Looking for instruction manual on an american standard cleartap filter. trying to remove faucet and filter assembly is stopping me
  • 15,935 Answers
The part number (model # ) is required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 10, 2010
Double faucets cartridge replaced still drips
My best advice
is to believe everything you just experienced...
(Perhaps an UNSEEN flaw in the "MONOBLOCK")
Buy the replacement faucet... shop around:
I spotted it on eBay... (number not close...)
((but still reasonably priced)).
AMAZON
American Standard 1480 101 002 Seva Single Control Lavatory Faucet with...
Also went to eFaucets (but their site was stunned
(normally GOOD resource... ))
http://efaucets.com/
eBay (concierge... buyer protected... FREE ship'n)
American Standard 1480 150 002 Seva Monoblock Single Lever Handle Lavatory...
Save the old one (parts)and DIAGNOSE
it in your SPARE TIME...
Hope this helps
Carnac the Magnificent
Oct 19, 2017 | American Standard - Lavatory Faucet -...
How do I replace a spout O-ring on an American Standard Jasmine Hi-Flow Kitchen Faucet, 3821.831 or .834. I'm trying to get the spout assembly off to get access to replace. Thanks in advance!
The base of spout is like a nut unscrew then lift off spout install new o-rings be sure to use plumbers grease or vaseline to coat new o-ring ,reinstall as was disassembled that should take care of problem.You may need a strap wrench to remove spout base nut.
Jun 03, 2011 | American Standard Jasmine 3821.831.295...
I am trying to uninstall an American Standard 4205.104 Reliant + combi faucet in my kitchen and have been unable to remove the "mounting kit". The faucet is loose. The paperwork that came with...
Hi, TYhe instructions for both models are the same. The 2 different methods of installation/uninstallation in the instructions refer to whether or not an escutcheon was used when installed. The escutcheon is the chrome piece that encircles the faucet and fits on the sink. So, if you have just a bare, chrome tube entering the sink, there is no escutcheon.
I hope this helps. Please click a vote for me if it does.
Thanks,
Handie Andie
Mar 27, 2011 | American Standard Reliant+ 4205.104.002...
Remove from basin and install in another?
Go to American Standard website they have detailed instructions
Nov 14, 2009 | American Standard 7471.732.002 Hampton...
Set screw has been removed from American Standard single lever faucet. How do you remove the faucet
Faucets are fastened with nut(s) under the sink.
-Turn off and disconnect the water supply hose from the faucet.
-If this is a faucet with a sprayer you will need to disconnect the sprayer hose from the faucet as well.
-If this is a bathroom sink you will have to disconnect the drain stopper assembly, this should be self-explain when you look at it.
-Remove the nuts or nut holding the faucet in place. This can be a difficult task to get a wrech or pliers on the nut(s). If you are having difficulty you may need to acquire a tool called a "basin wrench" most hardware stores carry them ask for it, if the person knows his department he will take you right to it. They arn't terribly exspensive.
Oct 28, 2009 | American Standard Plumbing
American Standard Easy Touch 6310 kitchen faucet leaks at base
you must remove the faucet form the sink. under the plate in the middle is 2 screws. remove the screws to remove the body.
Jul 15, 2009 | American Standard Kitchen Faucet 6310 020...
American Standard Colony Soft gooseneck kitchen faucet leaks base
at the spout near the base is an echeion ring. turn this counterclock wise then pull up ring to expose the neck,pull spout straight up.this echeion cap holds on the spout to the base there are plastic parts inside so be careful when pulling apart.
Jul 13, 2009 | American Standard 4275.550.002 ColonySoft...
Removal of single hole kithcen faucet.
There is a bracket that slides between the threaded shaft and the bottom of the sink. There is usually a nut which is tightened up against this bracket. When this nut is loosened, the bracket will slide out. Of course, you first have to unfasten the two water supply lines. Once the bracket is removed, the two water lines which are made into the faucet are gently bent and the whole thing is removed from the top of the sink. Hope this helps.
Mar 09, 2009 | American Standard - Lavatory Faucet -...
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
