Question about Olympus FE-210 Digital Camera
Broken zoom my camera was on so the zoom was out and i tripped and landed on it. now the inner part of the zoom is sat at an angle, wont move in or out & when i turn it on you can hear it attempt to push it out fully 5 times while the orange light flashes and then it gives up and turns off without the screen starting up. Does it sound fixable or is it time for a new camera? I only got it last xmas. Any idea where the best place to take it for fixing is? I'm based in Milton Keynes
    President:
  • 919 Answers
You may want to call Olympus Customer Service to discuss their repair policy and procedures. They will have suggestion as far as repair goes or give you a local place to take it for service. Their telephone number is 800-622-6372 option 2 and then option 3.
Posted on Jan 12, 2009
Dropped camera which landed on zoom lens.
Have you tried manually trying to pull out the part that is pushed in?
Sep 24, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Ricoh Caplio R3 zoom problem
the Zoom Cylinders is broken you need new ones
Jun 28, 2009 | Ricoh Caplio R4 Digital Camera
Zoom lenses is extended but wont go back in
Switch on and PRESS the "wide angle" selector switch. (in camera mode)
Now the lens should move partially back in.
If it does not move inwards at all and you do not hear a whirring noise, then the activator motor is defect.(or the lens assy is out of alignment). (or a foreign object has entered the gearing, and stalling the motor)
If you do hear the motor running, then a gear might be stripped.
All these faults do require to take the camera apart.
Mar 08, 2009 | Fuji FinePix F650 Digital Camera
Zoom broken
The impact damaged has jammed you lens assembly. I see these all the time in my shop. If it can be repaired without parts a shop should be able to do it for you for around $75. If it needs a new lens however it will not be worth the cost (the parts alone would cost about $50). I think though from your description it is probably repairable without parts. Please contact me if you need any more help
Wes
Perfect Image Camera Repair
Jan 06, 2009 | Olympus FE-210 Digital Camera
Camera lense
May not be repairable, but try this, put a block of wood ( approx. 2in X 6in ) on the end that is pushed in, on a angle and while holding steady tap it out with a light hammer. It should pop the lens back to orig. position. Turn the focus ring and it should turn smoothly.
I have used this method many times with about 80% success rate.
Nov 18, 2008 | Photography
Friction in zoom, Sigma AF 70-300mm for Canon-EOS
Its more like a distorted inner zoom barrel or sand and dirt inside  the inner barrel will need to be replaced or you need to dismantle and clean out
Nov 09, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Camera
My daughter just had this problem with her camera. The camera was off with the lens barrel extended. When I looked at it closely, I noticed that the inner part of the lens barrel was at a slight angle to the camera. I pushed firmly on the low side of the inner part of the barrel, and it popped the rest of the way out. Camera works fine now. Good luck!
Jan 17, 2008 | Polaroid I533P Digital Camera
Shaking Photography
Here you will find the tips for taking better photos with less camera shaking. Tips 1. Composing and holding the camera with less camera shaking. For clearer images, hold the camera firmly not to cause camera shaking. 1) For maximum stability, hold the camera firmly well over the grip and keep your right elbow lightly pressed against your body. 2) Support the lens or the camera body with your left hand from below. 3) Look into the optical viewfinder as if pressing your forehead to the camera. 4) Do not stand straight, but with one foot stepping forward for taking better balance of your body. 2. Change the composing and holding the camera according to the situation for securer photographing. (Particularly when you take photos using the LCD monitor.) 1) Lean against the wall. 2) Put the camera on a fixed object like a table. 3) Ensure the camera holding by pressing the elbow against the handrail. 4) Use the tripod. 3. Move the zoom control towards wide-angle if your camera has the zoom function. Moving the zoom control towards tele-angle, camera-shaking will easily happen. If your camera has the zoom function, we advise you to take photos by zooming towards wide-angle. 4. Higher shutter speed will produce better images. Slower shutter speed may produce more possible camera-shaking. If your camera has a choice of shutter speeds, we advise you to select higher shutter speed for less camera shaking.
Aug 31, 2005 | Canon PowerShot SD400 / IXUS 50 Digital...
Olympus FE-210 Digital Camera Logo
97 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
