Question about True T-49 Side by Side Refrigerator Commercial
We'd like to stop the True T-49 fans from running all the time
Another True commercial frig that we have does not run the fans when the cooling is not active - we run the frig at much higher temperatures for wine instead of food. How can we make the T-49 fans stop running all the time?
  • 51 Answers
You would have to have your fans power supply wired in series with the thermostat.
Posted on Feb 17, 2009
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
Overheating
That is normal cooling fan operation. the fans are computer controlled and not turned on until the engine reaches the pre programmed temperature, that is about 185-195F
Jan 03, 2014 | 1998 Chevrolet Lumina
The unit is not cooling down.
is the unit running? are the fans running? if the fans are running then check to see if the comp is running. If the comp is running you have a more serious issue. if its not or nothing is running im suspecting a control issue
Aug 14, 2013 | Summit Commercial Summit Professional Wine...
I am in need of a fan motor for my Danby Frig. Paret #JG50.DQ-10. Cannot find it anywhere. Suggestions?
The problem with the factory fan is that it is a sleeve-bearing fan. On average, a fan should operate for about 50,000 hours, which if it runs continuously would be over five years. However when the operating temperature rises or the fan is installed "not exactly" vertically, it will have shorter life.
I had to replace my fan two times withing two years since we bought the unit! Plus the stock fan becomes quite noisy after a couple of months of work.
With all of these problems I did some research for better fans and decided to purchase a ball-bearing fan to install it into the cooler by myself.
Ball-bearing fans on average outlast sleeve-bearing fans by 50 percent and produce less noise.
It's very important to purchase the right AC 115 Volts fan for this Danby wine cooler.
The original fan is Rullian Science RAL 1225S2 (120x120x25 mm in size, 100-125V AC, 0.09A)
The replacement model is Orion OA12AP-11-3TB which I got for $16.75 from Mouser Electronics (mouser.com). The replacement model is ball-bearing cooling fan with slightly higher/better parameters, which will help to cool down the wine cooler coil faster.
To replace the fan you need to tilt the wine cooler on the side and unscrew two small screws at the bottom that keep the original fan in place, remove one screw to the black box where the fan wires are attached and unplug these wires. Then you just need to replace it with the new fan and test that it works properly. If you never used Soldering Tool before you probably will be better off with getting some help from certified electrician - it still will be less expensive than getting this fan ordered every year from Danby.
Nov 06, 2012 | Danby DWC513BLS Wine Cooler
Do I need a wine cooler to store my wines or can I store them in a normal refrigerator?
The purpose of a wine cooler is to store wines at their proper temperatures in a proper manner. Wine coolers are set to higher temperature ranges than other systems simply because wine should not be kept as cool as other beverages.
Jul 31, 2012 | Furniture
This evaporator coil gets all iced up about once a month and quits cooling
Check the condenser coil is clear and clean, and thermostat set about 2 or 3. Also check the fan is running with door closed, and no food is too close to the top stopping the airflow over the evaporator. It may be as simple as a blocked drain backing up - check the drain tube next time it defrosts.
May 12, 2012 | True 49 cu. ft. / 1388 liter Commercial...
Location of temperature setting site
inside on the right side of the fan/coil housing. should be a black knob marked 1 - 9 the higher you set it the colder it will run. Normally set on 7 or right between 7 and 8.
Oct 25, 2011 | True 49 cu. ft. / 1388 liter Commercial...
My freezer has power, but the fans are not going on when the door shuts and the temperature is rising.
The defrost termination/ fan delay control is a temperature-activated, single pole-double throw switch. ).
The control is wired into the refrigeration circuit. The control is located high on the evaporator where the frost is likely to clear last. The function of this temperature-activated switch is to terminate defrost when the evaporator coil has been defrosted, and to delay the evaporator fans from coming on immediately after defrost.
The coil must reach a temperature of 25* F. for the fan delay to close allowing the fans to operate.bobicehouse_38.jpg
Jul 22, 2011 | True 49 cu. ft. / 1388 liter Commercial...
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
True T-49 Side by Side Refrigerator Commercial Logo
198 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
