Question about Maytag MER6772 Gemini Electric Kitchen Range
MER6772 front burner......is there a fuse that controlls the out
Inner circle works and the outer doesnt....ive openned the stove and removed the switch...tries touch the two wires together and nothing happens
    Sergeant:
  • 311 Answers
Sounds some like you know a little about appliances.if power is leaving switch and burner not working.its your burner.take a look at wiring diagram it will show you the power path, use volt meter[looking for out put at switch],[the limiter that you see in wiring diagram is built into the burner and can not be replaced by its self]so if power leaving switch replace burner.hope that helps.God bless ,tom
Posted on Jan 06, 2009
Testimonial: "great"
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
Jan 30, 2013 | Dacor Millennia ETT304 Electric Cooktop
My GE profile electric range (model PS905SPSS) has a power boil burner with dual burner elements (one inner circle and one large outer circle). The outer circle one is glowing and heating but the inner...
Disconnect power to range. If you have an ohm meter, you can check the burner coils for continuity from the wires at the switch. If not, open oven door, remove screws holding top. Lift up top and remove screws holding the set of burners in question and visually inspect the inner coil for a break in the burner coil.
Nov 27, 2010 | GE Ovens
One of the dual zone stove burner stopped working. The inner one has stopped the outer ring is still working
You have to determine if the control or the burner is bad. Only way is to verify power from the control. If power is there the burner is bad. If the control is not powering the burner then the control is bad. Rarely is it both but not a impossibility. 240 volts so a trained professional is preferred.
Eric
Dec 05, 2009 | Whirlpool GR448LXPQ Electric Kitchen Range
Inner burner -- front right burner - does not heat up
You will have to check your stat.this is the switch which controls the power to both parts of the ring.It may be faulty.This is a thermostatic switch.It can be checked with a mains test lamp.If this is ok then check the spade terminals are still intact at the ring itself.
Oct 12, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore Kitchen Ranges
Had a power outage and since then my inglis digital stove does not work. all the light's come on but no heat on burners or oven.
my control panel doesn't light up for both ovens and the clock too. The porclain stove top all five panel do work... could i have blown a fuses? in the oven its self .
Apr 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Problem w/burners & lights after self clean
You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows.
First, unplug the range.
LIFT–UP PORCELAIN COOKTOP
To lift:  When cool, grasp the cooktop front
edge.  Gently lift up until the two support rods
snap into place.
To lower:  Hold the cooktop front edge and
carefully push back on each support rod to
release.  Then lower the top into place.
COIL ELEMENTS
➢When an element is on, it will cycle on
and off to maintain the heat setting.
➢Coil elements are self-cleaning. Do not
immerse in water.
To remove:  When cool, raise element.  Carefully pull out and away from receptacle.
Check them for damage. They do wear out.
To replace:  Insert element terminals into receptacle.  Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl.
COIL ELEMENT SURFACE
➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(800)688-9900 U.S.
(800)688-2002 Canada
Dec 03, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
188 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
