When i turned on ppears "use divice manager to repair"
SOURCE: phillips gogear wont let me format or repair please help
a good old smack on the desk and plugged it in a differnt usb slot a few times and it just worked. these phillips things are so dodgy!!!
WHACK IT ONE!! lol
SOURCE: phillips gogear need driver
To reload drivers:
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
SOURCE: Phillips GoGear 2GB
Without opening the Philips device manager, disconnect the player from the computer, turn it off, and hold in the volume + button. Continue holding in the volume + button as you reconnect the player to the computer. After reconnecting, continue holding in the volume + button until the "Found New Hardware" Wizard pops-up. Go through the reinstallation process. Once complete, open the Philips Device Manager and click on the update button to make sure the device has the latest firmware upgrade.
SOURCE: Phillips Gogear SA5285/37 is frozen
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
SOURCE: why does my phillips gogear freeze up
what makes an mp3 player freezes, is when you put oo much song in the mp3 player and the memory size of the mp3 player is not too large to carry all the songs you put inside the mp3 player.Or you installed an applications too large for it to carry,
So you can heck and delete some data inside to stop it from freezing again. Or if it has a space for external memory to put more data in it you can transfer some of the data into it to stop the freezing.
Take care.
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
