Question about Sony KP-57WS510 57" Rear Projection HDTV
Convergence issue When I auto focus the plus sign shows up for about 2-3 seconds then disappears. When I try manual convergence nothing happens. Presently my screen has distinct and seperate red, green, and blue colors and the top and bottom of the screem bow inward.
  • Sony Master
  • 3,459 Answers
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, pico fuses, etc. Everything you need to fix it yourself. Its an easy fix.
Posted on Jan 26, 2009
  • Edward
    Edward Feb 28, 2009
    Your TV most likely has one of two possible problems.
    Problem #1: Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    Solution #2
    What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Is there a way to manually adjust the convergence on a Hitachi HDTV modol #43FDX15B?
Hi James,
If Auto Focus (Auto Convergence) won't complete the set-up stop trying to adjust it. There is a fault in the convergence circuit!! ICs have to be replaced and maybe some burnt resistors.
If you access the service set-up menu and try to adjust the "defective" circuit the Auto-focus may not work correctly after the IC's, etc are replaced. Experienced technicians know that the service menu allow easy resetting to correct the misalignment, etc. "First Time" technician can be easily misled, waste a lot of effort and never get a correct picture.
If you want to attempt the repair, buy the correct parts from a service guy that does this type of work. I suggest having the repair done by a local competent technician that is experienced with Hitachi Convergence Problems. It is considerably more challenging than changing a fuse.
Our Convergence Gallery shows a variety of Convergence Faults. If you live in Toronto, ON., Calgary, AB., or Vancouver BC. it costs $257 for Hitachi in home convergence repair.
Good luck.
Robert
Nov 17, 2015 | Hitachi Televison & Video
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
Unable to perform convergence.
Ur 2 STK convergence ICS,and some or all it resistors are dead.U must know how to solders?Replaced the 2 STK convergence ICS and some or all it resistors,will auto focus ur convergence back to normal buy itself.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Mar 10, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
Red lamp is out of Focus and the red is curved on the bottom left hand side of the screen. Auto Focus shows error. What could cause this to happen.
Ur convergence is dead.Must know how to solders?Must change ICS and all it resistors in the convergence board.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.The shop will cost u $300 parts and labors.
Jan 14, 2010 | Toshiba 42H81 42" Rear Projection...
Red's are out of alignment and I can't fix them
Replace the convergence ICs and the pico fuses you can get a convergence repair kit at the following link which is for the KP46WT510 But its the same one for your model. The kit contains the two convergence Ics all six pico fuses and four resistors. Plus free step by step instructions with pictures that show how to do the repair. Heres the link to the kit.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Jan 24, 2009 | Sony KP-51WS510 51" Rear Projection...
Convergence perfect focus not working and double vision
The problem you have is the 2 STK - 392 convergence integrated circuits need replacing the cost in the UK is about £150.
SUPER8
Nov 26, 2008 | Televison & Video
1993 Hitachi Projection Screen TV
Hi Dennis!
Your HItachi has an automatic color convergence (color beam alignment) feature called "Magic Focus" which can be accessed from the set-up menu. When selected, you will be prompted to push the front panel "Magic Focus" button... do so only one time and do not hold the button in more than three seconds to enter this mode. The process takes about 90 seconds to complete, but a second push of the button will stop the process with no change.
If the convergence is still bad after the auto-correction process, then the guns are misaligned beyond its corrective capabilities, and would require manual convergence.
A service manual detailing how to do this is available for a nominal charge at http://www.how2files.com/bykey.php/hitachi.
If you don't have one, a free download of the user's manual is available at https://merchant.satisfusion.com/sf/WarrantyCenter/registration/secure/Hitachi/Manuals/ModelNumberManualLinks.jsp?masterModelOID=SF-990486114-595&random=1213688278588.
Hope this is helpful, let us know if you have any other questions, and good luck!
Thanks!
-WildBill
Jun 17, 2008 | Hitachi 53SBX01B 53" Rear Projection...
HC-P4752W Blue Convergence??
You can replace the whole board, or opt to replace just the 2 IC's and a resistor or 2 that has probably failed. Lift the chassis & inspect the pins of the 2 IC convergence chips for hair line cracks around them. Inspect the small resistors out in front of the IC's for discoloring or burnt look compared to other similar resistors. The convergence board will cost much more than having the above repaced. Chips about fifeteen a piece, resisters .50 cents each plus shipping. Convergence board $100 plus.
Jul 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
Loss of convergence after powering off.
you must enter the service mode and align your convergence and save it to the epromm also activate the auto focus to activate the sensors , power on /mute-1-8-2- / press enter to save and before you exit activate the focus key on the remote ,very inportant to do the last step./g
Apr 29, 2007 | Samsung PCN5425R 54" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
127 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
