto the motor pulley then you put the belt on the fly wheel and turn it so as it walks on the flywheel...
rember pulley first then walk it on the flywheel and remember to adjust on the pulley so it sits on the grroves nearest to you not the motor
Jan 08, 2008 | Hotpoint WMA30 Front Load Washer
Washing Machines Logo
198 people viewed this question
Top Washing Machines Experts
