Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
Sleep mode ineffectual
PC continues to cycle on off...on off.
Sleep mode is a joke.
HELP!!!
  • 3 more comments
  • fabfauxfibni Jan 06, 2009
    Had new hard drive installed. That's another story for another day.
    Think sleep mode was behaving at the start BUT of late
    if I click on it it goes to sleep only to reawaken shortky thereafter.
    I t's supposed to WAIT till I move the mouse.
    This is how it Used to behave???
    NOW it simply cycles...sleep waken...sleep... awaken...etc.
    It won't STAY in sleep mode as it should.
    My Wife said she happened to spend a good deal of time in it's room the other day and it cycled on & off all day long???
    If I click on sleep mode in the evening sure enough the thing will be on & running in the morning presumeably cycling all nite.
    NO.
    I'm merely attempting to engage the sleep mode
    until I return. It DOESN'T STAY in sleep mode.
    It cycles on & off???
    OOPS!....
    Thanks for trying though.
    I'm NEW at this.
    Meant no offense. BE CERTAIN OF THIS!
    THANKS!
    We'll give 'er a whirl.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there
    Can you please explain in more detail what happening with the pc
    kind regards
  • 43 Answers
Are you saying that your computer keeps going into standby? You can change your power management settings to whatever you like in your control panel power options. Tell it not to go into standby, hibernate, or anything you don't want.
Posted on Jan 06, 2009
  • Johnathon Haywood
    Johnathon Haywood Jan 06, 2009
    Sounds like a program or background process is bringing it out of sleep mode. Trying running MSCONFIG and disabling everything in startup, then disable all non-microsoft services. Restart and then test to see if it will remain asleep.
Cant get power saving mode off
Step 1:
Sleep Mode b> Sleep mode is primarily used with home computers (desktop computers). Sleep mode is designed to save the current work, programs, and settings of your computer using your computers memory, while using very little power. b> Hibernate Mode b> Hibernate mode is primarily used with laptop's. Hibernate mode is designed to save your computers current state on to the hard disk, then turn off your computer to stop using power completely. This mode is usually used when you do not plan on using your laptop for an extended amount of time. Benefits b> Using Hibernate mode is more power-efficient, but files may become fragmented over time by using this mode frequently. Sleep mode does consume more power, but the advantage that Sleep mode has over Hibernate is that it does not take as long to resume your computers former state when you are ready to continue using it.
Feb 23, 2013 | Lenovo 3000 Computers & Internet
My monitor says it is going to sleep continually. what is wrong?
he is tired let him sleep no Joking of course ...
change the settings on your operating system go to power options on control panel if you are using windows 7 then control panel 2: power options then change when the computer sleep . then second options turn off the display increase the time to 20 Minutes or more .
May 02, 2011 | HP w1907 LCD Monitor
4350 nosiy while in sleep mode
If it comes out of "sleep mode" every 10 minutes, and you haven't touched the printer or sent any data to the printer, try unplugging the LAN cable for 15 minutes. If the printer stays in "sleep mode"either the formatter is bad or whatever is on the other end of the LAN cable could be bad. If you can put the printer on another PC to see what happens, that would really help you out.
Jun 19, 2010 | HP LaserJet 4350 Printer
The fax continually registers as being in "sleep" mode. Says it's in "Sleep" mode all day even when it is receiving and or sending out. How do I correct that?
Setting the Sleep Mode reduces power consumption while the machine is idle.
You can choose how long the machine is idle (from 00 to 99 minutes) before it drops into sleep mode.
The timer automatically resets itself after the machine
receives a fax or PC data, or makes a copy. The default setting is 5 minutes.
1 Press Menu, 1, 8.
2 Use the Dial pad to enter the length of
time the machine is idle before it drops
into sleep mode (00 to 99 minutes), and then press Set.
3 Press Stop/Exit.
Jun 15, 2010 | Brother IntelliFax-4100e Fax
How do I wake up the monitor when it goes to sleep when not used for a short time.
slapping it around usually works. "just a joke!"
tapping a few keys on your keyboard and moving the mouse will usually wake the monitor from sleep mode.
Nov 11, 2009 | Office Equipment & Supplies
Cannot get out of sleep mode
Unplug it, and remove the battery, put it all back, and start the machine. If it continues to do this, then do a system restore, a system repair, or disable the sleep mode to correct it. This could be a one time glitch, however, one of these three will correct the problem if it persists in the future.
Aug 09, 2008 | Lenovo 3000 N200 Notebook
Need help monitor stays in sleep mode... :(
power down, everything, leave it off for a few minutes, turn it back on.. when it gets booted, disable sleep mode option in advanced power features.
Mar 19, 2008 | Computers & Internet
Computers & Internet Logo
96 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
