Question about Hitachi 43UWX10B 43" Rear Projection Television
43uwx10b what are the STK 392-110 for and what do they control, where are they located.
  • Reginald Bittner
    Reginald Bittner Jan 11, 2009
    Sorry, the IC's are STK 394-160, are they still for start up.
  • Hitachi Master
  • 5,138 Answers
They are Big Black ICs will have STK on them they are startup and convergence ICs They control set to turn on and off and convergence. Look for board that has them on it.2 of them together. If they are 110s use 180s ,Let me know what # on STKs you have.
Posted on Jan 07, 2009
  • ladywinn
    ladywinn Feb 07, 2009
    Use the same STKs for this one, 394-160
Double image, red is 2 inches off main image. convergance ic amp?
Yes, your Convergence ICs have failed. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Feb 20, 2011 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B HDTV Used to work great, now when I turn it on the power led flashes and no picture. What steps do I need to take to further trouble shoot this issue?
Replace the STK ICs,they are big black IC they will have PN# on them Replace Both ICs STK392-110s use 120s
Mats Electronics 1-800-628-1118
Oct 29, 2010 | Hitachi 43UWX10B 43" Rear Projection...
I have a Hitachi hdtv, ultravision 43UWX10B and the colors aren't aligned. What should i do?
REPLACE BOTH OF YOUR STK ICS STK392-110s upgrade to 120s or 150s call mats electronics
1-800-628-1118
May 21, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Can you recommend an online store to purchase a repair kit for a convergence chip problem?
matt electronics. make shure you get the exact replacment stk ic.s those are prob. stk-392-110 or 120 also check that no resistors are opened on the convergence module good luck
Feb 03, 2010 | Hitachi 43UWX10B 43" Rear Projection...
As stated in your response to another person (Hitachi 43UWX10B)
Your post didn't get attached to the message in which you read the 'fix' for your set so the person who helped, will likely never see it.
You might try re-entering your brand/model info and sort through the results to find the original message.
Oct 24, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi hdtv model 43uwx10b is showing a green shadow on the left side of the pictures
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Good Luck, big IRISH.
Jul 13, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Convergence problem
You need to replace the convergence Ics in this set and most likley have a resistor burnt in the red circuit. If you can solder yourself you can fix your tv for less than 50 dollars. Part number you need for the ICS is CZ00431 they are STK 392-110. Location Ik04 and 05. Like I said if you are going to do this yourself check all the resistors in this area.
Feb 06, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43uwx10b
1)Replacement requires skilled soldering technique.
2)The IC's are on the largest heatsink on the chassis.
   Chassis will need to come out==skill and/or experience needed.
3) Possible bad fuse device in power supply,check any/all.
4) Re-check alignment.
PS.Name brand IC's last longer than generics.
Oct 17, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
57 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
