Question about Maytag PYE2300AY Electric Dryer
Electric dryer makes a rumbling when tumbler is turning.
Maytag electric dryer is 15 years old. It just started making a rumbling noise while the tumbler is turning and drying clothes. Sounds like a bearing is going out. Is this the problem or is it something else?
  • Anonymous Mar 22, 2014
    Dryer makes a large rumbling sound
There are two rub pads on the inside of the front cover that the drum rests on. I would guess one of these has worn through. It's easy to check it out by taking out the two lower screws on the front panel.
Posted on Jan 07, 2009
  • Maytag Master
  • 19,396 Answers
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Posted on Jan 06, 2009
After 15 years of service I imagine it will be hard to get the parts you want to repair it.. Newer machines may not dry as quickly as the older types but they use less power to do so.. Consider a new machine for the sake of the economics of the problem
Jul 26, 2013 | Maytag Neptune MDG5500AW Gas Dryer
Maytag my dryer just makes a humming noise without spinning. then i got it to start spinning again. this is a new problem never had it before although the dryer is 15 years old
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
Dec 23, 2010 | Maytag PYE2300AY Electric Dryer
My older Maytag dryer is making the classic rumbling noise when running. Heat seems fine. I can turn the tumbler by hand and sound like one of the tumbler wheels is vibraiting or wobbeling. what else...
Replace all drum wheels. I would replace the idler pulley and belt if the belt looks worn. Check front and rear felts for excessive wear. Check the blower wheel. Here is a link that should help
Aug 09, 2010 | Maytag Dryers
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
Maytag SD-8 about 10 years old. Making clunking
The reason to this problem is due to the bearing.
Sep 02, 2009 | Maytag PYE2300AY Electric Dryer
Rumbling noise in maytag gas dryer DG110 series 01
Unplug Dryer first: Page 3-11 of full service manual at link below will get front off. The most common solution for your problem is the blower wheel loose on the shaft. Hold drum and see if you can turn blower wheel (lower left plastic squirrel cage) separately. If you can turn the plastic wheel while you hold drum still, replace blower wheel.
Aug 22, 2009 | Maytag PYE2300AY Electric Dryer
Bosch dryer making rumbling /grinding noises low frequency
you might want check the rollers that tub rides on they are in the front lower part of the dryer, or the belt that turns the tub.
Jun 23, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer makes rumbling sound when starting
If you remove the front cover and access the blower fan and see if it is still tight on the shaft. if it isn't it makes a rumble sound when started due to vibrating and after a while it makes more noise as it goes. Now I removed the fan and placed a shim in the flat area and matched the flat area of the shaft and replace it back on the shaft and it should solve it.
Mar 21, 2009 | Maytag MDE2600 Electric Dryer
Maytag dryer making clanking noise
I had this problem and the cause was a loose screw holding on one of the "paddles" inside the drum. I removed the door, front panel, lifted the top, manually rotated the drum until I saw the screw head which had worked loose and was slapping the side of the dryer. A quick tighten of the screw and the noise was gone.
Jan 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loud Noise when drying....
hi thanks for the question tome iot sounds like the blower a rumbling noise and the dryer takes too long to dry so i would check that thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
372 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
