Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Not enough hot water
I have two moen shower fixtures, that I cant find numbers on, when turned all the way on I have hot water, but not until they are turned at least 90 percent of the way on, I notice that I have to set screws on the shower valve. Assuming they regulate the amount of water going to the shower head? this is a single handle shower valve, can I balance the amount of water by adjusting these Screws? I also see theres a snap ring holding them in?
  • low_et_1320 Jan 08, 2009
    Very helpful, and very fast, I just did not explain my problem well enough, Can't blame the FixYa guys there......Thanks and look forward to future support
    President:
  • 2,692 Answers
The screws remove the handle. After the handle is removed their are little plastic like gears to limit th ehot watr. Relocate the gear ring for more hot water.
Posted on Jan 06, 2009
I purchased a Moen L82691SRN "shower only" fixture. I hooked it up and can only get cold water to come out of shower head. When I turn the handle to the "hot" side it will only trickle...
You have purchased a scald guard faucet, that you will have to set for your own house. If you take off the handle and face plate and look down there should be a plastic part (usually a deep blue) with teeth. It restricts the hot water side of the unit. If you pull it out and rotate (about halfway) you should have water flow. If it is still not hot enough rotate it more, or less.
Jun 26, 2011 | Moen Home
All hooked up dobble cked but water only trickles so ample supply
Make sure the hot water is turned back on. Pressure balancing valves won't work if both cold and hot water is not on. Pull shower head off and test to see how it flows out of the shower arm. If good, clear out shower head. Whenever water is turned off for a time, and then turned back on, restricting shower heads and aerators usually get clogged. In the future, always open up a tub spout before turning water back on. This releases the air and other debris most effectively before testing other fixtures in the house.
Apr 23, 2011 | Moen 3175 Legend One Handle Shower Faucet...
Moen Kingsley Moentrol single handle bath/shower fixture. Had guests use this recently and they only could get hot water. When you turned the handle to cold nothing comes out. Only hot when turned the...
Sounds like the cause of your problem is the pressure balancing spool. Call Moen at
1-800-289-6636
and explain the problem. They will send a repair part to you free of charge. the link below is a "blow up" of your valve.
http://www.moen.com/shared/pdf/t3113pt.pdf
Mar 10, 2011 | Moen & One Handle Tub & Shower Faucet
Moen shower valve turns on full to cold water but flow becomes minimal when valve is turned to warm/hot. not getting enough warm water to shower. can this be fixed without rplacing the valve?
yes and no. Find hot water heater and insure cold water supply valve is open all the way. check to see if there is a hot water supply value and that its open all the way. If you replace shower value over iron pipe on the hot side it is corroded up replace pipe and value. If copper, find hot side, find value and open it up.
Nov 28, 2010 | Moen & One Handle Tub & Shower Faucet
Moen kitchen faucet. I changed the cartridge but
Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Single handle moen bath fixture only lets out hot water
remove the cartridge and see if their is anything blocking the cold inlet.If you dont see any dirt than that means that the cartridge needs to be replaced
Jan 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
433 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
