Question about Sansui 19 in. LCD TV
Sansui HDLCD1908 not recieveing Digital channels
I tried everything. I even plugged in my antenna that is working for my 42 inch HDTV which works just fine. But when I plug it into my Sansui it just says, "Digital signal too weak" or something like that. Help!
  • lance35 Jan 10, 2009
    Sorry about that, I took that back to Wal Mart and bought a Dynex at Best Buy which worked just fine. I'm sure your solution my have worked.
  • Anonymous Jan 21, 2009
    I have the same problem but only on one channel and just sporadically. One day the channel comes in fine and the next day it says signal too weak.
  • Sansui Master
  • 520 Answers
Go into the menu. Go to CHANNEL and press enter. Go to AUTO CH MEMORY and press enter. Press the right arrow on remote to change the signal type to AIR. Go down to AUTOMATIC SEARCH and press enter. Wait for it to finish on its own. You should have all the analog and digital channels you can get with the antenna setup you have connected to the tv.
Posted on Jan 07, 2009
How do I hook an antenna to my tv
Hi Dwayne,
The Proton has an NTSC analog tuner and also an ATSC digital tuner. Have you tried switching or changing the SOURCE inputs?
You may also have to use the scan button to have the tuner "find" the channels for you once you determine that you have selected the correct source for the antenna.
See page 9 of the manual.
http://www.manualslib.com/manual/323457/Protron-Pltv-4250.html?page=17#manual
Jan 18, 2015 | Protron PLTV-4250 42 in. LCD Television
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
Sansui HDLCD1908B Television
call you digital cable provider
Jul 23, 2012 | Sansui HDLCD1908 19 in. LCD TV
Hi. This Sansui 40 inch was working fine with an antenna. The Boy hooked up his playstation 3 and now it doesn't get any channels. Checked all the connections, disconnected the PS3, Tried doing th
You likely need to add an antenna amplifier. The PS3 should have been hooked up to one of the other source inputs other than the antenna. If it was attached via the antenna, a solder connection may have come loose or the coax got kinked.
Feb 20, 2012 | Radio Communications
Hello, Well I have a Jensen antenna( Perfect for HDTV). How do I tune the antenna into a Soniq LCD TV Model E16Z10A. I can only get SBS channels and a few 9 channels. I have done everything! I need your...
I have the same problem with my soniq hd tv i got a digital antenna that plugs into the power and i have also tried the roof antenna and neither worked.. Could it be the tv?
Jan 01, 2011 | Televison & Video
Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
Nov 28, 2009 | Televison & Video
I have digital tv with no signal
If you are accessing ATSC signal with an ATSC tuner, then you need an external antenna with good placement to recieve most channels. You may have to move it around. Be sure the coax cable to antenna is not too long with an un-amplified antenna.
Sep 27, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Sansui 27 inch # DTV2798
Yes. It takes a while to scan for all the channels.
Jul 09, 2008 | Sansui Televison & Video
Sansui 19 in. LCD TV Logo
877 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
