Question about HP Photosmart 8450 InkJet Printer
HP Photosmart 8450 Paper Feed Issue
It seems like oneof thethree rollers isnt advancing the paper. Has anyone seen this issue? I have taken theprinter apart and found no jammed paper. Please let me know if you have any ideas on this.
Thanks
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 27, 2009
HP P3015N tray two paper pickup issue
Issue is worn out feed rollers. There are three. One in the tray itself and two after you remove the tray. Look up into the printer from where you removed the tray and replace those two rollers
Jan 09, 2013 | HP LaserJet Enterprise P3015d BW laser...
The paper doesn't want to feed when I print.
I have a HP3210 and it would not feed photo paper (HP brand) and I put a small amount of the fingertip moistener (the same type of stuff a bank teller uses to count bills) on the two feed rollers that are seen from the back of the printer and it seems to have solved the problem. The product used is SortKwik, and it was purchased at Office Depot. HP service reps were of no help and did not seem to care..their only solution was to buy a new printer!
Jun 09, 2010 | HP Photosmart 3210 Printer
It seems that the rollers won't advance the paper. The error message of course tells me that it is out of paper. I haven't used it in over one year, could that have something to do with the problem?
Things to try are listed in this support document from HP: (recommend cleaning the rollers #4)
HP Photosmart C6280 Out of Paper
Lack of use could be a factor as it pertains to dust buildup on the working parts of the feed, especially the rollers.
Jan 05, 2010 | HP Photosmart C6280 Printer
Paper feed is feeding too many pages at once
First make sure you are using the right weight paper. On the package it will tell you what weight it is...ie: 20lb, if the paper is the acceptable weight for your particular printer then it is probably the pickup rollers. Depending on the price of your printer (if it is an inexpensive one) you may want to consider just replacing it, due to the difficulty of replacing rollers on many printers if they are even replaceable.
Aug 11, 2009 | HP Photosmart 8450 InkJet Printer
With HP Photosmart D7260 Printer, I get "out of paper" error, paper tray full, feed rollers leave skid marks on paper" I have tried other paper (HP Premium Ink Jet paper, Avery namecard stock, HP Premium...
Perhaps you are loading too much paper into the tray. Please try to work through the steps in this troubleshooter and see if it has any effect. If not, please report back with the results and someone will be happy to assist you.
HP OOPaper
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 02, 2009 | HP Photosmart D7260 Printer
Printer will not grab paper
Check to make sure the paper sensor tab moves freely. You might try air dusting around the paper pick-up rollers to make sure the area is free from any accumulation of dust, dirt, or paper residue.
Nov 19, 2008 | Office Equipment & Supplies
Loading A5 paper into photosmart 8450
your printer is capable of accepting a5, load the paper on a different direction, with the leading edge 5.83" feed first, then properly aligned the side guides to match your paper this will surely work this time, then slect a5 on your printing properties on your pc
cheers
Sep 27, 2008 | HP Photosmart 8450 InkJet Printer
Paper feed jams
try to clean the rollers of the ADF at the same time the separator pad of the ADF.some the issues why this will encounter jam because of the dirty rollers.but if the issue is occuring you need to SERVICE the product
HP TECH support
Aug 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
Error Message Out of paper
Contact hp. They have a small item (roller clelaner) that you insert it into the printer as if it were paper and it seems to clean up your rollers. It takes about 15 minutes and it works. I also had the same problem and this solved the issue.
Apr 16, 2008 | HP Photosmart 3210 All-In-One InkJet...
Jam problem
Well, the issue seems to be with Printer carriage stall or it could be an issue with Paper feed rollers or with Communication issue between Computer and Printer.
Please open below web link and try the steps that are mentioned in the web page.
http://tinyurl.com/3xyaq9
I hope that this should resolve the issue for you.
Bye.
Oct 15, 2007 | HP PhotoSmart C4180 All-in-One Color...
HP Photosmart 8450 InkJet Printer Logo
180 people viewed this question
Ben Johnson
