Question about Kenwood Audio Players & Recorders
Powered subwoofer will not work anymore
Tried another Kenwood powered subwoofer that I know works and had the same problem. I have a KS-908EX. The subwoofer is SW-38HT. I have tried the setup and it keeps reverting back to LFE level. How do I get the subwoofer to work? This is in step 3 of the setup for the speaker settings
  • 151 Answers
Make sure you are pluged into the sub pre out and not the six channel line in,its a easy mistake to make.
hope this helps.
CABLE GUY.
Posted on Jan 06, 2009
I have Kenwood SW 900 . need to know its out put. Kept for long period
Do you mean the Kenwood SW-200 subwoofer or the SW-200 power meter? The subwoofer can use 50W RMS at 4 Ohms. It's rated at 60W. The power meter reads in two ranges: 20W and 200W.
Kenwood has the manual for the subwoofer on their support site. The direct link to the manual is http://kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/sw200.pdf .
I hope this helps. If you are looking at a different Kenwood product, please clarify which product you have. I can't find a SW 200 receiver from Kenwood.
Mar 08, 2016 | Kenwood Car Audio & Video
What are signs of a burnt out coil in sub
Check the bronze-colored coil underneath the foam cover. Note whether it looks worn, burned, warped or distorted. This may be the cause of your sub sounding fuzzy or muffled, which means it needs replacement.
Look at the fuse inside the speaker and test it if you know how. This is a likely problem that causes your sub to power up improperly, play sounds at about half the volume or intermittently fade in and out. If the fuse is discolored or shows a short, you'll need to replace it
Dec 13, 2010 | Kenwood KS-706HT System
Hi, I have the Kenwood Subwoofer KS-201-HT, my question is how do I connect it to my receiver?
usually subs have outputs 4 ur monitors however if ur sub is active @ ur monitors are passive then you need 2 connect sub 2 ur tape loop with rca connections,usually you use the send signal from ur reciever which would norm connect to ur tape input , if the sub is passive then u connect direct to speaker output on amp then monitors to the sat connections on sub
Oct 12, 2010 | Kenwood SW36HT Subwoofer
Connect a Sony SA-W3800 powered subwoofer to a kenwood receiver
Yes. It needs to know you have a subwoofer or it won't send low frequencies out to one. Then you have to calibrate its level to match the rest of your speakers. Hit the SETUP section in the manual (available at retrevo.com).
Jul 02, 2010 | Kenwood VR-309
I NEED TO KNOW HOW TO WIRE THREE 3012 THWELVES TO A 1800 WATT KENWOOD AMP
Its hard to tell what you can or cant do without knowing exactly which kenwood amp you are using. Generally speaking though most kenwood amps are stable only down to 2 ohms. you will be better off just using 2 of your 12s wired in parallel- that will give you a 2 ohm load. There is a way to use all 3 simply by wiring them in series, it will end up giving you a 12 ohm load on the amp though which will work fine but you wont ever achieve the full power that the amp can do.
Jan 17, 2010 | Kenwood Kfc-w3012 12" 2400 Watt Car Subs...
Subs not programmed into dash...?
It sounds like the input gain on the amplifier needs to be adjusted.
OR if your certain this hasn't changed see if both of your RCA cords (Left and right) are working. I had a similar issue when the mono block AMP was only sending signal from the left channel to the amp which in turn was dropping the input load in half. Its all about isolation.
Simple way to test this is to adjust the L/R balance of your deck all the way left or right and see if the amount of bass changes. If you balance all the way left and you lose your base completely then you know your amp isn't getting signal from the left channel thus if you move it all the way to the right and the bass disappears then the problem is with the right channel.
Jul 05, 2009 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Cant get bass, fuse is fine
You don't say if you've configured the Receiver to know you have a subwoofer (under Multicontrol - SUBW YES). Unless it knows about the Sub it won't send anything out that single "preout". You can get an RCA splitter to run that single output to both inputs in the Sub.
Just as an experiment, temporarily run one a pair of cables from the REC OUT to the Sub's inputs and tune an FM station to prove the Sub amplifier is alive. If it's still silent, it's dead. If there is sound (muffled) you need to go back to the Receiver to figure out why the Sub Preout is signal-starved.
May 16, 2009 | Kenwood Audio Players & Recorders
Sw-32ht kenwood subwoofer
Open the case and check the fuses and the speaker to see if it actualy still working and not blown.
Oct 26, 2008 | Kenwood SW36HT Subwoofer
Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Sep 22, 2007 | Kenwood VR-507 Receiver
381 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
