Question about George Foreman GP324 Stainless Steel Grill
New grill as gift
I received this grill as a summer gift. It is missing the starter how can I obtain a starter?
0 characters
1 Points
Got married about two years ago. One of our wedding gifts was a gift certificate for Barbecues Galore. We picked up a Cap'n Cook 4-burner unit with an infrared rotis burner. Wanted to use the rotis...
No, John, Yo do not want to use the rotisserie rod/spit without the wooden handle. Call BBQ's Galore Customer Service 800-752-3085 for a replace handle. If they can't help you, go to the following link and search by the Model Number of your grill (FYI - Capt Cook is not a model number).
I hope this helps you and thanks for choosing FixYa. Happy Grilling!!
Aug 22, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
On a Go-Anywhere grill 20+ years old, the regulator valve slides out of the grill even when facing upwards. Normally only does this facing downward. Is there wear on my regulator? Or is it in the tube...
The U shaped clip that holds the regulator to the gas tube is probably missing.
Make a new one with a LARGE size paper clip bent with needle-nosed pliers and stick each end of the "U" shaped new wire into both sides of the gap in the gas tube where there is a groove in the regulator when the regulator is pushed into the gas tube. The simple new clip will prevent the regulator from sliding out.
Jun 16, 2011 | Weber Gas Go-Anywhere Grill
We definitely neglected this bbq. After last summer..leaving it with meat drippings and water which molded the entire inside of the grill as well as rusted the metal on the grate and the tray underneath...
Morgan, unfortunately, it has passed the point of taking better care of it this summer. In addition to replacing the grates, you will probably have to replace the burner(s) and the venturi valve(s), as well as the tray underneath. It will cost you just as much to replace all the parts (if you can find them) , as it would be to replace the grill with something equal to the Road Trip Grill. The accessories you'll need the most are a brass grill cleaning brush and a good quality grill cover (not a $9.99 special).
Sometimes, it's just not worth fixing some things.
Apr 26, 2011 | Coleman Roadtrip Grill LXE 9949-750
I received aa Amana AM26 lp Grill for a gift. Want to convert to natural gas. What part do I need?
The grill has to have the duel fuel label on it, if it is not duel fuel then it can not be converted to natural gas. I have searched and I have not found a conversion kit for it.
Jan 07, 2010 | Grills & Smokers
Last summer closed up grill had no not working
unhook the tank and hook it up again being sure that the regulator is right side u p.
these new grills have a safety valve that often partially closes and causes problems.
Apr 27, 2009 | Brinkmann Charmglow 810-7400-S Propane...
Weber grill doesn't work at all
You sometimes can clog the LP Regulator.  Try removing hose back to nut fitting and creating suction, ( human or even better, a brake pump tool).  Otherwise go to Menards or LP Provider and buy a new regulator and hose, (pretty cheap usually less than $20). Try that and let me know.
Mar 20, 2009 | Weber Q Grill
Burner issues
home Depot sells replacement parts for the grills take the burners with you and you shouldn't have any problems
May 16, 2008 | Weber Genesis Silver B Grill
George Foreman GP324 Stainless Steel Grill Logo
16 people viewed this question
Top George Foreman Grills & Smokers Experts
Jaime Hernandez
Steven Clarke
Steven Clarke
Are you a George Foreman Grill and Smoker Expert? Answer questions, earn points and help others
