Question about HP Photosmart 8250 InkJet Printer
I have hp8250 photosmart printer it will not print magenta. all cartriges are genuine hp. I have cleaned printer heads numerous times. The problem is magenta only and no error codes show. when I print a test page magenta prints very lightly. I have done a repower and removed all cart. and reinstalled. Hope someone can help. Doug
  • destolley Feb 03, 2009
    The magenta ink cartridge is blurting ink on my HP Photosmare 8250 - I have replaced the cartridge and using genuine ink.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
My HP Photosmart 3210 Printer does not Print Red.
WELL IT'S 5 DEC 2012, THIS HP 3210 QUIT MAGENTA'S.
WENT TO TOOLS TO CHECK LEVELS, NO YELLOW, GOT NEW CARTRIDGE, TEST SHOWED NO MAGENTA'S. REMOVED RIGHT SIDE COVER (GENTLY) AND REMOVED ALL TEN CABLES AND REINSERTED CAREFULLY. TESTED AGAIN, AND HAD LINES ONLY ON BOTH LIGHT AND DARK MAGENTA'S,
RAN CLEAN HEADS, SIX TIMES AND ALIGN PRINTER ONCE.
PICTURE GOT BETTER AND BETTER FINAL TEST DIAGNOSTIC PAGE PERFECT ALL SOLIDS. GOOD LUCK KEEP GOING
Jun 08, 2012 | HP Photosmart 3210 Printer
I have an HP Photosmart 8250. I changed the Magenta cartridge and it seemed to work fine for a while and now when I print, the Magenta fails to come out. I have a Purge test that is basically an entire...
please if you are not professional technician then don't do this.but you can use some cartridge head cleaning solution.on the print head.if problem not solve then replace the cartridge.
Jan 12, 2011 | HP Photosmart 8250 InkJet Printer
I installed a new magenta cartridge but it still says you need new magenta color
Try replacing the magenta with another cartridge whether refill or genuine new cartridge. Usually if the cartrige is faulty the retail store you purchased it should exchange it for you. If problem still persist clean contacts where cartridge sits in printer with wet qtip and carefully clean area, also do same to cartridge. Reinstall cartridge and see if the printer will except cartridge. If still havinging issue, bring printer to a certified technician or call HP at 1800-474-6836 for technical support.
May 29, 2010 | HP Photosmart C6280 Printer
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have a HP Photosmart C5200 - pages are printing pink and red streaks in pictures
the print head for magenta and cyan (might be also Yellow) is dirty. you can try to clean it with warm water, or replace a new print head.
Jul 31, 2009 | HP PhotoSmart InkJet Printer
Print head proplems on the hp photosmart 3310
ok, if you are using old cartriges, might want to try some rubbing alcohol on a tissue. This has worked on a number of cartriges in the past when i start getting missing pins. it lubricates the holes so in can flow again.
Take a q-tip and do the same if there's any kind of print head, but most print heads these days are built into the cartrige.
Mar 21, 2009 | HP Photosmart 3310 Printer
Leaking magenta ink onto output HP 9180
Hi all. After running the clean heads and extended clean heads routine about 5 times i have resolved the issue. Took some time but all seems well now.
Jan 12, 2009 | HP Photosmart Pro B9180 InkJet Printer
Printer will only print color pictures in black and cyan
Hi, this printer color cartridge contains all colors in one. So if you can print with one color means that the whole cartrige is ok but one or more colors ended. And you should had a low ink message on screen if it was genuine HP. Best thing to do is to go and buy a new one cartridge and see how it will go. This cartridge is green color.
Sep 05, 2017 | HP Photosmart 2575 All-In-One Printer,...
HP Photosmart 8250 InkJet Printer Logo
320 people viewed this question
Ben Johnson
