Question about Toshiba Sony CDXT69 CD Changer
CD CARTRIDGE WITH CD JAMMED IN A SONY CDX-T69
I conected a new CDX-T69. My car Audi A4 started loading the cd and was playing. For some reason I cound't get any sound. The Stereo then came up with erre message. I know the CD and Stereo work ok becase I took the same moddel CDX-T69 out of it. This had to be replaced because it would load the cartridge( I think a clip has broke?) Anyway, I've opened the top of the changer and I can see the CD Loaded and ready to go, the cartridge in in place (Locked and Loaded so to speak). When I connect it to the car and pres eject the arm at the top moves but nothing else does. CD stays in place catridge doesn't show any signs of moving, but the machine makes the noise that it's trying to do something. Can anyone help? I can't listen to the rubbish on the radio amymore during the day! Let me know Steve
  • Anonymous Nov 10, 2007
    I have the same problem, have removed unit and removed case Cd still in play position. Check power output from radio.
  • Clifton
    Clifton May 11, 2010
    Hey Steve!, I know this is an old problem on here, but did you ever figure out what the problem was with you CD changer? I have the same one and I just bought it brandnew through EBAY, it was a clearance sale. Sony doesnt make these anymore of course, but apparently im having the same problem you are. I have a Ford Explorer which I had a clarion 6 CD changer in it, and after 12 years it finally crashed, so I bought the Sony one to replace it with; not knowing that Sony is brand specific. Well, anyway, I got the right part I needed to fix that so my factory stereo would be able to communicate with it, but once I got it up and running it worked briefly at first, then I shut offf the car and came out later to leave and went to try it out and it got stuck and wont play or eject. Any Clue? Thanks, Clifton R.
sandrew
  • 2961 Answers
SOURCE: Laptop Freezes During Startup, before I can press any buttons or anything.
It could be a corrupt bios, which can be deleted with the removal of the bios battery or by the 'JBAT1' terminal to pins 2-3 then back to 1-2. The bios is probably set to halt on all errors and thats why it only goes so far. If there is no action at all; then there is a power failure to the motherboard or the processor has failed. Depending on your notebook age is whether it's economical to repair.
Posted on Jan 04, 2007
Benimur
  • 6966 Answers
SOURCE: tuning problems
Hi, This sounds like an inshop repair. The technical term for the changer being set to 88.5 but works in 97.5 is "frequency drift" and could be rectified with the use of a calibrating instrument/frequency counter and an alignment tool assuming no component replacement required. Frequency drift can be caused by component failure, humidity, temperature etc.; The part "my car off the changer stays on" could be faulty trigger on inside the changer, faulty remote trigger on in your head/radio/controller unit. Good luck and hope this gives you a few ideas. Kind regards.
Posted on Aug 23, 2007
  • 86 Answers
SOURCE: Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Posted on Feb 19, 2008
SOURCE: Sony CD interchanger CDX - T69 (how to reset?)
I have a CDX-T69 6 CD Changer and everytime I try to play it, it displays reset on my stereo screen. The CD box won't eject either. Anyone has any suggestions on how to fix this problem?
Thanks
Posted on Apr 10, 2008
SOURCE: cdx t69
VIEW THE LINK BELOW
http://www.fixya.com/support/t589604-cdx_changer_power_but_doesnt_want_eject
Posted on May 15, 2008
Does the sony cdx -gt25 work with the sony cdx t69
To connect T69 with head unit GT25,bus cable connecting port is required through which you can connect cd-changer with your head unit.As GT25 has no bus port,it does't work.
Nov 01, 2012 | Sony Car Audio & Video
Error 1 how do i fix (audi tt cdx-t69)
It means that the CD changer is malfunctioning. Mostly happends after condensation, due to it's location near the taillight. Go in the back, clean any moisture, take out the CD, and re-insert it. Problem should be solved. Audi should put this as one of the most common defects between the 99-03 a6
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 12, 2009 | Sony CDX-T69 6-Disc CD Changer
After putting CD Changer CDX-T69 changer into boot
If the CD Changer was working previous to the installation, you may have damaged the cable on installation when routing it through the vehicle.
Jul 11, 2009 | Car Audio & Video
How do you eject the magazine
Press and Slide Front half cover as shown in below image and you will see eject button there to eject magazine.
May 04, 2009 | Sony CDX-T69 6-Disc CD Changer
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Cdx t69
VIEW THE LINK BELOW
Apr 21, 2008 | Sony CDX-T69 6-Disc CD Changer
This would invalidate the warranty and you may break it but I have just had to do one:
1. Remove 4 black screws
2. Unclick the front panel - yes it is clicked on but may appear to be screwed
3. Take off black lid
4. Pop the cradled player from the 4 dampers and unhook from the 2 springs
5. Remove the ribbon connector - do this by slipping/clicking the brown holder very slightly and then the ribbon comes out easily
6. Now using a suitable tool push the stuck CD back into the magazine
7. Click the magazine out - there is a white piece of plastic what when moved does the eject.
8. Do the above in reverse.
The trick to get the grey horizontal/vertical discs back on is to set them passed horizontal one notch on and click them on at the end - turning one notch anti-clockwise to lock them.
Feb 09, 2008 | Sony CDX-T69 6-Disc CD Changer
Cds stuck in sony cdxt69
Take power away for 5min then plug back up. Hit reset with pen head.
Sep 17, 2007 | Sony CDX-T69 6-Disc CD Changer
Car Audio & Video Logo
661 people viewed this question
Top Toshiba Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Toshiba Car Audio and Video Expert? Answer questions, earn points and help others
