You need to push harder in the pinhole, and do it while the power is off. That pinhole goes directly to a gear. If the gear is stuck and will not turn at all the drive will have to be disassembled to recover the cd.
CD-ROM, DVD, or other disc tray not opening
Locking device or software installed
First, verify no locking software installed that prevents the tray from opening. If you are unsure, reboot the computer and as it is booting up, eject the tray. If the tray can eject as it is booting, but stops working after loading your operating system, something is being loaded that is preventing the drive tray from opening. Programs used to burn CDs are a common culprit.
Bad eject button
If you are running Microsoft Windows, open My computer, right-click the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective, and it is recommended that the drive be replaced.
No power to computer or disc drive
If you have recently installed a new optical drive or you have moved the computer, the power cable to the CD-ROM may have become loose or disconnected. Reseat the power cable to make sure this is not the problem.
CD stuck within drive
If you suspect that a CD may be stuck within the drive, the tray needs to be ejected manually. Look for the small manual eject hole that ( not the head phone jack) located on the front of the drive. Unwind a paper clip and place one end of the paper clip into the hole to eject the CD-ROM tray.
If CD-ROM tray opens part of the way, pull it gently to see if you can get it to open fully. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become damaged or dislodged. But usually, a stuck CD is blocking the way.
Caution: If you are able to open the CD-ROM drive using a paper clip, we do not recommend continuing to do so. This is meant to be used as a temporary solution; the drive should be replaced.
What to do if CD or DVD stuck in drive?
Note: This document is for disc drives with a disc in the drive that prevents the tray from opening. See our CD-ROM, DVD, or other disc tray not opening document, if the tray is not opening at all or doesn't seem to be getting power.
If the CD or DVD is not set into the disc tray correctly, it could be sticking up above the surface of the tray, causing it to get stuck with then tray tries to open. In this case, it may be possible gently shake the computer and move the CD or DVD into the correct place in the tray, allowing the drive to open. However, use caution when doing this, as you do not want to shake the computer too much, or you could damage other components.
If this is a desktop computer, you can prevent damage to the computer by opening the computer and removing the disc drive in order to shake or rotate the drive. When the drive is out of the computer, you can manually release the tray by inserting a paperclip into the manual eject hole.
In the case of a laptop computer or a slot load disc drive, since the CD or DVD does not sit in a tray, it cannot be shaken in order to adjust the disc. If the disc is visible you may be able to move the disc a bit by hand, enough to allow the drive to eject the disc. Again, be careful in doing so, as you could damage the disc or drive in the process.
If you're still unable to get the disc out of the drive after following the above steps, it may be a damaged drive and should be replaced. If the disc in the drive is an important disc and you believe the drive is bad, the drive can be disassembled in order to remove the disc. In the case of a laptop or computer with a slot load disc drive, the computer needs to be serviced in order for the drive the be replaced and the disc to be removed.
on the left side of the front pannel just under the drawer you will see a pinhole.turn your cd unit upside down and insert a straightened paperclip in the hole keeping it straight as possible,the drawer should open enough to allow you to grip it .
if no luck you will have to remove the case top and manually remove the disc..
hope this helps.....Len..
If you need to open the drive doors, there is a small 1 mm pinhole that should be underneath the drive doors. Using a paper clip or safety pin, insert this into the pinhole and the door should crack open. Then test the drive door's eject button. If it works, they should be fine. If it doesn't you may need to replace the drives themselves due to mechanical wear and tear. Given the model number of the unit you provided, this unit may be out of warranty.
If you are still having more problems or concerns, please feel free to give us a call @ 877-686-8868 x208. Thank you for purchasing EZ Dupe products.
Unless I am mistaken there will be a little hole on the door (or near it). That is the manual eject, use a pin or a paper clip to press the button inside.
To open this drive you can open My Computer and right click your DVD drive and select eject. You can also open any CD/DVD drive by taking a paper clip (or something the size of one) and inserting it inside the tiny pinhole near the eject button on the drive.
is the light flashing on the drive ? .... be that as it may you will note a small hole on the face of it.... put a small round object in there and push... that should open the door.
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
did you try to do the emergency eject ?
jewellers driver in drive pinhole.
use the eject method again, Computer powered Off. Open the drawer and push it back in firmly.
This is an eject button, make/break switch problem.
Also try ejecting the drive from my computer/Right click with mouse ( CD Drive ) Eject.
And ensure the 4 Pin Molex ( Red-Black-Black-Yellow ) is the right way round. Yellow usually faces to the outside of the casing.
