MY PRINTER STATUS SAYS ERROR AND WON'T PRINT ANYTHING
I HAE THE HP OFFICEJET PR L7580 SERIES
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
My hp officejet pro L7580 is connected to DOT4 port, there's a hp officejet pro L7580fax connected to USB002. I want officejet pro L7580 connected to USB002, NOT the L7580fax. My desktop is not...
To walk you through I'd need to know the OS you are running, but the generic answer is that you need to go into the print driver, and in the Printer Properties, under the ports tab , select the USB002 port rather than the DOT4 port and Apply the changes.
Mar 18, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
The following printhead has a problem black yellow k y
I have brand new print head and saids that there is a problem with the printer head and will not print nothing the black will not go to the print head need code to over ride and print something in black and white I've tried to shut it down and restarted for 30 sec. and for 15 min's did not work keeps coming up that there's a problem with the printer head model #C8187A-013 serial # MY76553H2 series Officejet Pro L7580 All-in-One email: robertcforce@gmail.com
Nov 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
How do you track and view the print count for the HP Officejet Pro L7580
Press the setup button, scroll down to print reports, and print the self test print, it has the print count as well as the serial number other printer data.
Feb 08, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Hp officejet pro l7580 won't print
Try this. Go to WWW.hp.com and let the website find your printer and install the sotware automatically.
Jun 20, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet pro l7580 magenta won't print, new HP cartridge 8/11
You will have to reset the printer.If you want any further support, a technician from techbuddies can help you for free.For this log on to www.techbuddies.org
Jun 18, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
"Door Open" error message
check all the doors of the printer. If they are not closed, The printer will continue to throw this error.
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
My HP Officejet Pro L7580 prints one page and then stops
TRY WITH WHETHER THE PRINTER CONNECTED PROPERLY AND UPDATE IS NOT PROPER
Nov 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
2,204 people viewed this question
jasbo
jasbo
