Question about Bose 901 VI Main / Stereo Speaker
Connecting Bose 901 series iv to Harman Kardon AVR 254
Exactly which input jacks of the AVR 254 should be used for the equalizer amplifier output and input?
    Brigadier General:
  • 8,546 Answers
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
Posted on Nov 30, 2009
    Problem Solver:
  • 9 Answers
Most HK av receivers have pre amp out,power amp in with metal jumpers connecting them for the main or front channels. that would be the best place to hook up the EQ on a AV receiver. If your receiver doesn't have pre out, power in jacks , you can use tape monitor .record out playback in. The tape monitor option is best for stereo use , as the active EQ will charge all speakers in tape mode, possibly damaging other speakers.I run my 901 s with a seperate pre-amp,power-amp hooked up to my Denon AV receiver that way i can run in surround w/standard speakers
Posted on Jan 07, 2009
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    How do I connect my bose equalizer to my pioneer amplifier
    The manual is at Bose.com.
    In any question regarding connections the exact models of all parts in the scenario should be defined.
    "Pioneer amplifier" is not unique nor revealing. Integrated amplifer? Power amp? Tape Loops available? Pre-Outs? What's involved as a preamp?
    The key thing to know is that any amplifier channels driving 901's must not drive other speakers as the Active EQ severely modifies the Line Level source input. If the EQ (or any sound processor) is used in a Tape Loop on a modern multichannel digital-audio-capable AVR, ONLY 2-channel analog sources will function when the Tape Loop is engaged; and all downstream speakers will be affected by the processing. That's par for the AVR course.
    Bose 901 use in multichannel applications (which I have) will require access to Pre-Amp outputs for the chosen channels (likely the Front) and you will need to get a separate amp for the 901's, placing the EQ in series with the chosen amplifier. I currently drive mine with a Carver MT-200T.
    Sep 20, 2011 | Bose 901 EQ1915 Home Equalizer
    Im having problems installing my equallizer i have it hooked up to a amp. do i put the jacks to the 4 inputs or the 2 outsput jacks
    Hi, the equalizer input is from the head unit preamp outputs and the equalizer output goes to the input jacks of the amp. There should be only 2 channels in and 2 (or sometimes 4) out of the equalizer. If you need more help, please provide model numbers of the head unit, equalizer, and amplifier and tell me all of the speakers you are trying to hook up.
    Mar 26, 2011 | Car Audio & Video
    How can i conect my amplifier with equalizer
    I don't know what equalizer you have but, from the head unit RCA output to the equalizer RCA input and then from the equalizer RCA output to the amplifier RCA input. Hope this helps. Without knowing which EQ you are using thats the best I can do. dreamsystems.
    Feb 16, 2011 | Kenwood KAC-8401 Car Audio Amplifier
    I have a Pioneer PL-S50 turntable that I want to connect
    hi you need a Phono Input Attenuator Line Adapter
    the above link is for one on ebay but they are also available through radio shack
    Jan 06, 2010 | Denon AVR-689 Receiver
    I would like to hook-up amp to graphic equalizer i would like picture if possible.
    An EQ (equalizer) is generally connected between the low level output of a device (phono, CD, DVD, etc.,) and the amplifier's input. If you choose to place the EQ at this point, only the device connected will be equalized. All the other sources will be unaltered.
    A more complete way is as follows:
    Some amplifiers have a jacks labeled Left & Right "PRE OUT" and Left & Right "AMP IN" with a heavy gauge wire or strap that connects the left AMP IN & left PRE OUT together; and the right AMP IN and right PRE OUT together. Removal of the wire or strap will cause the amp to fall silent, as the low level signal no longer has a path from the PRE OUT to the AMP IN jacks. If you were to insert the EQ here, the path would be restored - but allowing you to boost or cut the level of certain frequencies BEFORE they are amplified. This is accomplished by connecting PRE OUT to EQ IN and EQ OUT to AMP IN for both the left and right channels.
