Question about Brother DCP-110C All-In-One InkJet Printer
Does not print in black.
The printer will just send a blank paper through unless there is color to
print and it will use the blue, red and yellow. I have replaced the black cartridge but that did not help. I will not even print a test page.
  • 1 more comment
  • Anonymous Jan 29, 2009
    Ich habe einen Brother DCP 115C.
    Nach Wechsel der Druckerpatronen (sind alle im Statuts Monitor bereit und
    zu erkennen) zeigt der Drucker folgendes an:
    Chapter in Users´s Guide Trobleshooting and routine meintenance.
    Was immer das heißt, weiß ich nicht, da ich keine Englisch-Kenntnisse
    besitze.
    Können Sie mir helfen?
    Vielen Dank
    Ursula Jarchow
  • juliabatley Mar 07, 2009
    black does not print ive cleaned till i ran out of blk ink, then replaced, still does not print in blk col fine.
  • AKAM Apr 11, 2009
    I have MFC-210C and it prints all colors just fine but nothing in black. I have tested the color by test printing and cleaning several times but to no avail. Please help.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
Red and blue tint
Often "grayscale" is achieved by mixing some of your colors (CYM) to form composite black and gray - not necessarily just black from your black cartridge. Often there is some yellow used beneath the black -- so if you are getting a red or blue tint, it could mean something as simple as being low on yellow ink.
Jan 26, 2014 | Office Equipment & Supplies
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Just wondering: my printer's yellow and black toner are both empty and need replacing. Would this cause the printer to calibrate for minutes at a time? After calibrating, I tried printing a document with...
If your going to print in color may it be just red or blue. You really need all of the cartridges for it to work. Because for the printer to come up with those colors. It would need all three colors Cyan, Magenta and Yellow to come up with the any color, in your problem, Blue and Red.
Feb 04, 2011 | Dell 3100cn Laser Printer
I have HP Deskjet D2466 Printer and when i want to print with color cartridge, the black color would be printed as blue color... My black cartridge was exhausted so i only can printed with color...
when the color cartridge has to make black, it uses all three colors. printing blue indicates that the color cart. is getting low on red and yellow. get a new black cart. and a new color, 'cause it' s coming due.
Let me know
May 18, 2010 | Office Equipment & Supplies
Only prints in green and blue
You are more than likely out of magenta (red) ink. That printer uses a tri-color cartridge, and it has cyan (blue) magenta (red) and yellow ink. Green is blue + yellow-therefore you do have those two colors; since it will not print anything red or black you will need to replace both cartridges.
Mar 05, 2010 | Dell 810 All-In-One InkJet Printer
Refilled pixma MP210 color cartridge. Now my printer will not print any color at all, only black
Maybe your printer cartridge that has been refilled got ink clogged. You can bring it to the store where you can let them clean it for you. It must be free for cleaning since it was refilled from them. Hope this help.
You can also clean your cartridge by following my instructions below:
BEFORE DOING BELOW INSTRUCTIONS,TRY TO CLEAN YOU CARTRIDGE FIRST USING THE DEEP CLEAN FEATURE OF YOUR PRINTER, THEN USE PRINT NOOZLE CHECK PATTERN.
1. Uninstall your cartridge.
2. Get a tissue paper.
3. Try to put the printer head over a small piece of tissue paper.
If you will see the three colors in the tissue(Cyan-close to blue, Magenta-close to red, and Yellow). It means it was not clogged, the problem is the chip of your color cartridge and needs to be replaced. But if the colors are blur and or nothing appears, it means the printhead of your cartridge is clog. You can proceed to step 4.
4. Try to put a little amount of water in a small piece of tissue paper and soak the printer head for a 2 min. Then remove it after.
5. Wipe the printer head with a dry tissue paper.
6. Reinstall the cartridge back to the printer.
7. Print a 4 basic colors, RED, BLUE, YELLOW and BLACK.
8. Clean the printer using the cleaning feature of your printer.
9. You can use deep cleaning twice. And Print a noozle print.
10. Hope it could help.
Dec 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
MISSING COLOR IN MY PRINTS
try a test page first and see what that does
Aug 08, 2008 | Epson Stylus C46 InkJet Printer
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Brother DCP-110C All-In-One InkJet Printer Logo
169 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
