Question about Freeplay Energy Plus AM/FM/SW Radio
Global shortwave Freeplay radio overwound. How to fix this?
I have a Freeplay radio, called Global Shortwave. It has a hand crank and a solar-powered system to make it play. The windup part was overwound and stuck. I can't get it to unwind.
I have been warned not to open the radio (by the information provided from manufacturer) in case the spring uncoils.
I would like to get the windup component of this Freeplay radio to work again.
Can you help?
Thanks in advance for your kind consideration.
SOURCE: Shortwave programmes
MORE INFO NEEDED!
Posted on Jan 26, 2008
SOURCE: users manual for the grundig g5 shortwave radio
I can't find one either but there is a downloadable manual for the Eton E5 at Retrevo.com  Just search for Eton E5
Posted on Feb 28, 2008
SOURCE: Original Freeplay windup radio.
it sounds like your drive belt has worn out. Check ebay, there is a guy who sells the belts. it is a thin O ring type drive belt and is simple to fix. Search for "baygen belt".
Posted on Jul 29, 2008
Tony,
Can't help you with the aerial. Mine made the same noise when winding down and I fixed that by pouring talcum powder around the windup section. Let it unwind and allow the talcum to go in,,,, and presto.......no more grinding noises.
Carlo
Posted on Oct 01, 2008
SOURCE: dynamo problem
In the original big black Baygen radio there is a blue wire with a solder joint that breaks. This wire shunts part of the load back to the generator and prevents it from running to fast and going over-voltage. I am guessing that a similar problem is affecting your newer smaller radio. On the original radio after you take the two halves of the case apart there is a blue wire that comes from the 3v input jack on the back half of the case and goes to the radio circuit board near the top corner. The solder joint where the wire is soldered breaks easily. With this wire broken the generator will run to fast because there is very little load. The radio will still play if you slow the generator with your hand as it is playing back. If you resolder this wire the radio will work and the generator will run at the proper speed. This takes only a moment or two.
Good luck.
Posted on Nov 13, 2008
Manual for grundig 750 radio
Here is a link to the manual for your radio.
http://www.etoncorp.com/sites/default/files/GS750_Manual.pdf
Dec 11, 2014 | Grundig Eton Satellite 750...
Realistic DX300 shortwave do not receive
you may have to change caps and some transistors.
Aug 06, 2012 | Radio Shack Dx-302 Shortwave Am/usb/lsb-cw...
I just purchased the G6 Aviator. The FM band works well, but none of the AM or shortwave stations get reception. I have tried the antenna up and down, indoors and outdoors with no success.
It sounds like the whole am band is not working which includes the shortwave bands, there is no remedy to correct this and is clearly a manufacture defect. The best solution is return the radio because there is nothing more that can be done in it's present condition.
Mar 03, 2011 | Grundig G6 Aviator (Buzz Aldrin Edition)...
No am on am band
Usually the "front end" of the radio has a bad FET transistor. This is caused by a static zap at the antenna. Early models suffered from this and the cure is to replace the FET and add protection diodes. If you need help with this email me at.... poikaa@yahoo.com
Rod
Nov 08, 2009 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF 2010 Shortwave scan does not scan, it beeps.
It will not scan blank memories and it will not scan on search function till you specify a frequency range.
Rod
Jan 30, 2009 | Sony ICF-2010 AM/FM/SW Radio
Before you call a doctor or an exorcist, verify that you're using your shortwave receiver under normal condition. There are several factors which affects reception of whortwave programs and signals.
1. Check for the time and frequencies. Depending on your country and location, all Shortwave time zones are based on World Time in UTC or GMT ("Universal Time Coordinates" or Greenwich Mean Time") In my country (Philippines, Asia) for example, we are 8 hours advanced from World Time. You can check your time zones and regions using a world map.
2. Check for propagation and band conditions/ openings. During daytime higher frequencies such as 9 -21 Mhz are active, while nightime frequencies are the lower bands such as 3 - 9 Mhz. Daytime and nigthime divider frequency is about 10 Mhz, that means you might receive signals under most conditions during daytime and night time. Check some technical books on amateur radio operations or magazines for radio reception. It might be worthwile to study books or materials on receiving international broadcasts stations before you can receive good or adequate shortwave signals. This might become your hobby too, "DXing" or receiving distant stations from across the world. Try it, but it might be an addicting hobby once you're drawn to it!
