Question about Garmin iQue 3600 GPS Receiver
Unable to update my ique 3600 to r3 from r2
When I try and run the updater I keep getting the following error:
Update Error - Routes and tracks are using too much memory to perform this update. Please delete some routes or tracks and begin the update again.
I have cleared and verifed that both are empty, have hard reset and wiped data but still no luck.
I want to get to r6 but need to get to r3 first. When I apply r6 the ubit powers off with garbage on the bottom of the screen. When I reset the updater files are gone but the update does not take.
Any help would be appreciated.
  • 3 Answers
SOURCE: iQue 3600 sim card problem
from Garmin:
Why wont the PC recognise my the SD card in my iQue 3600?
--> Answer: Go to My computer and look for the following directory:
  • C: > Program Files > Palm > (user name) > file called 'sync'
  • Double click on this file and delete the four bottom rows that will look something like this:
DisplayName=SecureDigital (SD) Card
  • Then try a HotSync as normal, it should then 'see' your SD card.
  • If all fails delete a second user name as sometimes this interferes.
Posted on Mar 29, 2008
SOURCE: Garmin Nuvi 200 2009 Map Update
Here's what worked for me. Nuvi 200 brand new w/2008 trying to upgrade to 2009.
After registering and download the map 2009, I started the install. I go to a point where I was told I needed 37MB more room. I went thru windows explorer and looked in the Nuvi. I went into the language folder and moved all of the languages I didn't need to my hard drive. I then went into the HELP folder of the Nuvi and again removed the all of the languages I did not need. I then went back to the install program and hit retry. All good from there. I hope this helps.
Posted on Jul 12, 2008
SOURCE: iQue 3600 Fatal Alert
You'll have to do a hard reset. Push the reset button, then hold the power button until the Palm Power appear and then release the power button. Next it will ask if you want to erase the data. I hate to said this but select yes. No will not work. Then after the inital set up run a HotSync.
Posted on Nov 11, 2008
SOURCE: Garmin zumo 550 map update problem
  1. Make a backup of your Zumo by copying all the file to your computer.
  2. Using your PC and MapSource select all the maps then send them to a SD memory card need 2Gig or bigger card.
  3. Try to rename this file to gmapprom.img and replace the same named file in your zumo. (I haven't tried this personally, so if it fails, just replace this with your backup and all will be as it was.)
  4. If this fails, you can use the SD memory card in your zumo and it will use this map instead, but it will take longer to boot your zumo.
Posted on Apr 11, 2009
  • 40 Answers
SOURCE: Ique 3600 antenna reception problem
I have three iQue 3600, one with a dead antenna. I added an external antenna I bought off eBay (Gilsson is a good brand) and it works. The iQue antenna is not very good compared to a more modern device so your performance will improve.
Posted on Jan 23, 2010
Windows 7 Update
Follow this article
System Update Readiness Tool fixes Windows Update errors in Windows 8, Windows 7, Windows Vista, Windows Server 2008 R2, and Windows Server 2008
Jan 13, 2013 | Lenovo Computers & Internet
Garmin iQue 3600 has a blink screen
if it will not power up, you don't have many options.
unscrew the head of the sylus to access the rest tool
Press the reset at the back with the stylus
This is re-booting, all data safe still here.
Hard reset is last erased here.
Press the reset button again as above
after you release, press the power button, keep pressing until the message
( all data stored is about to be erased )
to complete the reset press the upper half of the scroll button, on the front,
The digitizer screen appears
pressing any other button here performs a soft reset.
Update it if you get it up and running.
Hope this helps
Mar 22, 2009 | Garmin iQue 3600 GPS Receiver
No backlight on my Garmin IQue 3600
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
If your problem still continues then you need to take your gps to near by shop to get it repaired .
Feb 03, 2009 | Garmin iQue 3600 GPS Receiver
Can not play
If you are running Vista, run R2 as Administrator (Right Click on R2 and click RUN AS ADMINISTRATOR)
Jan 03, 2009 | Ubi Soft Entertainment The Settlers: Rise...
IQue3600 maps unavailable
You can get City Navigator 2008 CD from your local Garmin dealer. Cost around $100.
It updates via MapSource program and USB connection to IQue 3600.
Do not get "NT" maps as 3600 does not understand "NT" compression
Sep 23, 2008 | Garmin iQue 3600 GPS Receiver
Garmin ique 3600 mapsource Synch problem with XP
Are you running Vista? If so, contact Garmin for a download that allows the maps to be loaded.
Apr 13, 2008 | Garmin iQue 3600 GPS Receiver
IQue 3600 missing disks
The simplest method is to update the software for the Mapping/Data, the one you probably had is sooo out of date!
City Navigator North America 2008 DVD
MapSource City Navigator North America
(includes access to the whole disk)
Garmin Part Number: 010-10474-00
U.S. List Price: $139.27 (for domestic US market only)
Sep 26, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
