Question about Frigidaire FRT8B5EQ 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Clear Crispers, 2 Sliding Wire Shel...
Frigidaire model #FRT18L4FW3 Where can I get a cheap drain pan?
2 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire, model #FRT18B4AWA Leaking water, drip pan is full
    Has the unit gone into a defrost cycle recently?
    Posted on Aug 03, 2012
    Frigidaire model FRT18L4FW3 how many cubic feet the refrigerator is
    If you want to know the amount in JUST the refrigerator, I don't see it in my reference guide, however, it's usually about 75% of the total.
    Here's the specs that I DO have:
    Frigidaire refrigerator, model FRT18L4FW3, 29.5''W x 30''D x 65.5''H, 18.2 cu ft
    Jan 05, 2018 | Frigidaire Refrigerators
    There is condensation under upright frigidaire freezer model number FFHI7F7HWE . also dripping water on the floor
    There should be a drip pan under fridge to catch the condensation if pan is full it will cause water on floor or if drain line from defrost system could be plugged. Causing moisture to find alternative path.
    Jul 25, 2017 | Frigidaire Refrigerators
    My Frigidaire refrigerator has a drain pan that is un remove able and has a bad smell how can I clean.
    I appreciate your inquiry, friend!
    If you would like to clean any dirt or debris from the drain pain you can use a vacuum attachment to get inside and clean any residue within the drain pan. You can also use warm water and bleach to help disinfect the drain pan prior to vacuuming it out. If that does not help you may want to consult with a professional technician for additional cleaning to be completed within your Frigidaire refrigerator. Best of luck! -Matt
    Oct 19, 2014 | Frigidaire Refrigerators
    Where is the drain hose for a frigidaire model frs23lh5ds9
    Hello mcdh109 - Generally speaking, side by side refrigerators have a drain pan located on the right hand bottom side that in some models it is not removable. The unit does not actually have a drain hose.
    Dec 16, 2012 | Frigidaire FRS6R5EMB Side by Side...
    How do I remove the drain pan to clean it. My freezer is frost free frigidaire upright. The defrost timer went out and some of the food defrosted and drained into the pan and on the floor. There is some...
    On older freezers/refrigerators the drip pan could easily be removed. On newer models its now part of the base frame and their is no way to remove it. Dam shame if ya ask me since it was recommended noraml to remove and clean drain pan every couple months, but hey ain't modern technology great hehehehe
    Gene
    Aug 01, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
    Model # FFU14F9GW.. water pooling under unit
    Greetings,
    If the water is pooling under the bottom drawer. I'd say your drain is clogged..the drain will freeze over from something getting into the drain i.e. food particle....The best thing to do. Is use a hair drier to defrost the drain pan and then make sure your drain runs free by pouring water into it....
    if this is pooling under the refrigerator and out on the floor..There is a drain pan problem..and /or the drain hose going to pan is out of the pan , or has a hole in it...correct as needed
    If this has been helpful in fixing your problem..please leave a testimonial.....thank you
    Dec 12, 2010 | Frigidaire Freezers
    Frigidaire Gallery, model GLRT183TDW0 Water is leaking underneath, and water is collecting in the bottom under the crisper drawers
    Is there a drain hole under the crsper drawers if so see if it is pluged. And leting water to drain to the drain pan under the frig. I hope this will help. Jim
    Oct 27, 2010 | Frigidaire Refrigerators
    Remove Front panel for cleaning. Frigidaire FAC127P1A4 Air conditioner
    Need a part number for a "drain pipe" that would fit in the bottom of the drain pan so I can redirect condensate for Frigidaire Air Conditioner, model FAS257Q2A
    May 11, 2009 | Heating & Cooling
    FRT18L4FW3 Frigidaire Compressor Kicking Off Prematurely
    Sounds like it is either low on gas or it is tripping the internal overload which would mean you need a new comp. Check on warranty
    Dec 29, 2008 | Frigidaire FRT18S6AW Top Freezer...
    Refrigerators Logo
    174 people viewed this question
    Top Frigidaire Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
