Question about HP Office Equipment & Supplies
Have HP Photosmart C4200 all in one. When I changed the cartridges recently I went through the alignment routine but now every time I start the copier I have to run an alignment page, I scan it and each time it comes up with the message that it couldn't locate or didn't work or something. How do I get rid of this pain so that when I start up the maching I can just make copies without all the scan business. I only use the machine for copying - nothing else. Thanks for a reply. john
  • HP Master
  • 19,396 Answers
Thta is because you never completed the alignment procedure.
This is an all in one, after you print the alignment page, you need to place the printed page on the scanner, do a scan, and complete the alignment procedure.
Restart printer alignment from printer tools on Programs, after printing alignment page, follow instructions and place page on scanner, until procedure is complete.
Posted on Jan 29, 2009
    President:
  • 1,214 Answers
Based on advice given and efforts put into correction so far, we need to know the message that comes up.
    Scholar:
  • 140 Answers
Below is a partial entry of the help document at HP. The complete text can be found by clicking on this link here.
Essentially, there is no easy Trick to clearing this issue. The most common error made by users it in replacing both cartridges at the same time. Each cartridge should be replaced individually. Once completed the printer will want to execute a print head alignment test. This print out will include instructions on selecting the numbered lines that line up most exactly. Then you would enter the corresponding number.
Bypassing or interrupting this alignment test after replacing cartridges will cause error messages such as yours. So, if you did this out of ignorance or confusion, remove each cartridge one at a time using the method descrbed below. When both have been removed and reinstalled and the alignment process completed you should be error free. Should you still receive this error, remove and clean each cartridge using the method described below, one cartridge at a time.
If after completing all the steps below, you still receive the error message, your printer has a larger problem that is internal hardware related. You can either replace the printer or have it serviced by HP. Most people opt to replace the printer as an error such as this at the internal hardware level usually indicates that the printer has reached the end of its usable life span. If this is happening prematurely, have it serviced under warranty. Printer warranties are usually one year from HP. If you purchased using a credit card you may have an extended warranty. Check with your card company right away for information on any extended warranty you have from using your Credit Card.
If you have any further questions, please ask me using the comment box below.
Regards,
Worldvet
Solution one: Remove and reinsert the ink cartridges
  1. Turn the product on.
  2. Make sure to have letter or A4 unused, plain, white paper loaded in the input tray.
  3. Open the ink cartridge door.
    NOTE: Make sure that the carriage holding the ink cartridge moves to the right. If it does not move to the right, turn the product off. If it is a new product, make sure all the packaging material is removed. Close the ink cartridge door and then turn the product on again. The carriage should move to the right. Figure 1: Opening the ink cartridge door CAUTION: The product must be turned on before the ink cartridge door is opened. If the product is off when the ink cartridge door is opened for access to the ink cartridges, the product will not release the cartridges. The product can be damaged if the ink cartridges are not docked safely before removal.
  4. Wait until the carriage is idle and silent, and then lightly press down on an ink cartridge to release it. The error message should indicate the problem cartridge by displaying an icon that represents it.
    • The tri-color ink cartridge is in the slot on the left.
    • The black or photo ink cartridge is in the slot on the right.
    Figure 2: Pressing down on an ink cartridge to release it 1 - Ink cartridge slot for the tri-color print cartridge 2 - Ink cartridge slot for the black and photo ink cartridges
  5. Pull the ink cartridge toward you out of its slot.
  6. Make sure the tape has been removed from the cartridge. If the tape has not been removed, remove it now. Figure 3: Removing the tape CAUTION: Do not touch the copper-colored contacts or reattach the tape.
  7. Hold the cartridge with the HP logo on top.
  8. Reinsert the ink cartridge into its slot by gently pushing the upper part of the ink cartridge forward until it clicks into the socket. CAUTION: When installing the ink cartridge, do not rest your hand on top of the product for leverage. This might cause the carriage to lift out of position. Figure 4: Incorrectly grasping the top of the product for leverage Figure 5: Pushing the cartridge in firmly
    • When installing the tri-color ink cartridge, slide it into the left slot.
    • When installing a black, photo, or gray photo ink cartridge, slide it into the right slot.
    Figure 6: Tri-color cartridge in the left cartridge slot and black cartridge in the right cartridge slot
  9. Close the ink cartridge door.
If the error message persists, continue to the next solution.
  • HP Master
  • 4,806 Answers
Hello John
its really quite simple, check that the cartridges are seated properly first of all, power off the printer and remove the USB lead from the PC, then uninstall the printer software and restart the PC so that changes are made in the registry.
Start the PC again and reinstall the printer software (connect the printer lead when prompted) then realign the cartridges and print a test page!!! your problem should now be solved
Good luck and kind regards
Posted on Jan 06, 2009
    Genius:
  • 1,847 Answers
Did you try reset the machine and reinstall the software..
    Sergeant:
  • 378 Answers
At the time when allignment comes out you have to place the allignment sheet on the scanner up side down and then press the scan button.and wait till the on/resume button stops blinking.do it two times continuisously.
  • HP Master
  • 13,433 Answers
Try a semi full reset
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord. Continue holding until it displays Semi Full Reset message in the front panel of the All in one
See if the issue is resolved.
Why do my pictures have tiny black lines running vertically thru them when I print pictures?
