Question about Westinghouse LTV-27W2 27 in. HD-Ready LCD Television
Westinghouse LTV-27W2 bad picture?
There seems to be small lines going accross the screen. looks pixely and in groups that form larger lines. on every input. it might go away for a sec then come right back. kinda looks like this. ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: ::: :::
  • kmmk Feb 22, 2008
    I have the same problem and am attempting to replace the display board myself. Unfortunately I can't seem to get the back cover off. How do you removed the back cover from this TV?
  • Anonymous Apr 03, 2008
    i've ordered the main board as well,
    how does the back panel come off?
Thanks all for the information and link to the main board.
i was having the exact problem listed in the first post with dots appearing and multiplying in that pattern and growing until the whole screen was a mess.
I followed the link and purchased the main board with the correct part number. The board was 197 and backordered. one month later, the mainboard appeared at my doorstep. But ran into a problem with the back panel removal.
I removed all of the screws on the back panel and was stuck for a while. With the LCD screen down, I slipped a flathead screwdriver (carefully between the black back panel and the silver frame in the lower corner just above the speaker section. Carefully edging the screwdriver down, you will see the edge of the back panel and the snap tab holding it onto the frame. Angle the flat head underneath the black panel <POP> the back panel literally begins to pop off. Remove screws, ground wires (3) etc... described above... ltv_27w2 back in action!!! Thanks all who contributed.!!!
Posted on Apr 06, 2008
INSTALL IS PRETTY EASY REMOVE BACK COVER OF TV SNAP IT OFF MAIN SIGNAL BOARD IS ABOUT A FOOT LONG AND IS 8 INCHES WIDE THER ARE 4 PLUGS AT TOP AND 2 GROUNDS BOTTOM THERE ARE 4 AND 3 GROUNDS IT IS ON ITS OWN FRAME JUST REMOVE SCREWS AND PLUG IN. THERE ARE 2 BOARDS MAKE SURE YOU GET ONE THAT WORKS USE YOUR SERIAL NUMBER FROM TV WHEN ORDERING
Posted on Oct 03, 2007
Googling comes up with this thread, any links? http://tinyurl.com/2jm2ju 197 bucks anyone have an install guide?
Posted on Sep 19, 2007
MAIN SIGNAL BOARD PART NUMBER 5600110351
Posted on Sep 13, 2007
Hi i have the westinghouse ltv-27w2 it has lines on the screen what internal parts control the picture?
T-CON board, check the connections between the T-CON and the Main LOGIC board first (very rarely to be the logic board but not 100% for sure). Make sure to get the number as printed on the board since there are more than one version. http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LTV-27W2+
Please see my basic troubleshooting guide:
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: try www.shopjimmy.com or Ebay
Jun 25, 2010 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
No picture
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LTV-27W2+
Please post back what you find.
Dec 23, 2009 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
I am having problems with my Westinghouse LTV-32w3 HD TV. If flickers and rolls kind of like the old tube tv used to roll and you would have to adjust it in the back by turning the nob. I have a 37 inch...
The LCD controller is bad, after about on for 30 minutes, see sample here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notee: my pix show the board with the cover removed. You can run the TV with the back open and have s small fan blowing in the back to keep it cool.
You need new LCD controller (there are more than one version, you need to match with the LCD panel): http://www.shopjimmy.com/catalogsearch/result/index/?q=ltv-32w3hd&stock=all
Nov 25, 2009 | Westinghouse LTV-32w3 HD Television
Westinghouse tv has only half of picture on screen
screen driver has failed on the screen, also known as the t-con board this controls the lcd screen, looks to me as its failed and just needs replacing depending on your location price is from £5 upwards in UK just make sure you replace the board with the same board as the original. t-con board is located on the back of the screen under the metal shield with the wires coming out going to the main av board 4 screws and 2- 4 clips on the board connecting the ribbons to the screen itself.
Dec 19, 2017 | Westinghouse LTV-19W3 19 in. LCD...
The TV doesn't turn on and it has a purple light.
MAIN BOARD IS BAD...THERE ARE TWO DIFFERENT MAIN BOARDS FOR THIS TV...IF S/N STARTS WITH W2702...USE P/N 5600110351...IF S/N STARTS WITH W2751...USE P/N 5600110493...PART CAN BE ORDERED FROM ANDREWS ELECTRONICS IN CALIFORNIA..YOU MAY CONSIDER TAKING THE SET TO A LOCAL REPAIR SHOP..
May 29, 2008 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
Mar 06, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Wierd lines?
maybe interf. from cell phone or non magneticualy shielded speakers.
May 24, 2007 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Westinghouse LTV-27W2 27 in. HD-Ready LCD Television Logo
382 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
