Question about Frigidaire FRT8B5EQ 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Clear Crispers, 2 Sliding Wire Shel...
Drain Pan Frigidaire Model #FRT18L4FW3 Where can I get cheap drain pan?
  • 409 Answers
SOURCE: Drain pan oder
hi there,
you will have to start by removing the kickplate. which is the panel under the doors. it's held on by 2 screws. remove the screws and remove the kickplate. you should have no problem pulling out the drain pan then. you can clean it with bleach no problem.
Posted on Sep 30, 2008
  • 943 Answers
SOURCE: Frigidaire FRT18IL6D
Hi thanks for your question. to unclog. pull fridge away from the wall. remove back cover , clean all coils. let fridge thaw for at least 24 hrs. get small plastic hose to push up the drain tube from the back. blow up yhr drain tube to clear the tube. thanks the appliance doc. please rte my answer, thanks.
Posted on Oct 12, 2008
  • 958 Answers
SOURCE: drain pan
yup..that's how it is. no solution but to pick up the dead mouse and clean the drain pan as is, where is.
you might send someone with a small hand to reach the pan completely. rinse it with soap and water to eliminate the odor. use gloves to pick up and clean the pan.
tnx 4 using fixya,
Posted on Oct 24, 2008
  • 102 Answers
SOURCE: Water draining under crisper bins & onto shelves. Try again
Your drain tube is stopped up. Take the panel off in the freezer section and chip away the ice in the pan below the coil. When you get to the drain hole pour hot water in it until it free flows. You will need a towel in the freezer to catch the excess water. Run some extra hot water through it to assure that you clean the drain out good.
Posted on Apr 01, 2009
  • 123 Answers
SOURCE: Water leak under refrigerator, Frigidaire, FRS6R5ESBC
chk out dis video
Posted on May 14, 2009
My Frigidaire refrigerator has a drain pan that is un remove able and has a bad smell how can I clean.
I appreciate your inquiry, friend!
If you would like to clean any dirt or debris from the drain pain you can use a vacuum attachment to get inside and clean any residue within the drain pan. You can also use warm water and bleach to help disinfect the drain pan prior to vacuuming it out. If that does not help you may want to consult with a professional technician for additional cleaning to be completed within your Frigidaire refrigerator. Best of luck! -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Why is there water accumulating at the bottom of my refrigerator?
More than likely, the drain tube connecting the bottom of the drain pan under the cooling coil is either frozen or blocked by debris. If you can locate the pan under the cooling coil which is located in the freezer, you can clear it by using a straw to penetrate the drain pan opening and blow through the straw and clear the drain tube.
Jul 14, 2014 | Frigidaire Refrigerators
Where is the drain pan drain hole on the bottom of the Fridgidaire FAC 127S1A air conditioner?
Good Morning Friend,
I understand you want to know where the drain hole is on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, instead of draining. The drain hole is located beneath the compressor. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. Hope this is helpful.
-Best Regards-
Jul 06, 2014 | Frigidaire FAC127S1A Air Conditioner
Where is the drain hose for a frigidaire model frs23lh5ds9
Hello mcdh109 - Generally speaking, side by side refrigerators have a drain pan located on the right hand bottom side that in some models it is not removable. The unit does not actually have a drain hose.
Dec 16, 2012 | Frigidaire FRS6R5EMB Side by Side...
How do I remove the drain pan to clean it. My freezer is frost free frigidaire upright. The defrost timer went out and some of the food defrosted and drained into the pan and on the floor. There is some...
On older freezers/refrigerators the drip pan could easily be removed. On newer models its now part of the base frame and their is no way to remove it. Dam shame if ya ask me since it was recommended noraml to remove and clean drain pan every couple months, but hey ain't modern technology great hehehehe
Aug 01, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Model # FFU14F9GW.. water pooling under unit
If the water is pooling under the bottom drawer. I'd say your drain is clogged..the drain will freeze over from something getting into the drain i.e. food particle....The best thing to do. Is use a hair drier to defrost the drain pan and then make sure your drain runs free by pouring water into it....
if this is pooling under the refrigerator and out on the floor..There is a drain pan problem..and /or the drain hose going to pan is out of the pan , or has a hole in it...correct as needed
If this has been helpful in fixing your problem..please leave a testimonial.....thank you
Dec 12, 2010 | Frigidaire Freezers
I have a Frigidaire refrigerator top freezer model # FRT8B5HBO serial # BA80212978. It leaks from the bottom front in the morning. What do you think the problem is. Exactly where is the pan located...
It's not the pan that's the problem, it's the drain line to the pan.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Nov 19, 2009 | Refrigerators
Water dripping down on top shelf of refrigerator compartment.
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of may see ice build up...melt ice with hair dryer/heat will see a pan below evaporator...melt ice in pan...dry water up in pan with paper you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 18, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Drain pan
If u have 2 people u can lean the fridge back and the drain pan unscrews from the fridge from the bottom even though it says "non-removable
Oct 24, 2008 | Frigidaire FRT8B5EQ 30" 18.2 Cu. Ft. Top...
Refrigerators Logo
43 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
