Question about Yamaha HTR-6130 Receiver
Sub digital coax connection
I received a Yamaha 590BL system for Christmas. I have everything hooked up and working except for an extra sub. I have monster digital coaxial cable but I don't know where to connect it to on the av receiver?? There is an orange coaxial connection but it says DVD below it. I still tryed that though and no sound from sub.
Any ideas??
  • Scott Frye
    Scott Frye May 11, 2010
    Hi jd...
    Do you have a manual?
    If not you can get one free from the yamaha consumer electronics site.
    The DVD connector is for DVD player IN only.
  • 32 Answers
You will need to get a y connector and split the sub out signal between the one it came with and your additional sub. The connector you need is an MFF, (1-male, 2- female) RCA type.
Good Luck,
BB
Posted on Jan 06, 2009
I wish to replace a subwoofer on a surround sound system
In most surround sound systems the sub woofer is powered separately and uses a standard RCA coax connection to the receiver/amplifier.
Replacing is simply plugging in the new and reconnecting the coax cable.
Usually the audio signal is Dolby Digital 5.1 the (.1) is the LFE Sub-woofer. The connection is between the Subwoofer RCA connector on the amplifier and connects to the (LFE-Line) in on the subwoofer speaker.
Hope this helps?
Aug 09, 2016 | Audio Players & Recorders
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
How to install klipsch sub woofer to yamaha reciever rx-v559. everything working properly but sub wont be adjusted with volume. i got my stuff moved out here but had a mate help me set up. didnt pull it...
Does the sub work at all? How is it hooked up? The sub needs to be fed by an RCA cable from the Subwoofer Output jack for the receiver to control its output.
Mar 01, 2010 | Yamaha RX-V559 Receiver
Even though my dvd and receiver have component video inputs/outputs, when i hook them up i don't get any picture. i have connected the audio with a digital coax and that works fine. why doesn't it work?
Have you enabled the component output on the dvd player and/or switched the output to "component out"? This type of connection doesn't have automatic recognition like scart.
Jul 18, 2009 | Yamaha RX-V620 Receiver
Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Jan 14, 2009 | Onkyo TX-SR606 Receiver
Connection a JBL surround cinema speakers with sub to a Yamaha
if you do not have the digital hook up from the tv to the reciever
304c659.gif then you will not get the subwoofer sounds or the dolby digital sounds
if you don't have this on your tv then just turn off the dolby digital when watching the tv , and you should be able to hear the subwoofer thru the virtual surround sound
hope this info is worth a fixya and if you need other help then just ask me and
i'll be glad to help
electech
Nov 23, 2008 | Yamaha HTR-5850 Receiver
Yamaha RX V861 - Phillips DVD - No sound via digital coax
Does your TV support "Line In" or "Aux" or "External"? if so plug your "Low end" DVD directly into the back of the tv and verify that you Can get audio. Quite a few DVD players do have a mute feature. Be sure this is turned "off"...accordianman
May 14, 2008 | Yamaha RX-V861 Receiver
Help setting up Yamaha RX-V461
Typically, only stereo inputs exist on any comsumer-grade receiver, and the actual decoding to 3, 4, 5, 6, and even 7.1 is done internal in the receiver. When a "placement" signal is detected by the receiver, the sound is routed to the correct speaker.Please refer to a user manual
..accordianman
May 01, 2008 | Denon AVR-4802 Receiver
Cerwin vega ht-10d subwoofer won't work in yamaha reciever
Well, as I know, your Cerwin Vega subwoofer is designed for use with stereo systems. Therefore, it has only 2 channels for input, and 2 channels for output as well. However, you can try this out; the first thing I suggest is that you hook up your main front channels through the subwoofer. All you have to do is to connect the subwoofer input to the front channel output on the amp, then hook up your front speakers to the satellite output on the subwoofer. As long as you make sure that system is working on 8 ohms, I believe this can activate the subwoofer.
Sep 15, 2007 | Athena AS-F1 Main / Stereo Speaker
Yamaha HTR-6130 Receiver Logo
197 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
