Question about Creative Labs ZEN V Plus MP3 Player
Trouble my zen will not charge or turn on; occasionally it will switch on for a second and charge then immediately show a triangle with a yellow exclamation mark and go off again! please help!
  • 827 Answers
To resolve this problem, establish that the player is charging correctly as follows:
  1. Connect the player to a USB port on the back of a desktop PC, to a powered hub, or to a power adapter (separately available).
  2. Check the display for the charging icon trouble - battery_ac_charge_1.jpg.
    • As the display times out after a few seconds, press any button on the player to reactivate the display.
    • If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
  3. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging.
If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
Creative recommends updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Posted on Jan 09, 2009
What does a bright orange triangle( with a ! in the middle of it),mean when tablet will not on ?
Thread: Android bot laying down with exclamation mark - Asus ...
www.transformerforums.com > ... > Asus Transformer (TF101) Help
Apr 7, 2012 - 10 posts - ‎5 authors
Hello: With the tablet powered off I press down "- volume button" and ... Guys - you can only do a cold boot or factory reset through the .... No worries I've sounded grumpy occasionally myself - even big, bright, yellow, grinning me ... dead android with redtriangle ... what does an android avatar laid out mean.
Warning triangle and thermometer on charge s... ' Samsung Galaxy S ...
forum.xda-developers.com/.../warning-triangle-thermometer-charge-t15...
Apr 13, 2012 - 5 posts - ‎4 authors
I also can't turn the phone on unless I go to Recovery and reboot the system that way.Does anyone know what this means? Thanks.
Jan 19, 2016 | Tablets & eReaders
When I try to charge my samsung galaxy tablet a yellow triangle pops up on the battery sign
I had this same thing. The Batter image had a red line on the right side and the yellow triangle had an explanation point in the middle.
I searched the net and found a few solutions.
1. Hold the power button down for 30 seconds.
2. Hold the power button down and the volume down button at the same time for 30 seconds.
3. Just let it charge and over night and it should go back to normal.
I did all 3, in the order I wrote them. While in step 3, after about 5 minutes I pressed the power button and it showed that it was charging normal.
Hope this helps.
Dec 04, 2012 | Samsung Galaxy Tab Tablet PC
Hello After downloading a supposed updated software to my creative Zen V PLUS 2Gb, It doesn't start anymore! After "CREATIVE" and "ZEN v plus" usual display, it shows yellow triangle and "firmware Problem"...
it seems that ur firmware is interrupted while installation or corrupted while installation.make sure the version is for ur device,then try to update it again.
if this doesnt work try to get an old version of the update
Mar 29, 2010 | Creative Labs ZEN V Plus MP3 Player
Mp3 player will not turn on, it is fully charged
First try resetting it = To reset your zen = Put a pen head in the hole under the power button for 20 seconds.
A depleted battery may have any of the following symptoms:
The charging icon is missing
The blue power LED is not blinking
The player turns off immediately when it is disconnected from its power supply
Not showing any signs of activity (with the exception of the blue power LED)
No LCD display
The player is not detected by Windows or any programs
If the player shows the above symptoms, download the firmware below and follow the step by step instructions to install the firmware update.
http://www.creative.com/support / downloads, firmware.
May have to format if nothing eles works.
http://www.creative.com/support/ downloads
Jul 29, 2009 | Creative Labs ZEN Stone MP3 Player
I have a yellow triangler light showing while the car is running
I suspect that yellow triangle lamp is your emergency flasher switch. If you were to press the switch (triangle) you would find the flashers start working and if you press it again they would stop.
Jan 11, 2009 | 2006 Volkswagen Passat
CREATIVE ZEN V-PLUS. COULD NOT TURN ON AND IS NOT CHARGING
my vision m wont charge. and i just tried to click that button and pluged it back in and its still not working :''''''[
Aug 01, 2008 | Creative Labs Zen Stone Plus MP3 Player
Try using the reset botton while connected to the computer via usb cable , it worked for me.
Jul 24, 2008 | Creative Labs ZEN V Plus MP3 Player
How to charge my creative zen mp3 player
Just connect your Zen onto your PC (NOT LAP TOP) on a USB.
If does not start charging (you´ll see arrow and pause/ play buttons flashing slowly) then you need to RESET your ZEN.
How to reset: You´ll find a tiny little hole by on/off button on the side. With ZEN connected to the PC USB or onto wall charger try turning ZEN on, it doesen´t matter if it turns on or not. Then insert a sowing pin or office paper clip end in this reset hole for a few seconds and release. Give it a couple of seconds and see the lights go off onto charging mode. LEAVE IT CHARGING for 24 hours. Make sure your PC will NOT turn itself on safe mode or hibernates in this period, it has to be ON for charging, at all times.
This is it.
Louise Passalacqua.
Jul 08, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative vision M 30 gig not working.
In Australia is 220v the standard? This player might be a 5V, US-market version. Transformer would be required.
If the voltage checks out, however, I would try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Apr 25, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen mp3 player
Its possible that the battery just needs to be charged. Also make sure you are holding down the on off slider for about six seconds, it won't turn on if you only hold it down for a second or two.
Apr 09, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
83 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
