Home | Kitchen Hoods | Kitchen Hood Broan Nut...
Kitchen Hoods
Problem for Kitchen Hoods
Generic problem for all Kitchen Hoods
Kitchen Hood Broan Nutone RM5200 Hood won...
By michael928 on Jan 06, 2009
The range hood when turned on, won't **** air and has a loud knocking noise which vibrates the cabinets around.
Comments:
Feb 10, 2009
- Thank you for the reply. i ended up changing the motor assembly which includes the fan and the rattling is gone. But the vent isn't pulling that strong when the bottom vent is reattached. I plan to do a few things to test out what's wrong. 1) check to make sure the pipe that lets air out isn't blocked. I plan to use a thick rope and poke it through to see if it's sucks the air out. i can also use very small pieces of tissue paper and see if it blows out to the outside. My pipe outlet is the side of my house so I can actually see it from my porch 2) patch up all screw holes and holes which might let the air out 3) consider changing the duct to a 6 inch instead of the one that was installed, 6 inch outlet to a 3 inch duct. when turned on, i can hear the flaps opening up to let the air out but it closes and opens every other second, which is also annoying. Let me know what you think of my plan.
Same Problem
Apr 03, 2009
-   It's not pulling air although the motor is running. It never worked since we moved in to this house. I'd like to know what 'metal plate' could have been left and how I could remove it. Thank you.-   katg8
Best Solution
posted on Feb 08, 2009
Very Helpful)
gtp_jmp
Rank: Wiz
Rating: 86%, 25 votes
There is definetly somthing blocking the air from escaping, either the duct is blocked or the installer did not remove the metal plate which opens the fan up for it to be able to evacuate.
Comments:
Feb 10, 2009
- Your plan sounds perfect! Keep me updated.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kitchen Hoods
Questions and Unsolved Problems for Kitchen Hoods
Answer
What kitchen hood should I buy?
Answer
fan and lights are not working. I checked the fuse and it is not blown. The light over the #1 button... (More)
Answer
I have a code that is coming up, F-9, What can I do myself to fix the problem?
Answer
I have a Kenmore Elite Utra Wave Technology Microwave, F-9 code coming up, what do I do?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kitchen Hoods:
Top Kitchen Hood Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Kitchen Hood Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
