Question about LG VOYAGER VX10000 Cellular Phone
I can't see who is calling me
All the calls that i getting always i can't see who it's
    Problem Solver:
  • 3 Answers
Your service provider as removed your caller I.D you must contact them to get it turned back on.
Posted on Jan 07, 2009
I forwarded my cell phone calls to my house phone. I cannot deactivate call forwarding. I have a Samsung S7
  • 1.From the home screen, tap Phone
  • 2.Tap More
  • 3.Tap Settings
  • 4.Tap More Settings
  • 5.Tap Call Forwarding
  • 6.Tap Always Forward
  • 7.Enter the number you would like your calls forwarded to and then tap Enable
  • 8.To disable call forwarding, swipe down from the top of the screen
  • 9.Tap the Call Forwarding notification
  • 10.Tap Always Forward
  • 11.Tap Disable
Samsung Galaxy S5 How to Setup Call Forwarding
Feb 11, 2017 | Samsung Cell Phones
Dial out always busy
View topic - Fast Busy Signal when Calling out - Ooma
www.ooma.com/forums/viewtopic.php?f=4&t=13773
May 15, 2012 - I'm out of town, but yesterday I tried calling a few numbers and alwaysgot the fast busy. Incoming calls were fine. I rebooted the telo and it still ... Can't Dial Out To Same Area Code
Feb 4, 2014
Can't dial out
Dec 3, 2011
Can't make calls, can't receive calls, but I have ...
Sep 13, 2011
cannot dial out and dial in
Nov 1, 2010
More results from www.ooma.com
Jan 26, 2016 | Cell Phones
I updated my cc info tried to buy book said there was a problem What now?
The best way to get help is to call AMAZON Customer Service866-216-1072. You can be forever trying to solve this unless you call them. You will get faster results this way. Been there and done that! Hope this helps.
Apr 04, 2015 | Amazon Kindle Fire HD
Nortel Norstar M7208 always reads "Calls For You". What can i do to clear display?
This is Caller ID log
FEATURE 812 View Call Log
FEATURE 813 Manual Call Log
FEATURE 815 Deletes Call Log Items
To have no log see your office administrator or call your local tech to De-program your phone from the system log.
Nov 28, 2012 | NorStar M7208 Corded Phone
Getting this message .call divert set. what is it and how do i get rid of ot ???
When you make a call it will say this As while your in a call it will need to divert calls to voicemail as you cannot answer two calls at once..
Don't worry about this, If its Set for always diverting then In settings > Call or network settings you can disable all diverts.
If its just appearing when making a call then ignore it, Its perfectly normal.
Aug 11, 2010 | LG Shine KE970 Cellular Phone
Samsung U700 cant get calls says I am not
try to check the settings of the phone. see if you have call barring for incoming activated ~ menu ~ setting ~ call settings ~ voice call ~ call barring ~ make sure all incoming calls is set to DEACTIVATED
you can also try to check if call divert is also set ~ menu ~ setting ~ call settings ~ voice call ~ call diverting ~ make sure always is set to DEACTIVATED
hope that helps.. :)
Sep 18, 2009 | Samsung SGH-U700 Cellular Phone
I recieve calls from a friend abroad and keep
there is some problem with your handset.
give it for servicing.
Jun 16, 2009 | Lands Phones
Fax wants to pick up voice calls.
Xerox has what they call a feature that is called Fax priority.
It means no matter what, it will ALWAYS prioritize an incoming fax
Believe me, I have fought this one several times. Xerox Engineering has told me that is how it is designed, to make sure you get your fax.
There is nothing you can do about that except get a dedicated fax line .It is called Fax priority. and you can not over ride it.
May 26, 2009 | Xerox Phaser 3200MFP/N Laser Printer
Night Service and Diver All Call to Voice Mail
make sure the call rerouting always is setup and points to the vm huntgroup, then check the call rerouting assignment points the answer point extn number to the relevant always alternative in night1 and night2 mode
ie; always alternative 10 set all to Reroute and supply vm huntgroup number then program call rerouting assignment for extn during night1 and 2 to 10.
let me know if this resolves the issue if not it could be a number of other timer related / vm configuration / call routing problems which might require a more indepth investigation
Feb 09, 2009 | Mitel 5020
INCOMING CALLS
Hi there, it is possible that you have the G1 set into "always Forward" state, which means when receiving calls the phone will forward the caller to your voicemail.
To Check and change these settings. goto the G1's Home screen, Click the "Menu" button, and then click on "Call settings". Then from here click on "Call Forwarding".
From here, the top setting should say "Always Forward" If this is set to Enabled, click on it and select Disable. This should now allow you to receive calls correctly ! if the Always forward function was disabled already, i would suggest calling T-Mobiles Customer support line to see if they have a remedy to this situation !
Hope this helps ?!
Oct 27, 2008 | HTC G1
LG VOYAGER VX10000 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