Hi
If you have recently changed one or more of the cartridges you may need to align the print head, the following steps explain the process:
To align printer from the printer display
1. From the Home screen, touch the Settings icon, and then touch Tools.
2. On the Tools menu, touch the down arrow to scroll through the options, and then touch Align Printer.
3. Follow the instruction on the screen.
To align printer from the printer software
On Windows:
a. From the Start menu on your computer, click All Programs, click HP.
b. Click the HP Photosmart 5520 series folder, click HP Photosmart 5520 series.
c. Under Print, double-click Maintain Your Printer.
d. Under the Device Services tab, double-click Align Printheads.
These instructions were copied from the manual at the following link
http://h10032.www1.hp.com/ctg/Manual/c03353113
If this doesn't fix the problem, you may like to check the HP support page for the 5520 at the following link ---> support hp com
Trust this helps, best regards Alan
Feb 11, 2015 | HP Office Equipment & Supplies
My hp photosmart C420 will take the commands but will only print blank pages
maybe u check the laser or a transfer belt or some contact bias from a cartridge
Feb 19, 2013 | PrintCountry HP Photosmart C4200 Series...
HP Photosmart with FAX C410B. When I do an alignment test is comes up with the error message 'alignment failed'. I have tried taking the cartridges out and cleaning them but this has not worked....
Best thing to do is use the printer driver software to do a nozzle check. If the output has a problem, run the procedure to clean the nozzles. There is also the possibility if you are using refilled cartridges the quality of the cartridge housing has itself deteriorated making changes in the nozzle & air hole so the only way you can confirm is by using new original cartridge replacement.
Jun 30, 2011 | HP Photosmart C5180 All-In-One InkJet...
My HP photosmart c4280 keeps aligning the cartridge when on!
probably the alignment its not succeed
be cause on of color is missing
check if you see and the 4 colors on paper (yellow cyan magenta black)
if one color is try cleaning , refilling or replacing the cartridge
if you need instructions for refilling check here
http://www.youtube.com/watch?v=Ybj4awp_1ic
May 01, 2010 | HP Photosmart C4240 All-In-One InkJet...
Incompatible print cartridge
Take out the print cartridge. Clean the points on the cartridge with cotton swab and try using it again.
Nov 04, 2009 | HP Photosmart C4480 All-In-One InkJet...
HP photosmart C4200 - alignment disable
I've run into this problem. The first simple thing to look at is the aligment page itself. Does it have colors on it or is it strictly greyscale/black and white? If your color cartridge is empty/a knockoff/not installed correctly, the printer will just print the alignment page in black/white and not necessarily notify you of a problem. However, the cartridges won't align if the aligment page isn't printed in color.
This is clearly a screw-up by HP, because there is nothing to notify you of this problem in the software or manual. The printer will automatically print an aligment page, and then tell you to scan it. If they did it right there would be some error message notifying the user that it couldn't print an aligment page rather than print one that is worse than useless.
Sep 03, 2009 | Office Equipment & Supplies
HP Photosmart 3310 printer shows all ink cartridges need replaced
If you ran the ink cartridge refill routine, from your desktop using the utility supplied by HP, this should not occur, so try running the head cleaning and alignment routines and see if this clears up the problems.
I am assuming that all your cartridges are relatively full and trouble free and that the printer has been successfully and recently used, prior to your replacement of the one new cartridge.
Sometimes, if the printer has been idle for some time without use, the ink will dry on the heads of perfectly good cartridges, causing the problem you cite.
Use alchohol based cleaner with the kind pads supplied with a new cartridge to regularly clean the heads of your ink cartridges, according to instructions in your manual and CAREFULLY, so as to not damage the heads.
Apr 07, 2009 | HP Photosmart 3310 Printer
Trouble with scanning and printing
One of my friend faced a similar problem and he referred this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00880901&lc=en&cc=us&dlc=en&product=3192753&lang=en
Please let us know if the solution solved the problem and kindly rate.
Jan 06, 2009 | HP Office Equipment & Supplies
Have just unpacked new HP Photosmart C4200 All-in-One Cannot get machine to accept cartidges which werre supplied with the printer
NOTE: The product must be on before you can insert the print cartridges.
  1. Open the print cartridge door. Figure 7: Opening the print cartridge door c00880893.jpg
  2. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  3. Open the packaging and remove the tape from both cartridges. Figure 8: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges.
  4. Hold the cartridges with the HP logo on top.
  5. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot . Figure 9: Inserting the print cartridges c00880895.jpgc00880896.jpg
  6. Push the cartridge firmly into the slot until it snaps into place.
  7. Close the print cartridge door.
Step eight: Align the print cartridges When a new print cartridge is installed, the product aligns the cartridge. Align the print cartridges at any other time by using the software installed with the product. Aligning the print cartridges ensures high-quality output. NOTE: If a print cartridge is removed and reinserted, the product will not prompt for an alignment. The product memory retains the alignment values for that print cartridge. Follow these steps to align newly installed print cartridges.
  1. When prompted, make sure that plain, white letter or A4 paper is loaded in the input tray, and then press the button next to OK . The alignment page prints.
  2. Lift the lid. Place the top of the alignment page face-down on the front, right corner of the scanner glass. Figure 10: Placing the alignment page c00880898.jpg
  3. Close the lid.
  4. Press the button next to OK . When the On button stops flashing, the alignment is complete and the page can be removed.
Nov 18, 2008 | HP Computers & Internet
23 people viewed this question
Seeker5211
Seeker5211
