Question about Sony Playstation 3 (PS3) Console
TV doesn't recognize PS3
My TV is blue and says "no signal" when I turn on my PS3. I haven't used it in months, and have only used it about a dozen times in total, but it's always worked fine in the past.
I'm running a HDMI cable into the TV. The TV picked up the signal for about 5 minutes, but then went right back to saying "no signal." The cable seems fine. I tried resetting the system by holding the power sensor for a few seconds until it beeped, but that didn't solve anything.
Anyone have any ideas?
  • 124 Answers
Put cables ps3 came with in with ps3 on standby hold power button on ps3 down 10sec and it will reset audio and visual setings
Posted on Jan 07, 2009
No PS3 signal on TV using HMDI or Component Parts
It could be that either HDMI port could be bad or you might want to try a different hdmi cable. The cable could be bad.
Jun 24, 2012 | Sony Playstation 3 (PS3) Console
Would like to hook up playstation2 can you help with this
I would suggest hooking up via HDMI or via the composite cables. Then all you should have to do is turn on your ps3, change the input on your tv to whichever port shows the ps3 or new input device. If it doesn't for some reason recognize it as ps3, you can always go into more detail using the tv to rename that port as the PS3. Hope this is what you wanted to know!
Feb 07, 2012 | Panasonic Viera TX-32LX70 32 in. LCD TV
Tv recognizes ps3 through hdmi but ps3 not giving a signal to tv
you could have a loose south bridge chip, you will need to do a re-flow.
also check any small resisters next to the HDMI port.
Jan 03, 2012 | Video Game Consoles & Games
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
My PS3 worked fine for 2 months, then just like that I get "no signal" on the tv screen. Nothing has been changed (cable or tv). I've tried holding the on/off button down till the unit turns back off, but...
Your A/V cables might not work anymore. Do you have any spare A/V cables....like from a ps2? Try the cable on your ps3 to see if you can get a signal then. If you don't get a signal it is a problem either with your ps3 or the TV. Try using a different TV, if it continues to happen than it's your ps3. I highly doubt it's your ps3 and doubt you will get to this step, but if you do what you need to do next is buy an HDMI cable and hook it to your ps3 and tv. If your tv doesnt accept HDMI than i dont know what to tell you. If you do this step and it still doesnt work than sorry it didnt work. Hope this helps, good luck.
Jul 25, 2010 | Sony Playstation 3 (PS3) Console
Blue ray wont play movies on new tv
Are you sure the tv is 1080p capable? Usually when "mode is not supported" is displayed, it means that the tv can not handle the signal format that is being input to it. If you are using HDMI, then signal formatting is usually handled automatically. If you are using component video, you will probably have to tell the PS3 to step down the signal to either 1080i or 720p.
Jan 10, 2009 | Insignia 37" LCD Flat-Panel HDTV
Ps 3 no data
Try holding the power on button down until you hear a series of beeps, each one representing your ps3 switching video modes. try this until you get a picture on your screen, then you can use the options to set it to your tv's resolution. I've seen this same problem often from people holding the button when they turn it on :3.
Hope this helps.
Mar 26, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont start up
send it back under warranty,
The power supply may be faulty.
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
My yamaha htr 6050
Make sure you speakers are turned on on the receiver,
Jan 23, 2008 | Yamaha HTR-6030 Receiver
Sony Playstation 3 (PS3) Console Logo
856 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
