Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Freezer icing over fan
Once a month my freezer ices up around the fan and I have to unplug the freezer for 24 hours, how can stop the freezer from icing around the fan?
  • 38 Answers
Check the defrost timer first and then if that is ok check the defrost heaters and the firmisters on the evaperator 1 or all of the above will be faulty good luck
Posted on Sep 04, 2007
  • 291 Answers
Check the water spout comeing into ice maker and see if water is leaking out or spilling over
Can I remove the freezer compartment from my Haier HSE12WNAWW?
not possible to remove the freezer
the most likely [problem is that the seals around the freezer door are not sealing properly
that allows the atmosphere into the freezer and the humidity then freezes and turns to ice , causing the problem
adjust the door and change that door seal
when defrosting the freezer, remove all the frozen food, and place a fan at the open door
atmospheric temp air will defrost a badly iced freezer in around 1 hour with the use of the fan on high speed
Apr 05, 2017 | Haier Refrigerators
My kenmore side by side refridgerator is making a loud noise on the freezer side when it runs....sounds like the motor or fan and is very annoying. Took out the ice tray and emptied it, also cleaned some...
Hi there
These units are called frost free, however in my experience they are some of the time but not all. It is likely that the freezer has built up some ice around the coil and the fan, try the following.
1. Empty the fridge and freezer and store the food elsewhere.
2. Switch off and unplug the unit and leave for 24 to 36 hours with the doors held slightly open. You may get quite a lot of water on the floor, you just need to mop it up, this is normal.
3. Wipe out the inside of both sides to leave them clean and dry.
4. Plug in and switch on, wait around 4 hours.The noise should have stopped, if not it is the fan.
5. Re stock the unit it should be OK.
6. If the problem re-occurs within a few days then there is another possibility that is causing this problem and that is there may be a fault with the defrost system. Possibly the timer, the termination switch or the heater.
7. If the problem goes away for several months then the ongoing solution is to repeat the above steps.
Hope this helps
Gordon
Apr 27, 2011 | Kenmore Side by Side Refrigerator
Our two door samsung has making noise from the motor and when you open the door it will stop. jackie.brincat@bigpond.com
Hi and welcome to FixYa, I am Kelly
The noise that stops when you open the door is the evaporator fan. If it sounds like blades striking something there is most likely too much ice in the evaporator coils and the fan blades are striking the built up ice. If it sounds like a vibration it can be bad bearings inthe evaporatof fan motor.
Ice build up is usually a sign of an automatic defrost circuit problem. The unit should defrost close to 3 times a day depending on the defrost control installed. What you should do is do a manual defrost session by unplugging the unit, removing the freezer contents and directing a fan into the freezer compartment for just over 2 hours. This will ensure that all of the evaporator coil ice has melted. (Yes it makes a water mess) Tidy things up and return the unit to normal service after your manual defrost session. NOTE: If you have an automatic defrosting problem the fan noise can repeat in as little as 2 days as the ice once again builds up on the evaporator coils.
DO the manual defrost, LISTEN for noise after 24 - 48 hours. No noise... no worries, NOISE after 24 - 48 hours = Defrost problem. Causes of a defrost problem can be the defrost control, defrost heating element, the defrost thermostat or a wiring problem.
Thanks for choosing FixYa,
Kelly
Feb 03, 2011 | Samsung RS2630SH Side by Side Refrigerator
The freezer side appears loud rattling noise and noise stop when the freezer door open. It happens couple times per day and last minutes to hour.Please tell me what's going on this
I had the same problem - A fan in the freezer section has ice building up on it and the noise you here is the fan blades hitting the ice. The fan stops when you open the door. I had to empty the freezer, shelves and all; remove the back panel (a pain in the neck) and chip the ice off of the fan housing. I have to do this every few months.
Aug 03, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
The ice maker will not quit dispensing ice and it no longer cools
For now unplug the pin plug at lower freezer door hinge and disable the dispenser control board until we see if the keyboard or the dispenser board is at fault. Sea Breeze
Feb 22, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Maytag Plus side by side refrigerator stops cooling. I unplugged it for 24 hours. When I plugg it back in, it works fine for about 2-3 months. Then it stops again and works fine after being unplugged for...
Take food out of the freezer, take out the racks, take off the back panel on the bottom/back ( probably 4-6 screws).. You will see a fan. If that fan has ice around it, then take it all off, chip it, hair dryer, what ever you want. Unplugging it for 24 hours is not enough for all of the ice to melt so it is probably taking a couple months to build back up. Generally this happens in a high humidity time of the year. It will probably happen again, do not freet. Just clean it again. I know one customer that had it happen two years in a row and that was about four years ago. He has had the unit (Maytag Plus side by side refrigerator) about 10 years and is just fine with it. Little inconvience, but sometimes that is the breaks in life. Good luck.... f067b6b.gif
Nov 30, 2009 | Refrigerators
Freezer works refrigerator warm
Sounds like the FF(freezer fan) is wearing out this fan supplies the circulation for both the freezer and the refrigerator, when this fan motor starts to wear out it does not produce enough force to circulate air thru the freezer and refrigerator causing the area around the fan to ice up. The immediate solution is to unplug the unit for around four hours or use a portable hair dryer to melt the ice around the fan, but be very careful not to melt the plastic. That is why it is better to let the ice melt on its own by unplugging the unit. The minimum cost to repair/replace this fan assemble is around $300.00
Jul 11, 2009 | Refrigerators
Ice on back wall but not freezing food and rattle noise. Moved all food to other freezer
This is a fairly common problem with these types of refrigerators. The design is set to defrost every 12 hours and be down for 1 hour to allow ice to melt on coils. More often than not the ice never fully melts and creates a blockage in the coils and in turn slows air flow. You can remove the screws in the back wall of freezer unit and unsnap the ice maker plug to allow access to the coil. Gently tilt the back plate forward. You can then unplug the ref. and help it thaw with a blow drier. If you are not comfortable removing the back plate then you can just unplug the ref. and let it thaw on its own. this may take a while. try to remove as much ice as you can from the back of the freezer wall by hand and prop the door open for a couple of hours to ensure that all the ice melts. The rattling sound you are hearing is the fan blades hitting the ice that is built up around it. As a precaution I recommend that these type of refrigerators get manual defrost simply by unplugging about once a month for about two (2) hours. I hope that this will help you out with the melted ice cream. Good luck.
May 30, 2009 | Kenmore Refrigerators
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
FREEZER SOUNDS VERY NOISY
It could be the fan is bad or that it is hitting ice. If the noise is kind of a buzzing like it is hitting ice...defrost your unit by unplugging and waiting a day or so for full melt out...then check your door gaskets for cleanliness and good seal. Avoid 'windowshopping".
Dec 22, 2007 | Samsung RS2630SH Side by Side Refrigerator
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