3. Check if any shortwave station broadcast in any specific time of day at any frequency. Shortwave broadcasts are scheduled based on band openings mentioned above. If for example I'm a Shortwave broadcaster from Asia, and would like to broadcast my signal through the Americas, I would use band openings with respect with time zones. If it is night time in the Philippines, and daytime in the Canada, I would use the higher frequencies to propagate my signal. So I would specify the time for example "8:00 pm Philippine local time, 12 hours UTC, and 7 am in Canada"--- Asia: 8 hours advanced to UTC, Canada--- 5 hours behind to UTC). So shortwave broadcast schedules varies. Broadcast schedules are available on the net, just search for the Shortwave station you want to hear such as Radio, Japan, Radio Australia, BBC, DW (Deutche Welle) Radio in Germany, China Radio International... There's too many shortwave stations waiting to be discovered out there! Check some books and magazines too such as Popular Communications, Monitoring Times, Passport to World Band Radios, World Radio and TV Handbook, etc. You may want to check if any station would be broadcasting in your dialects as most of these mainstream and regular broadcasters are multilingual.
2. Check your location. If you are using your radio indoors, shortwave signals might not entering your homes or offices due concrete walls and metal railings or fence. There are many factors which blocks radio waves especially in the HF or lowetr bands. Try receiving AM (Mediumwave) first. If it cannot receive any AM station, then you would not receive any Shortwave signal at all, even if you extend fully the telescopic whip. If you cannot receive AM or Shortwave signal indoors, try using your receiver outdoors.
2. Check for local interference. Your receiver might be receiving interference from noise generating gadgets such as PC monitors, TV sets, faulty wall adapters or switching power supplies, motor operated appliances such as washing machines or vacuum cleaners, flourescent lamps, etc. Try turning off or unplugging each of these mentioned gadgets to see if they are the cause. Faulty house wiring or powerline noise might also cause some interference noise which could drown shortwave signals, verify this with your local electrical technicians.
3. Check your radio's settings. Depending on the radio that you use, there might be settings such as attenuator or RF gain, be sure that attenuator are set to zero or turned to off, and RF gain to high. Attenuator must be turned to minimum or OFF position, unless you are receiving too much signas from nearby radio stations. Setting attenuator to mid or high position will attenuate most weak signal, and only those strong local stations will pass through. Setting too much attenuation will prevent you from receiving any station at all. Same with RF Gain, always set it to highest gain setting unless you are receiving too much signals which might overloads your shortwave radio.
4. If these troubleshooting efforts above doesn't works and you still cannot receive any station, then your radio's front end parts might had burn out due to signal overloads. Burn parts might include one or several transistors or diodes. Let your local service technicians check your radio and solve the problem for you. If your radio is still under warranty, send it back to the store or dealer, and let a qualified technician do the repair.
MANNY DE GUZMAN JR.
SoundMagik Home Studio
Site Creator, Teen Models 2007
Visit my website at http://mannydeguzmanartist.wetpaint.com/
My YouTube Channel, http://www.youtube.com/user/mannydeguzmanjartist
My imeem social media channel, http://mannydeguzmanartist.imeem.com/
My Talents and Modeling site at http://teenmodels2007.wetpaint.com/
I've also signed up an account at Total Popstar, uploading some promotional videos. You can watch and rate my videos (you can find my videos on the right side of the screen), just click the link here: http://www.totalpopstar.com/?profile/index/&1740
Thank you very much. I hope I'll really be of help here at FIXYA.COM!!!
Jan 26, 2008 | Sony ICF-SW30 Radio
Users manual for the grundig g5 shortwave radio
Jan 24, 2008 | Grundig YB 400PE AM/FM/SW Radio
Sony CDX-GT360S NO AM OR SHORTWAVE RECEIVE
am fm receiption not the same most likely antenna make sure the antenna wire fit tightly in radio cheers
Jan 08, 2008 | Sony XPLOD CDX-GT200 CD Player
Freeplay Energy Plus AM/FM/SW Radio Logo
133 people viewed this question
Top Freeplay Energy Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Freeplay Energy Audio Player and Recorder Expert? Answer questions, earn points and help others
