Question about Toshiba 42HL167 42 in. LCD Television
No sound on my Toshiba Regza 42HL167
The tv is about 1 1/2 yrs old bought brand new. It was working fine last night, but when I came home & turned it on tonight, there is no sound. I jiggled all the cables, lightly tapped the back and even connected my pc to see if maybe it was the cable tv, but no sound that way either. I've checked the audio settings on both the cable tv and the tv but I don't see any changes help!!
  • noripoo Jan 06, 2009
    nevermind...I think it's the HDMI cable. Thanks.
    President:
  • 814 Answers
Found this troubleshooting method on the www.Toshiba.com website. Q. My TV has a picture, but there is no audio?
Models: 20DL77, 20HLK67, 26HL47, 32HL17, 37HL17, 42HL17, 26HL37, 32HL37, 20HL67, 26HL67, 32HL67, 37HL67,
42HL167, 42HL67, 47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00128
1. Please check your connections and make sure if you are using COMPOSITE “yellow, white, and red cables”, SVIDEO,
with “white, and red” or Color Stream COMPONENT “green, blue, red, white and red cables,” that the white
and red cables which are used for audio are plugged in securely into the same inputs as the video.
If your connections are secure, the station may have broadcast difficulties. Try a different channel.
2. If you are using the coax cable from the wall, press the “ENTER” button on the middle of the remote. If the
information provided shows that you have SAP selected we will need to change it to STEREO or MONO. To do
this, we will need to press the “MENU” button, and use the RIGHT or LEFT arrow keys to highlight the AUDIO
menu. Next we will need to use the DOWN arrow to select AUDIO SETUP press “ENTER” and then arrow down to
MTS and use the RIGHT arrow to select stereo.
3. If you have a cable box or satellite receiver, please make sure the TV’s volume, as well as the box’s, volume is
turned up sufficiently.
4. The station may have broadcast difficulties. Try another channel.
5. The sound may be muted. Press VOLUME.
6. If you still have problems after following these steps please contact Customer Solutions at 1800-631-3811 Monday
through Friday 8am to 7pm CST. The Toshiba customer service number is 1-800-631-3811. I hope this helps you with your problem.
Posted on May 17, 2009
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
I bought a brand new xbox 369 last night. i also bought a brand new 32" flatscreen emerson le320em3. is this tv not compatible with an xbox 360? i was able to get the tv hooked up to cable and the...
Your problem is in the TV. I'm not familiar with your TV, but you should look for an option to turn it to normal or to try and scan for channels with xbox plugged in and running. I'm pretty sure that if you get HDMI cable, your problem should be solved.
Feb 06, 2013 | Video Game Consoles & Games
Colour separating on screen
Sounds like a Convergence problem----see attached photos---if so provide model and brand and I will offer suggestions/solution for you--also indicate your skill level?
Dec 03, 2012 | Televison & Video
Hi i have an isis tv and have lost the manual to it. I can not get the tv to switch on, every time i turn the power on and try and use the remote to turn it on nothing happens and the led red light on the...
Hi can anyone please help me a have a isis tv only a year old was working fine last night aye want to put it on tonight and the red light flashes for a bit than comes on but no sound or picture what could it be the scream is just dark
Sep 13, 2011 | Televison & Video
Sharp flat tv lc-32sb24u no audio was watching tv last night and the sound just stopped in the middle of a show. picture is perfect. is it worth to fix.
Sir try to check the cables connection at the back of your tv. and if you are using a digital receiver, try to use a dvd to check if there is a sound. If there is a sound the problem is the digital receiver, feel free to send feed back good day and best regards.
Aug 16, 2011 | Sharp LC-32SB24U 32 in. LCD TV
I have a Dynex DX-LCD32-09 TV it was fine last night when I turned it off. When I turned it on today it showed the channel number then the screen went black but I have sound on all channels. Is there a...
LCD tvs come with a florecent tube that projects light through the LCD screen like a stained glass window. It can be replaced if you take it to a repair shop that can order the parts. Given that it works and then turns off would obviously mean the bulb is working, the power is just getting cut to it at some point. This will complicate the repair considerably. I would just replace it, personally. By the time the diagnostic fee and the parts+ labor is done, you might as well just pay a little bit more for a brand new tv with better features and a new warranty.
May 25, 2011 | Dynex DX-LCD32-09 LCD TV
My 27" Hitachi TV is about 14-15 yrs. Last night
could be alot of things but it comes on by hitting it makes me think either a bad relay or solder connection on the pcb board
Jan 29, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Red power light flashes. tv won't turn on.
how old is your tv?? ours was 2 1/2 yrs old it was a 40in lg hd ready lcd tv it just crackled and turned off one night same as yours it would turn on but with no picture or sound....we took it for repair and they said it was something inside that is basically impossible to fix...it would have cost more that the tv itself. BUT trading standards say a brand new tv should last upto 3yrs...you need to get a free qoute nd if they cant fix it contact trading standards and the tv MANUFACTURER not the shop where you got it....you NEED a reciept to do this for proof of when you purchased it...hope this helps :0)
Jun 29, 2009 | Televison & Video
Power Issue 42" plasma flat HDTV Pixel Plus
you ip board is bad go t0 this site partstore.com typ in the modle of tv and buy it . works like brand new .trust mr it did and saved a lot
Apr 07, 2009 | Samsung SPN4235 42 in. Plasma HDTV
JVC i art 32" flat screen
Does anyone know where can I buy a screen for a 27" LCD Insignia TV. Model is NS-27LCD? My screen creaked. I checked out e-bay and have not found a broken TV with a good screen. Does anyone know where I can buy a screen at.
Thank you all for you time.
JC
Jul 22, 2008 | Televison & Video
Toshiba 42HL167 42 in. LCD Television Logo
4,415 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
