Question about Daewoo KOR-630A Microwave Oven
Microwave stopped working
It did like this before[when it was still in warranty] and the tech at deawoo said to unplug it and let it sit for a couple hours then plug it back up. did it and it worked. but now it does nothing and i tried the same thing unplug it and let it sit then plug it back up nothing any suggestions thanks
  • 1 more comment
  • rick faulkner May 26, 2007
    this time the ground wire that grounds the side of the case was off and the bulb had melted of the soulder and fuse was blown.as for the bulb i resouldered it back in the socket hooked the ground wire back up after squeezing the terminal so it would fit tight and replaced fuse and it works
  • rick faulkner Nov 03, 2007
    fixed it ........ it was a door switch the one that is hid behind a panel. put new switch in and she works again.....
  • Anonymous Jun 08, 2008
    just used the microwave, it worked fine. Took out the popcorn closed the door and it is like there is no power to it. I checked the fuse box but it did not blow.
  • 38 Answers
Please be a little more specific no power or no functions .open cover and check fuse if no power ineed more info sorry
Posted on May 24, 2007
My GeE Profile model #PEB1590SM2SS microwave isn’t working. The turntable spins when the door is open, but it won’t spin or heat anything up during operation.
First, I'm not a GE tech
* STOP!
* Door opened should turn off all power except the display. This is a safety measure,
* Unplug and DO NOT use!
* Check warranty. Call for service.
* Check with store or vendor for replacement.
Aloha, ukeboy57
Jul 21, 2018 | Microwave Ovens
Microwave just stopped working
It may be a blown main fuse, or that one of the thermal fuses (cut-outs) has operated and not reset.
Take it to a competent service tech for a cost estimate (the cost may approach that of a new oven), but don't mess with the insides yourself. Microwaves have dangerous high voltage inside, possibly even when unplugged.
Aug 31, 2013 | Whirlpool MH7130XE Microwave Oven
My recently purchased Rival RGST902 microwave stopped heating. Everything else works, it just will not heat.
HELLO.
The first wayout is to consider WARRANTY.If the microwave is under warranty return it to the point of purchase to enjoy warranty right.But if the microwave is not under warranty another wayout is needed.
Below is the solution on how to make our microwave heat food.
1 Remove oven racks and place them in soapy water to soak.
2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thanks.
    Sep 20, 2011 | Microwave Ovens
    When start Microwave after a couple seconds it stops and asks you to set the clock again.
    The magnetron on most all microwave ovens is tied to the microprocessor that drives the display and the input from the keypad.
    Check you manual to see if it comes with a self-diagnostic (higher-end microwaves from Panasonic, LG and Jenn-Air come with them) and run it (normally kicked off by a keypad sequence).
    If unplugging the microwave and plugging it back in after about 15-20 seconds doesn't correct the problem, then I'd get it serviced if under warranty. Microprocessor will need to be replaced most likely. If not covered under warranty then you're looking at out-of-pocket repair or replacement.
    Jun 22, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave will not stop cooking unless I open door
    you have a bad door switch call a tech these things can kill you even if they are unplugged.
    Jan 07, 2010 | Amana MVH210W Microwave Oven
    Works fine before unplugging, stops working when plugged in again
    Westinghouse WST3504 User Instructions Before Calling For Service
    YOU CAN OFTEN CORRECT OPERATING PROBLEMS YOURSELF
    AND TRY THE SOLUTIONS LISTED FOR EACH PROBLEM
    Note: If the Microwave Oven still does not work properly, please contact Service and Repair
    located on Warranty page. 19
    BEFORE CALLING FOR SERVICE Possible Causes
    • Is the power cord plugged in?
    • Is the door closed?
    • Is the cooking time set?
    Feb 01, 2018 | Westinghouse WST3504 Microwave Oven
    Microwave stopping
    That's a bad magnetron. In this case, it will be intermittent until it goes out completely.
    You have a 5 to 9-year warranty on the magnetron. See your manual for that.
    You can download GE owner's manuals and installation instructions here.
    GE Customer Service is here and they can help you arrange service.
    Dec 02, 2008 | GE XL1800 1100 Watts Microwave Oven
    No more heating, GE Profile Microwave JVM 1870CF02
    I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
    Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
    LG MS-283MCG Microwave - had a fault when we first bought it, engineer replaced an internal fuse. Stopped working again years ago in the same way, been sitting in a cupboard since then. Hardly used since...
    Microwaves usually have a small ceramic fuse inside. White with metal caps about 1 inch long. You can change it yourself but please follow these rules:
    • Always make sure the unit is unplugged when doing this.
    • Replace the fure with the same type of fuse. Don't use a glass fuse if the original is ceramic.
    Other than that, I hope that fixed ya...
    Geno
    Apr 02, 2008 | Microwave Ovens
    Oster Microwave/Convection/Grill
    first, get your money back or get a replacement for no charge. now, unplug the oven for 15 minutes and try again. if no-go, then some device is faulty that only a tech can find
    May 28, 2007 | Sharp R-930AK Convection/Microwave Oven
    Daewoo KOR-630A Microwave Oven Logo
    450 people viewed this question
    Top Daewoo Microwave Ovens Experts
    William Miller
    William Miller
    Ian Summerfield
    Ian Summerfield
    Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
