Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water filter won't come out so I can change it.
I have a Whirlpool side by side and I can't seem to get the wate filter out to put in a new one . I look in the use guide but it was no help.
    Problem Solver:
I had same prob when I changed filter first time...if it is up in the top corner of fridge, you'll need some kind of rubber gripper to use cause the condensation makes the filter holder slippery. Just grab on to it and turn counterclockwise. It should just screw out, take out the old filter, replace w/new and screw back in. On some fridges, the whole part you screwed out has to be replaced instead of just a filter inside it. Hope this helps.
Posted on Jan 06, 2009
I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
Oct 27, 2014 | Whirlpool Refrigerators
Wate Filter Light stays on after filter has been changed.
  • After changing your water filter you have to reset the light for it to go off as it does not reset right away.
  1. Just press and hold the "FIGHT" and "LOCK" buttons until the water filter light flashes. Now the light will be off.
  2. Don't forget to run a couple gallons of water through the new filter to remove any carbon out of the incoming water after installing a new water filter. This is not poisonous by any mean but it can leave a bitter taste in your mouth until the carbon wears off.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Maytag MSD2756G Side by Side Refrigerator
Am attempting to change an in grill water filter for my whirlpool side by side fridge, and cartridge seems jammed, cannot turn anti-clock wise to release. Do not want to force in case I break it. Any...
Use one wrench to hold the water line and another one on the filter to avoid braking the line, the filter should give up.
Don't forget to rate this post!!
Sep 19, 2010 | Whirlpool GS6NBEXR Side by Side...
Water flow is very slow almost a dribble - we have changed filter and that did not improve the flow When frig was new water flow was very high
ck the walve that was installe on cold water it is gone bad and needs replace ment . do use one that you drill pipe 1/4 in and it alow the water to flow . the small pin pircing type will corrode over and slow the wate or stop the water .. mm
Aug 17, 2010 | Maytag MSD2656G Side by Side Refrigerator
Ge refrigerator water low, Drinking wate.
make sure line is not kinked behind the frig, maybe change filter if it has one. then change water valve if that dosent solve problem
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How do I change the water filter in the refrigerator?
down in the front grill at the bottom of the fridge you will see the filter and just the the left of it you will see a button. push the button in and that will pop the filter out a bit. pull it out and put the black cover that was on your old filter and put on your new one. then just push it in
Mar 26, 2010 | Whirlpool GC3NHAXVY Stainless Steel Side...
My brand new side by side with exterior ice/water dispenser barely dispenses water. It comes out in a tiny stream that after a few seconds only drips out. Why?
you might want to check the shut off valve on the house end. follow where the wate line goes and see if it is a self percing valve. if it is shut it off all the way to re-tap the cold water line on the house end. if there is a filter on the line with also cause this problem. Is the waterline new? if so it might not be tapped all the way.
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Fridge model ED5VHGXMQ00. It just stopped making ice
Hello Mike more then likely you have a bad water inlet valve it’s in the back of the refrigerator now if you change the valve and it still won’t work the water line may be frozen you have to defrost the freezer to correct this problem
Nov 18, 2017 | Whirlpool ED5FTGX Side by Side...
Changing the water filter
hold the filter light button down for about 6 sec
Jan 28, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
582 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
