Question about Sony RDR-VX515 DVD Recorder/VCR
Rca cables in place of component cables
If I put the red/white/and yellow rca cables in the component cable jacks (yellow/green/blue) in back of a dvd player and then put the same colors in the component ports of the tv and then use a separate audio cable would that give me the same quality of picture as using actual component cables?
It does work but I don't know about the quality. Its still 3 cables for the picture isn't it?
    President:
  • 846 Answers
Typically the Yellow is video and Red and White are Sound. So only one is for video two are for sound normally.
Basically they are about the same thing, the only difference there will be cables are made different. Some cables are better than others at transferring signals be they video or sound. So quality might be affected slightly.
Posted on Jan 06, 2009
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Is i possible to connect a rca cable to the converter box from a dvd player and watch on the tv?
DVD players can have several outputs:
* coaxiable cable
* composite video (RED/WHITE for stereo audio, and YELLOW for video)
* component video (RED/BLUE/GREEN to video components, plus RED/WHITE for stereo audio)
* HDMI
TVs can have several inputs:
* coaxiable cable
* HDMI
Just use the correct tables to "match" the output to the input.
Feb 21, 2011 | RCA (DTA800B1) Video Converter
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
Oct 07, 2010 | Nintendo Wii Console
How do i connect my dvd rv32 to my sony tv?
It will depend on your TV's inputs. The included cable is a composite A/V cable. This will work. Match the RCA plugs on each device (yellow to video out on the DVD player, video in on the TV; white and red audio go similarly). Alternatively, you can get and use an S-video cable.
For a better picture if your TV has Component video, get a Component video cable (this has three RCA jacks colored red, green and blue on each end) and then use that. You can get a separate audio cable that only has the red/white RCA jacks (or use the composite video with the yellow video jacks dangling).
If your TV doesn't have Composite video inputs, you need a RF modulator (Composite to RF converter). These are available at many sites, including Radio Shack.
I hope this helps.
Sep 06, 2010 | Panasonic DVD-RV32 DVD Player
The picture is green
Make sure that the unit is connected to the tv properly. Be aware that most dvd players have six connections. You can connect the unit to the television using RCA cables (yellow, white, red) or RCA sound with component video (white, red, blue, green, and red). When using the yellow-white-red method, the sound is carried by the white and red cables and the video signal is carried by the yellow cable. If you're using the white-red-blue-green-red method, the white and one of the red cables carries the sound, and the blue-green-red cable carries the video signal. This connection uses one cable for the green component of the picture, one for the blue, and one for the red. Make sure that the cables are connected properly and you don't have the two red ones mixed up. Connect Sound-R to Sound-R, component R to component R, etc. If that doesn't work, you may be able to adjust the picture on the tv. There's still a chance that the machine is defective.
Mar 08, 2010 | Daewoo DVRS04 DVD Recorder/VCR
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
2) COMPOSITE VIDEO (Yellow)
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
May 04, 2009 | Televison & Video
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
Hookup
very simple , just made sure dvd output hooked to the input of your tvs and same color ,jack to jack,you know, yellow to yellow,red to red ,white to white.But I suggest you use a s-video jack(all black). instead of the yellow composite ,or RCA jack,which give you a better picture,and if you have a the component jacks (red, blue , green)on both machine , that will give you the best picture, but remember , you still have to connect the red(right channel,+))and white(left channel,-)cable to have sound coming out from your tv.You will need a s-video cable or component cables for those option I suggested.
Nov 17, 2007 | Sony DVP-NS55P DVD Player
Sony RDR-VX515 DVD Recorder/VCR Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
