Goodman Draft Induction Fan Keeps Cycling On and Off
Here is my situation:
I have a Goodman (gulp) gaspack Model PGB042125-1 that is approximately 8 years old. In the past we have had to repair the the other regular issues (cracked heat exchanger, multiple bad igniters, burned compressor contacts, etc -- Thanks Goodman!), but I've got a new one and money is tight. The draft induction fan keeps cycling on and off -- regardless of whether the thermostat is calling for heat or not. The gas never turn on during the cycling and the igniter never glows, the induction fan just keeps cycling on and off and has been doing so for weeks. When the thermostat calls for heat, the unit works just fine. Is this a problem with the board that I keep reading about? I'm pretty handy with a volt meter but I have no clue where to start to diagnose the problem and I can't afford to either start replacing parts or pay for a house call to a professional to run the diagnostics. I've searched through the threads and cannot find an example of my problem. Please help me.
Thanks,
Walt
  • 70 Answers
Can you write down where the low voltage t stat wire go and disconnect the white wire at the unit to eliminate a short between the white wire and the red wire usually the colors are as follows red is 24volt , green is fan , white is heat, yellow is cooling I want to narrow down the red is not shorting to the white briefly let me know if this is possible if not we can try other checks
Posted on Jan 06, 2009
Condencer runs for 20 sec then off keeps repeting after 2 or 3 min goodman central system
Seems like it trying to start and then cuts out , possibly on overload. Try the machine on fan blow only , that will check the indoor unit to see if that is working. Then try cool or heat function while listening to the machine starting. If you hear a loud humming just as the fan starts, and then it cuts out, It could be a compressor issue. Possibly the start capacitor has failed.
May 27, 2015 | Goodman Heating & Cooling
Furnace will not ignite.
I think you are talking about draft induction pressure switch operation. Make sure the metal orifice located on the draft induction blower is clear. To check, remove the rubber tubing end at the pressure switch and blow into the tubing. It should be easy to blow through it. If it is plugged, remove the tubing from the blower orfice and use a paperclip, inserting it into the orfice to clear the opening. After repairing, and all is hooked up, retry the furnace start up procedure. If the code comes up again, replace the pressure switch.
Dec 17, 2014 | Goodman Manufacturing...
I have a Goodman GMS9 furnace. When the furnace starts the induction fan runs for about 15 seconds, the ignitor turns on but thats as far as it goes. The burners do not light and I don't think the gas...
The igniter heats a thermocouple to turn on the gas valve. From your description, the thermocouple may have failed. The noisy stack blower probably needs to be replaced but its controller may be in need of replacement as well.
Nov 01, 2013 | Goodman GMS90703BXA Heater
My heil n9mp2 isnt working just hums
is the flame igniting and then cutting off? on a gas furnace, the induction fan motor(draft motor) should start first (if the furnace is so equipped), then the flame, then the blower. if you have an induction motor (flue gas exhaust mmotor) this may be your problem (the induction motor isn't starting), if your unit doesn't have one, have you checked to see that you have gas? finally, the capacitor on the blower motor may be causing the motor not to start.
Jan 06, 2013 | Heating & Cooling
Goodman gaspack problem
Hi check the flame sencer is clean
Mar 23, 2010 | Heating & Cooling
Blower will not shut off
check the settings on automatic fan control check fan control is clean on the back , check humdifer stat is not set too high ,if fitted .........
Jan 09, 2010 | Goodman Furnace Draft Inducer Blower ...
Goodman pgb 0300751 gas package unit. The unit started running both the combustion and circulating fans. Technicians have put two new honeywell boards in it. the fans are still running. all circuits and...
then you need toi have them check the fan high limit that is mounted in the blower compartment. if it's closed then the blower fan and the conmbustion air fan will run together.
Feb 03, 2009 | Heating & Cooling
GOODMAN CMA80905CXBA FURNACE. INDUCTION BLOWER NOT ENERGIZING. GETTING 3 "BLINKS" FROM DIAGNOSTIC LIGHT (LOW PRESSURE SWITCH OPEN). THE A/C WORKS & THE BLOWER FAN COMES ON WHEN THE STAT IS IN...
the pressure switch is closed before the draft motor closes it.the board is telling you that this is not right.pull the wire(either) off of the pressure switch to see if furnace tries to light.if it does,you should replace the pressure switch.
Oct 02, 2008 | Goodman Heating & Cooling
Ever hear of this odd problem?
Sounds like the main circuit board. Get the freon level up to spec and if you can live for now with the inducer fan issue, let it ride. It will fail at some point.
May 18, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
201 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
