Question about Palm Tungsten T3 Handheld
Trying to put TurboApps to Tungsten T3, getting error message
HotSync Log for Cliff ConardF_TA_Rep_Contact_Info - -2147213296 Database, record, etc. not found
ERROR TurboApps - Rev. 1.0.855/123/0
Download requirements ok, good connection with equipment.
  • Anonymous Apr 16, 2009
    TurboApps used to sync fine with laptop via "HotSync". Now no longer works. Shows this message: "F_LA_Signatures - -2147213296 Database, record, etc. not found
    ERROR TurboApps - Rev. 1.0.923/149/149"
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
This 3rd party app may not work with your unit. Was it downloaded for palm device
Posted on Jan 09, 2009
Tungsten V
Re-arrange port configuration, install latest version of palm desktop. Right click on palmsync icon on system tray and check "Local Serial" . You may also use IrDa as alternate sync method
Apr 04, 2009 | Palm Tungsten E2 Handheld
During hotsync, data wont transfer from Computer to palm
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Mar 31, 2009 | Palm Tungsten E2 Handheld
Trying to hotsync my desktop and my 755, and I use Outlook.
if using verizon go into the wireless sync application and select settings> connection> advanced settings> and select enable other sync apps.
Apr 07, 2008 | Palm Treo 755p Smartphone
Synchronizing Tungsten T3 with desktop or laptop
I recently re-installed my T3 program
What do you mean?
  • Did you restore your T3 from a backup on the PC?
  • Did you install programs on the T3 using the PC's "quick install"?
Is Palm Desktop showing the correct Contact/To-do/Calendar Data?
How are the conduits set up? (From Palm Desktop, select Hotsync->Custom)
Nov 15, 2007 | Palm Tungsten T3 Handheld
Palm tungsten not switching on
Make sure that it has a full charge. I have been having problems with it not turning on as well, but it sounds like a different problem. I have bought a new battery from ebay and installed it. It is holding a charge great, but still isn't turning on all the time. I think the prob is with the datebook or something else. Good Luck!!!
Mar 01, 2007 | Palm Tungsten T3 Handheld
Unable to sync with outlook 2003
Try to change conduits to hotsync with PDS, if it will work then the problem is with the MSOutlook.
Sep 12, 2005 | Palm Treo 650 Handheld
Lost all contacts, memos, tasks, after LifeDrive Update 1.0
This morning I downloaded LifeDrive Update 1.0, and when I did a HotSync afterwards, I got an error message saying, Handheld Tasks application database version not supported. Handheld Notes application database version not supported. Now my contacts, memos, tasks, calendar entries and possibly other items are all gone!! This is the core data that is the reason why I use a PDA! I would be totally distraught, except that the data does still seem to exist in Outlook on my PC. I am running Outlook 2002, SP3 on a WinXP machine. Can anyone help to fix this problem? thanks,
Sep 12, 2005 | Palm LifeDrive Handheld
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
Sep 11, 2005 | Palm Tungsten T3 Handheld
1 palm + 2 computers = successful hotsync?
Yes and.. no.
It is possible to have one Palm synchronized to 2 PCs (I do this with my T3), just make sure that you don't end up with any "overlapping changes" - items that change on both machines.
However, since Syncing takes a full backup of the Palm, having two completely different sets of data on two different machines is complicated at best. If you are are not careful you could lose all your info by accident. One way to get around this would be to put everything on on the T3 and use categories to separate work and personal items - which is what I do.
However, if you are dead-set on keeping all of your work stuff in one place and all your personal stuff in another, I would recommend that you get a second T3.
Sep 07, 2005 | Palm Tungsten T3 Handheld
Sync fails with "too many open databases"
This is what I did to fix that error:
Hard-reset your Palm to erase all data (that usually involves pushing the small "reset" button on the back, then pressing the "power on" button until the device boots, and then pressing "up" to confirm the hard-reset)
After that, sync your palm. The sync software will ask if you want to use your existing profile or create a new one. Create a new one. Then the program will offer to sync your Outlook profile with your Palm. Click on "ok", and a message asking you to accept to sync your Outlook data with more than one profile will pop-up. Click on OK, again... and that's it!
Palm Tungsten T3 Handheld Logo
125 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
