Question about Bosch 24 in. SHU43 Built-in Dishwasher
Blue rubber belt found in dishwasher after cycle
I just finished a cycle iin the dishwasher and founs a blue rubber belt inside. I would guess it came off something during use but I dont see where it goes- any ideas????
  • joann wallace Feb 22, 2009
    I also just found a blue rubber belt encircling the bottom arm in my two-year-old Bosch dishwasher after the cycle completed and I rolled the bottom drawer out. There's no way it got in there otherwise..
  • Anonymous Mar 20, 2014
    Ive found a white drive belt on the inside base of my beko dishwasher does anyone knowbwhere it goes
It, off you,r tupperware lid.
Posted on Nov 11, 2012
  • Tamsin Russell
    Tamsin Russell Dec 16, 2013
    so glad i found this here would have been reading the manual for ages!!!! thank you Crawford Grant!
  • 67 Answers
Dishwashers don't have belts only washing machines and tumble driers have them.
Posted on Jan 07, 2009
  • Hckyplyr Jun 04, 2012
    I also found a teal colored belt after a dishwasher cycle. I'm not saying it is a drive belt but obviously a part of my dishwasher and not broken or torn. I'm guessing I overloaded a rack. Any help? I don't want to have to call a repair man, as he will likely say "it just slipped off and goes here".
  • 4,806 Answers
Hi there
Dishwashers don't have belts only washing machines and tumble driers have them. Its probably something thats got in there by accident, nothing to worry about
Kind regards
Posted on Jan 06, 2009
Electrolux Dishlex DX302SJ#6 not draining
make this test and fix it. Merry Christmas
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#3#ixzz2nvKv4oia
Dec 19, 2013 | Dishwashers
Found a blue rubber type substance in dishwasher after cycle?
I found the same blue rubbery stuff all over the inside of the dishwasher. We used Finish Gel for a couple years. Here is what it looks like
Dec 17, 2010 | KitchenAid KUDR25 Dishwasher
After my dishwasher is finished everything has a gritty feeling to it,and the glasses have turned all cloudy and the forks have white stuff on them
You are not getting your rinse cycle. It sounds like your wash cycle is starting, then stopping if yo get grit. I take it you are using powder detergent. That is where the grit comes from. It should all dissolve by the end of the wash cycle, which leads me to believe the wash cycle is not finishing. And it sounds like the rinse cycle never occurs. You may have a bad timer which enables each cycle, if I had to guess.
Oct 08, 2010 | Whirlpool Dishwashers
Large blue band appeared on lower tray following wash cycle,
So. We had the same problem tonight and I have been sitting lookin at this thing for an hour and decided to run it and see what happened with no rubber band in there. After the cycle was over I noticed that my wife washes those "snap wear" containers in the dishwasher and these items have colored coated Mylar bands as sealers. When they heat they expand and can be dislodged. It was a coincidence that it wrapped itself around the bottom spinner. Myth debunked!!!!!
Mar 10, 2010 | Bosch Dishwashers
Dishwasher began smoking while cycling. Noticed some water in the bottom before starting the dishwasher. The little door for the soap pouch opened but the pouch stayed inside the door area. It smelled like...
hi..the reason to this problem is probably due to the
bad belt.you need to replace it with a new one.
check this out..
thank you..
kindly rate my response..
Jul 21, 2009 | GE Dishwashers
My frigidaire dishwasher routinely leaves some water in the bottom after it is finished washing and the dishes are always wet on the top
HI. check the following areas for faults.
2. Broken belt
3. Pump
Jul 19, 2009 | Dishwashers
I'm getting an error code LE on the control panel and there is still water in the bottom of the dishwasher. The cycle was almost finished. What is the problem?
This is a drainage issue. check the following to address this issue.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 26, 2009 | LG LDF6810ST Stainless Steel Built-in...
Bosch dishwasher has water in it after finishing a cycle. Is this normal or is there a problem
All dishwashers leave a small amount of water in the sump area to keep the rubber/plastic connections lubricated.
As long as the water is clear and has no odor, you have nothing to be concerned about. OK?
Apr 21, 2009 | Dishwashers
Water isn't draining
Check all the possible causes below to address this issue you are having. replace any part or device if found to be faulty
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Mar 30, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool dishwasher quiet #1
Have you figured your dishwasher problem out yet? In my Whirlpool, that tube doesn't fit on the wash column, it just snaps on to the lower rack, right above the washer column black rubber gasket... hope this helps!!!
Sep 02, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
720 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
