Question about Microsoft Zune JS8-00001 Digital Media Player
My Zune will not light up.
When i turn my Zune on (16g) it doesn't light up most of the time and it makes it really hard to read the screen. The only time it does light up is right after I unplug it from my computer. What can I do to fix this?
  • 2 more comments
  • Diekorenueft Jan 12, 2009
    My Zune does the same thing, except now it's not even lighting up after being plugged into the computer. I tried changing the setting for the backlight to be always on, but that doesn't help at all....
  • skatetillidi Feb 16, 2009
    mine does the same thing what do i do
  • ansanc Mar 02, 2009
    mine too
  • ann1218 Apr 07, 2009
    what will cause a microsoft zune not to light up
  • 502 Answers
There is an issue with the backlight of your screen. Sorry but your screen probably needs to be replaced. There are third party Zune repair services, that will fix it for cheap. Even better, I found an DYI Zune repair guide,so you can do it yourself too, not that difficult. Part is available on Ebay. If you can't do it yourself, have a tech savy friend do it for you. If it does work on a different PC, then the issue lies within your windows. If you re-install your PC to factory and then re-install fresh zune software it should work.
Posted on Aug 24, 2010
  • 38 Answers
Suggestion #1
.. Diek, maybe try to reset your device.
.. In fact, everyone try to do the reset. I do it at least once a week, just to give my Zune a soft kick in the pants. Mind you, I got me the ancient and original 30.
.. Set your backlight to 15 seconds. "Always on" will drain your battery far too quickly.
.. Drain the battery and then let it charge for a minimum of 3 hours.
.. Perhaps a Restore is needed, but only as a last result 'cause it will wipe your Zune clean.
.. Outside of all of that, call Zune support at 1-877-438-9863.
Posted on Mar 10, 2009
I think my zune is fried. every time i turn it on it makes a clicking noise and on the screen its says 5 & contact support. tell me wht you think it is.
Most zune 120s and 80 gigs with code 5 or 3 need major repair due to hard drive failed I see alot of them for sale.hard drives are not very cheap. seems to me that ms bought cheap drives.so send it in for repair or sell it.
Sep 13, 2010 | Microsoft Zune JS8-00001 Digital Media...
My zune 8 gig won't turn on
find the reset button and use a paperclip to press down on the resset button. only for 10 seconds. if it doesn;t work then do it again and hold it for 30 seconds.if that doesn;t work hold it for a min. if that does;t work its fried.
Nov 15, 2009 | Audio Players & Recorders
Zune does nothing! Screen says Zune with loading logo but...
Let it on and completely drain the power, then try it. Make sure your lock key is not locked either. (at the top of Zune Device)
Jul 15, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
120GB Zune wont turn on
Please try to hold Back, Center and Left at the same time to restore the zune,
Jun 02, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune blank screen
have you updated it to the latest firmware? cause zune's had a major malfution to to this years "leap year" the time change/date change messed with the internal clock causing major malfunctions
May 28, 2009 | Microsoft Zune JS8-00001 Digital Media...
I cant seem to turn off my zune completely, only pauses the unit, the screen goes black after holding the pause button, it appears to be off, then i go to use it hours later and the battery life has...
The Zune never really turns off completely. To turn it off, hold the back button and up on the Zune pad. As soon as the screen turns black, let it go, and turn on Hold.
This will turn it off completely.
Mar 26, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune wont load
This is how this problem should be resolved:
  1. Disconnect your Zune from USB and AC power sources.
  2. Because the player is frozen, its battery will drain—this is good. Wait until the battery is empty and the screen goes black. If the battery was fully charged, this might take a couple of hours.
  3. Wait until after noon GMT on January 1, 2009 (that's 7 a.m. Eastern or 4 a.m. Pacific time).
  4. Connect your Zune to either a USB port on the back or your computer or to AC power using the Zune AC Adapter and let it charge.
I cannot believe the savvy programmers for Zune did not identify this problem in advance
Jan 08, 2009 | Microsoft Zune JS8-00001 Digital Media...
My 30 gb zune is frozen
There's a fix:
Your zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connecter. Your zune should start up immediately. Press the backing of the zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Frozen zune 80gig 2nd gen, error 5
One last ditch effort: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
And, yeah, as far as the international replacement - that is how all the manufacturers are - they are not willing to pay the cost to keep their customers. Also, they have no process in place for fulfilling such a request, even if they have offices in both countries (which most of them do). Sad, really.
Jun 02, 2008 | Microsoft Zune JS8-00001 Digital Media...
My zune wont turn on
I turned on my Zune and the screen froze so I turned it off but it would not turn back on.
I went online and read somewhere that if the screen freezes then you should press up and back and wait for the zune insignia to come on. Well my zune was not just frozen it would not go on but I tried the up and back thing and it worked. it took about 9-13 seconds but it worked so give it a chance and if that doesn't work try charging it overnight. Hope that helps :D
Nov 12, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
934 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
