Question about NetGear WGR614 Wireless Router
All lights are on my wireless router
All my ligts are on my router
I tried reset button, it doesn't work. Then I try to use another power adapter, it works!
Posted on Feb 20, 2010
    Problem Solver:
  • 9 Answers
If all the lights in u r router is on ...it means that the product is defective ......so try to reset u r router ...if still not working ...no other go
Posted on Jan 10, 2009
Modem works but does ligts not working
Try unplugging the modem wait for 30 seconds or so and plug in.
Feb 06, 2013 | Computers & Internet
I bought a netgear jwnr 2000 yesterday and tried to set it up at my sisters house for her, so i could take the other netgear router with me. It didnt work. The only indicating lights that were working...
1. Reset the router to factory settings.
- Before you reset the router, unplug all the cables attached to it except the power cord.
- Make sure the router is plugged into the power outlet, then hold down the reset button at
the back of the router for 30 seconds using a paper clip or a pen. You should see the lights flicker momentarily on the front panel of the router.
2. Once the lights are stable, connect 1 computer or laptop directly to the back of the
router(LAN ports usually they are labeled by numbers and have the same color, just pick one).
If you pick number 1, check the corresponding light indicator at the front panel of the
router, make sure light 1 is also lit up if not choose another port at the back of the router.
3. access the router's setup page by typing http://www.routerlogin.net or 192.168.1.1 in the
address field of your browser and then press Enter. Type admin for the router user name and your password (or the default, password). Setup and configure the router again.
4. If you notice the connection is not stable or the lights on the router are still not
displaying correctly, you may update or reload the same firmware(program or software) on the
router. You may download the updated firmware from http://support.netgear.com , just type the
model of your router, choose the version, press enter then click on Downloads, you should see
the firmware available for your router. Make sure to use wired connection when updating the
firmware.
Sep 18, 2011 | NetGear WNR2000 Wireless Router
N Wireless Modem-Router F5D8633au4A: every light on my belkin N wireless router is on e...
WIRELESS LIGHT WILL LIT UP IF YOU CONNECT ANY ANY WIRELESS DEVICE TO THE ROUTER.. FOR EX: YOU CAN SEE WIRED LIGHT LITTED UP BECAUSE YOU CONNECTED A COMPUTER WITH HELP OF ETHERNET CABLE.. IN THE SAME IT WILL WORK...
May 17, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Router will not go wireless. all lights come on
The "wireless" (second) light on this model does not indicate that the router's wireless features are active, it indicates that a computer is connected to the router wirelessly. If the "router" (fourth) light shows three little "radio wave" symbols, the router's wireless capability is on.
Nov 18, 2009 | Belkin (F5D8231-4) Wireless Router...
When I connect the wrt160n in the pc it says network cable unplug
Check the Ethernet adapter status under network adapters in devicemanager.
right click my computer-properties-hardware tab-device manager-network adapter.etherrnet should be green
Jul 12, 2009 | Linksys WRT160N Wireless Router
My netgear wgr614 is not working. I have no
To establish a wireless connection between the router and computer, the router’s wireless setting (SSID or Network Name, Channel, and Mode of communication) has to be configured. Please follow the steps below to configure the wireless settings on your NETGEAR router.
  1. Connect a computer to the LAN port of the router using an ethernet cable.
  2. Open up a browser and type in the following URL: http://192.168.0.1 or http://192.168.1.1 (depending on the model number of the router)
  3. Type the Username as admin, and Password as password. Then click OK.
    1. To change the Wireless settings, click Wireless Settings under Setup on the left menu bar.
  1. Under Wireless Network, (make a note of these settings, you need these values to configure your wireless clients)
2.
    • Change SSID from default NETGEAR to any desired name (for e.g. Home)
    • Select the Region as applicable - Incorrect selection may cause performance problems.
    • Select any one of the available Channel.
    • Apply the changes
Configuring Wireless Clients:
The steps explained below use the Windows XP wireless client. If your card came with
its own wireless configuration utility, you may use that as well.
  1. Open the Control Panel from the Start Menu.
  1. Right-click Wireless Network Connection and choose Properties.
  1. on the Wireless Networks tab and if unchecked, check the box for Use Windows to configure my wireless network settings.
Then click OK.
  1. Right-click on Wireless Network Connection, Select View Available Wireless Networks
  1. This will lists all the available wireless networks in range. Select your network from the list and click Connect.
If you are connecting to a secured wireless network, you will be prompted for a Network key. Type the Network key (if you are using WEP security, make sure you are typing the network key, not the Passphrase) and click Connect
  1. Your network list should now display your connection status. If you are connected and your router is setup for internet access, you are ready to connect to the Internet wirelessly.
May 18, 2009 | NetGear WGR614 Wireless Router
Min router fungerer fin via kabel. men efter en reeset af routeren kan jeg ikke l?ngere logge p? tr?dl?st. Hvordan finder man en ny n?gle???
Hej Trille,
- generere nye koder?
Det bliver uden tvivl noget grusomt "giberish" = uforståligt :-)
Du kan selv lave din egen kode, og VæLG key 1, for der er desværre trådløse kort der KUN har key 1.
Nu da du så har fået sat en kode på routeren, skal du "bare" sætte den samme kode på dit trådløse netkort.
Model - og jeg kan hjælpe
Hvis ikke, - så ville det da ikke gøre mig det mindste hvis du "vote" "FixYa" :-)
arbejder på at blive Guru her på siden :-)
Dec 03, 2008 | Linksys Wireless-G Broadband Router
Configure router
You haven't specified the version no of the router. If you would turn the router upside down, you can see the model no and the version no right next to it. Although, the configuration of all the versions would be the same, you still need to make sure it has the latest firmware if its a older version. Here is what we need to do... 1. Connect the modem to the Internet port of the router 2. Connect the desktop to the port 4 of the router 3. With the router turned on, push the reset button on the router and hold it for 20-30 seconds. 4. Power Cycle: Unplug the power from the router and the modem. Wait 30 seconds and turn on the modem first. Wait 1-2 minutes till the ligts on the modem are steady. Turn on the router. 5. Wait till the lights on the router are all turned on (takes around 1 minute) 6. On the desktop, open your web browser 7. In the address bar, type 192.168.1.1 8. It must prompt you for a username and password 9. Skip the username and type the password - 'admin' 10. That must bring up the setup page of the router 11. There is tab on the top right corner - 'Status'. Click on that 12. In the status tab, you must see the internet ip address - 192.168.1.64, which is the ip address provided by the modem 13. Go back to the setup tab 14. In the setup tab, you would see the local ip address = 192.168.1.1 15. Change it to 192.168.2.1 16. Click on Save Settings (scroll down to the lower end of the screen to see this option) 17. Wait for 30 seconds and close the web browser 18. Power Cycle again (refer step 4) 19. Now internet must work on the desktop 20. By default, the network name (SSID) of the linksys router is - 'linksys' 21. You can go to the laptop(i assume it has windows xp), and try to connect to this network by - right click on the wireless icon in the system tray (on the right bottom corner of the screen) and click on 'view available wireless networks' 22. You must see 'linksys' as one of the available wireless networks 23. Try connecting to it and you laptop must work Those steps are generalised and you might get stuck in exceptional cases. If this does not work, please initiate a chat session with any of the experts, if this does not work, because this may require some advanced troubleshooting which would not be possible using those short messages. Good Luck
Mar 27, 2007 | Linksys Wireless-G WRT54G Router
Configure router
NetGear WGR614 Wireless Router Logo
360 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
