Question about Vehicle Parts & Accessories
Need install manual
Prostart CT-3200 automatictrasmission Multi-channel remote starter system
  • Anonymous Mar 15, 2014
    Prostart ct-5072 just turns over and won't start when in auto start??
    Problem Solver:
  • 10 Answers
copy and paste into your browser... should be able to download and print...
Posted on Jan 06, 2009
I have to install a remote starter ProStart 3271 ct J need to chima Electric to complete installation I need to connect the wire starter kill output
talk to prostart on custom car hacks.
only th
ey can help., after all its THEIR design.
when stuck far from home , dont expect some pro to figure out your custom wiring , for cheap, for fast or even possible.
dont hack cars! and save tons of grief and cash,,,,
unless its a toy. then hack away.
looks like you are already in trouble. sure.
(done many)
Sep 13, 2014 | 2001 Toyota Corolla Sedan
Car remote start
you need to find the wiring diagram
bcz remote starts normally have 3-5 replays
however there are other types on the market that can be operated via the factory remote only
no alarm module required
maybe the manufacturer of the device can help
Nov 07, 2013 | Vehicle Parts & Accessories
Need help with the 3 pin harness from a prostart car remeote starter ct-3460tw how to wire to my 2000 jeep tj sport with manuel trans
It looks like those are the Lock/Unlock wires with a ground for power locks that rest at ground. Your ok without them just finish your install. Good luck Sir.
Nov 03, 2013 | Vehicle Parts & Accessories
Hey MECP guy, what a job you're doing; THANKS. I want to buy the Prostart CT-5472W for a 2004 Lincoln Navigator. I also want to get addt'l modules like DEI 504D shock sensor 506T audio sensor
Yes, I frequently use DEI modules with Audiovox( Prestige and Code) alarms and remote starters. I just have to hardwire them to work with the systems.
Oct 26, 2012 | Vehicle Parts & Accessories
I installed prostart remote starter in 2002 Sonoma,used xpresskit bypass module to bypass passlock 2, truck started with remote ,now won;t start with remote,have to reset and start with truck key
If you are sure that everything is connected properly, then the only explanation could the ground when running from the remote starter to the bypass. If you are using data to data(D2D), switch over to wire to wire. Test the ground when running connection from the remote starter (white) to the ground when running connection of the Xpresskit (blue). You could even go so far as to connect the ground when running of the bypass to constant ground for the test. You CANNOT leave this wire connected to chassis ground.
Also, that vehicle has a second ignition wire(white) that MUST BE power up for remote start. If not, it will trigger the check engine light.
Oct 01, 2012 | Vehicle Parts & Accessories
I need a instalation manual for instaling a prostart ct3271 in to a 99 olsmobile intrigue
this address will take you to the pdf manual for this product... this helps. if not google prostart ct 3271 and it will take you to their site, im sure you can find more options
Dec 31, 2011 | Cars & Trucks
I installed a prostart remote starter with a universal bypass transponder. it cranks but will not start.
put your key in the ignition hole and remote start it, if it starts you need to reposition the key in the box or the loop around the igntion switch
Jan 08, 2010 | Bulldog Remote Starter & T-Harness Kit for...
Looking for installation manual for a prostart ct-3100.I would like to install it in a 2000 gmc jimmy
here is the information you requested, good luck on the jimmy, you will also need a passlock 2 bypass modual and a door lock polarity inverter, let me know if you need them as I stock these items
Dec 10, 2009 | 2000 GMC Jimmy
Vehicle Parts & Accessories Logo
629 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
