Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman door opener jumps and drags
THe opener seems like it is in a bind or is dragging, making it open roughly sometimes reopening before it completley closes
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
If you have a Chraftsman/Liftmaster:
1.Check to see if the door is running correctly.
A. Run the door down and pull the emergency release. See if the door will run easily by itself.
1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40) And be sure you lubricate the rial and the chain on the operator
2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
B. If the door runs fine then check the up and down force on your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
C. If this does not solve your problem the top bushing could be going out of your operator. Open the case and see if a lot of black filings are on the top of the big gear. If so the gear assy. will have to be replaced part # 41C4220A
Posted on Jan 06, 2009
My compressor comes on for a few seconds, makes a slight humming sound, then quits altogether; any suggestions?
The only thing I can think of is that something is DRAGGING or binding, which "overloads" the motor, and thus causes the thermal overload safety switch [inside the motor] to "open" thus PROTECTING the motor from overheat damage.
The only fix for this is to find, AND ELIMINATE, the drag or bind!!!!!
Jan 16, 2015 | Campbell Hausfeld Extreme Contractor...
Door only opens 6in
There should be 2 or 3 knobs/screws on the side to adjust torque to lift and to let down the door. Sounds like you need to increase the lift torque setting. If its maxed you can try greasing the rollers/wheels to help remove the drag. If still does not lift it then you may need a bigger motor (1hp) or you can add some springs to help lift it. Check your sensors too. Make sure they aren't being tripped at 6" up.
Apr 20, 2014 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 18.5hp new battery new solenoid will only crank one revalution then quit what next?
It could be several things !! well not the battry !! you can check that out from the list !! sounds like the starter is dragging, you can try to jump it off with a screw driver turn the key on and touch the two srews on the solenoid becareful cause its going to spark a little , check to see if it still drags or it fires right up !? if it drags and turns slow than its most likley your starter ,check and see if the starter geting real hot also ? thats one of the signs that its going out also ,
Feb 14, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When i use the keypad or internal button to close my garage it will begin to close then immediately reopen. The sensors are clear and nothing is causing the door to stop closing and reopen. What do you...
make sure the sensors are properly aligned. disconnect the opener with the saftey release and operate the door manually. be sure the door opens and closes reasonably easy by hand. If not, check for binding or broken springs or torsion springs
Oct 14, 2010 | Garden
I have Craftsman ½ HP Garage Door Opener Model 139.18458D. It reopens immediately after closing. Sometimes it works normally, and sometimes gives this problem. I have tried adjusting the close force,...
It sounds like the door is traveling too far in the down direction. When it hits the floor the safety causes it to reverse to the open position. You need to adjust the 'down limit' not the force.
Sep 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Snowboard boots with reduced length
You may also want to look at how you are setting up your bindings. I have a US 11 foot (29 cm) and with my bindings set correctly have never had any issues with toe or heal drag.
The best way to set up your bindings it to take them off, remove the mounting screws, keep the base plates in and fit your boots into your bindings with the straps still undone. Then, with the board on the floor, position the binding at the angle you like (roughly) and look to see when the toe and heel over lap is even or if you are like me pull the bindings back slightly so that you have little or no toe drag and just little heel drag. It works a treat and I have done this for over a hundred customers over the years.
Mar 15, 2010 | Burton Boxer Snowboard Boots
Two identical Sears doors jump about 6 to 8 inches up when opener button pressed. Periodically doors will stop at that point, need to be closed and then reopened to operate properly. Have tried adjusting...
It sounds like the door springs may be mis-adjusted. Release the doors from the opener and try raising and lowering them manually. They should not try to rise on their own.
Jul 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door chain is sagging
If the chain is adjusted properly the chain will sag slightly on one side when the door is closed and on the other side when it is open. It should not sag enough that it is dragging on the T-rail. You can adjust it at the trolley. If you over tighten it you will hear a clicking sound when the opener opens or closes.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Freezer door opens When you close refir. door
The freezer door is relatively light weight, and when the fresh foods door closes, the air has to go somewhere and the easiest escape route is to momentarily pop the freezer door open. The door should close again quickly. If is does not, make sure the freezer door liner is not touching the top or bottom, causing dragging resistance, and make sure that the front leveling legs are raised up so the door closes by it's self when released from a 45 degree opening. Sometimes the hinge side gasket rubs and holds things up also, especially if that area was cleaned. If that is the case, rub a film of wax on the hinge side gasket to lubricate it. Additional weight in the freezer door will also help.
Oct 27, 2008 | GE Profile Arctica Stainless Steel Top...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
78 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
