Question about Samsung ML 2010 Laser Printer
Maybe you can help me with my printer error
Hi, I've posted this problem before but no answer yet, maybe you can help me. I need to print from a Visual Fox system to a shared Samsung ML-2010 printer. By default in the printer configuration the printer processor is RAW, but the printer blinks (like receiving data) and doesn't start any printing. If I change the printer processor to TEXT the printer does print but it doesn't recognize the especial characters like line feed, carriage return, etc. The same system works fine with HP printers with RAW printer processor, I don't know why it doesn't work with this Samsung printer. I've installed the latest driver from the vendor but it remains the same. Thanks a lot for your help
  • Alvaro Iniguez May 31, 2007
    I'm sorry I didn't see the response before. Thanks a lot for your solution. The document is not a complex one (only text) but I will try to print a smaller one, just to see if it's something related to the memory. If I find the solution I will post it here
    Scholar:
  • 77 Answers
I'm not familiar with your Visual Fox system, but from your description it sounds like you are exceeding the printer's memory. Your model only has 8MB RAM and is NOT expandable. Even if your document is less than 8MB, the printer has a lot of overhead it has to deal with. Some printers make better use of memory than others. Your HP printers probably have more memory and/or a better scheme for handling it. You might want to try a VERY small document to see if it prints. I know this doesn't FIX your problem, but hopefully it will help solve the mystery. Ed
Posted on May 26, 2007
  • Edward Paulinski May 31, 2007
    Thank you for your vote of confidence. I quit
White lines on dark photo prints
White lines means some of the print head nozzles maybe blocked.
Try the deep clean print head cycles then do a test print. If this still does not fix the problem then a new print head is required.
Print heads are expensive and if your printer is old then maybe better to put your money towards a new printer.
Oct 18, 2012 | Canon MP560 All-In-One InkJet Printer
Epson Stylus Photo R800 not printing certain color
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 15, 2012 | Epson Stylus Photo R800 InkJet Printer
After working for years, my HP All-in-One Printer stopped printing jobs suddenly, giving me an "incompatible black ink cartridge" message on the computer & an error light on the printer;...
sometimes they just defect and burn out.. place and old/empty/dry one if you have, if the error disappear you now that your cartridge just failed and you need new one.
Sep 20, 2011 | HP PSC 1315 All-In-One InkJet Printer
I have an HP 1022 printer. Recently I am unable to print. When I try to print there is a rattling noise. I've checked the paper feeder and didn't note anything loose.
This can be caused by a bad driver or the printer itself is going bad. But eitherway, you should get an error message either from the printer or from the computer where you are trying to print. Post the error here. We will be more than happy to post the resolution.
Hope this helps.
Jun 24, 2011 | Office Equipment & Supplies
When i print any photo it can't print error show E3
hi, look at this post maybe can solved your problem not all Error E3 means your printer part damage but maybe somethings inside it that makes the printer look likes paper jam,
Canon MP198 Printer Error E3 is because something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things.
Look at the paper sensor there is must be somethings in it. I found this when my printer Canon MP198 got error E3. I found small part of paper in the sensor that makes sensor not function properly. I just remove the paper and the printer working again.
see also
http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html
Nov 18, 2010 | Canon Office Equipment & Supplies
Print cartridge error
hi..
try to install and reinstall the cartridge to the printer...
maybe there is a loss connection between the printer and cartridge..
and also clean the tab circuit of the cartridge..and the tab circuit printer carrier where the cartridge is installed....^_^
if the problem still exist try to replace the tanks of the cartridge maybe the tanks was not recognized by the printer...
May 12, 2009 | HP Officejet 5510xi Printer
Cant print in ms word 2008
Hi
Can you access the printer settngs from microsoft? when you click on Print. does it give you option to select the printer that you are using? try reinstalling microsoft office as well...
Keep me posted
Dec 09, 2008 | Epson R245 InkJet Photo Printer
Problems with hp laserjet 3330
hi,
i think you need to replace the fan of your printer cause maybe they reach temperature level that's why you experiencing that error...
Oct 08, 2008 | HP LaserJet 3330 All-In-One Printer
Samsung ML 2010 Laser Printer Logo
67 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