    As I mentioned, only some amps have these PRE OUT and AMP IN jacks - many however do not. In this case, you may be able to use the TAPE MON jacks. The TAPE MON is the Tape Monitor and appears on most "half-way decent" receivers. These jacks were provided to enable listening to a tape in nearly "real time" as it was being recorded on higher end "3 head" tape recorders. If you don't have a "3 head" tape deck (most do not), you can use these jacks the same as the PRE OUT and AMP IN jacks above. This is accomplished by connecting the TAPE OUT to EQ IN and the EQ OUT to the TAPE IN for both the left and right jacks. You would then select the source of the music - be it CD, Phono, etc. and with the EQ powered, pressing the TAPE MON button on the receiver, you could hear the difference between the EQ in the circuit and the EQ out of the circuit.
    The key in the examples above is that there is always an input connected to an output. Don't connect inputs to inputs and outputs to outputs. Take your time and work one cable at a time - one end to an input and the other to the corresponding output.
    Some situations may arise if using Dolby Digital, THX, etc. type input signals. Sometimes it is not possible to equalize them. If you have sources (DVD, Satellite Receivers, etc.) that have an optical or coaxial connection, those will be the ones that may have undesired affects. The familiar RCA type jacks for left and right signals should work perfectly.
    I'll see if I can find a link with a picture...
    Sep 29, 2009 | Audio Players & Recorders
    Power Acoustik PWM-16 Equalizer Help
    You should be able to use your RCA output (Line Out) from your Pioneer to the input of your PWM-16. Then take the PMW output to an amplifier and then to your speakers. Your EQ only uses RCA's so an amplifier after
    it would really bring the sound to life. The amp need not be huge as you have an output for subs also. You could try a line converter to change the RCA lines to speaker wire connections. Not sure if the output would be enough to power a speaker but it's worth a try.
    Sep 28, 2009 | Power Acoustik PWM-16 Car Audio Amplifier
    How to connect phono leads
    1. Step 1 Check the back of your Stereo for recording input(in) and output (out), your cassette deck may be plugged into these jacks.
    2. Step 2 Connect the RCA/Phono wires to your equalizer's input and output jacks on the back.
    3. Step 3 If your cassette deck or some other component is plugged into the recording jacks in the back of your amplifier, unplug it and plug it into the back of the equalizer under monitor jacks. Be sure that the "out" from the cassette deck goes to the "in" of the equalizer.
    4. Step 4 Now, take the wires from the equalizer and plug them into the amplifier in the same manner: "in" to "out" and visa versa.
    5. Step 5 Once all your wires are connected be sure the "tape monitor button" on the amplifier is on. Turning it off will disable the equalizer. You can still monitor your recording devise or cassette deck by the "monitor switch" on the equalizer.
    Mar 12, 2009 | Audio Players & Recorders
    I have Pioneer Amplifier with Phono Inputs. Also I have an Akai stereo Equalizer. I want to connect my Turntable to the pioneer amplifier through Akai stereo Equalizer to have a better sound quality. Is it...
    hook the turntable "directly" up to the "phono" inputs. if it sounds normal this way, and not loud and distorted, then you have to plug the turntable up that way, directly to the reciever's phono input.
    you can hook the eq up through the "tape in/out" jacks.
    take the tape record out jacks, and hook them up to the input of the eq, and take the tape play input jacks and hook them up to the output of the eq. then, to use toe eq, select whatever input you want eq'ed, while also selecting "tape monitor"
    Mar 07, 2009 | Kenwood Audio Players & Recorders
    HOOK-UP
    get your output from auxiliary output jacks of(karaoke machine)and connect it to equalizer- and connect equalizer output to input of surround sound system.
    Dec 30, 2007 | Audio Players & Recorders
    Bose 901 VI Main / Stereo Speaker Logo
    849 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Electro Med Services...
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
